Autor Thema: Unstable - works only for 1-2 days  (Gelesen 38414 mal)
lattjo
« am: August 18, 2010, 08:54:30 Nachmittag »
I have big problems with my MediaTV dongle.
I use it with TVHeadEnd 2.11 (DVB-C) and it works only for maximum 3 days, after that I get errors like this and picture is very bad.
2010-08-18 20:48:15 [1302] Symbol rate: 6874786
2010-08-18 20:48:15 [1302] Constellation: QAM256
2010-08-18 20:48:15 [1302] Mirroring: Normal
2010-08-18 20:48:15 [1302] TS Sync byte not aligned, realigning stream (180)
2010-08-18 20:48:16 [1302] TS Sync byte not aligned, realigning stream (180)
2010-08-18 20:48:16 [1302] CRC invalid of requested section (0012 00)
uname -a: Linux htpc 2.6.35-gentoo #2 SMP Thu Aug 5 13:30:04 CEST 2010 x86_64 Intel(R) Atom(TM) CPU 330 @ 1.60GHz GenuineIntel GNU/Linux
How can I debug this?
Also it would be nice if the log wasn't spammed with:
Even if everything is ok, it fills my root disk in a week. Please make it possible to log only warnings and errors.
Re:Unstable - works only for 1-2 days
« Antwort #1 am: August 18, 2010, 08:59:02 Nachmittag »
What driver are you using?
did you try http://www.sundtek.de/media/sundtek_installer_development.sh ?
The latest version should have some better recovery support.
The root cause of this can be that something in the system went on heavy load (maybe IO).
/opt/bin/mediaclient --loglevel=off can disable logging if you want to let it run day and night you should use this option
lattjo
« Antwort #2 am: August 21, 2010, 09:28:35 Vormittag »
The development version seems much more stable, it's been running for 2 days now.
Can somehow get it to always start with loglevel=off? As it is now I need to do it manually after each reboot (which I now might not need :) )
« Antwort #3 am: August 21, 2010, 03:02:09 Nachmittag »
we put this feature request onto our development list. We've been working on too many features since the last official driver got released. Although we hope to move the current development driver to a stable release very soon. Just a few days ago we received a firmware update from a chip manufacturer so we have to upgrade our driver again. After this we probably move the entire version to stable.
lattjo
« Antwort #4 am: August 29, 2010, 08:02:19 Nachmittag »
Development driver up and running for 10 days now, thanks :)
It still would be useful if there was a loglevel for logging only warnings.
gergomez
« Antwort #5 am: August 31, 2010, 02:23:32 Nachmittag »
Any plan to upgrade the windows driver with the new firmware, or is it not necessary for windows?? And any update on the OSX development??
Regards,
« Antwort #6 am: September 01, 2010, 10:51:06 Nachmittag »
Regards,
The windows driver will be updated when we're going to release the new DVB-S/S2 devices - which should be at the end of September.
OSX .. different topic and will be answered when it's ready, at least all the linux work nowadays also influences the OSX driver...
