Autor Thema: MediaTV Pro und Azbox Me  (Gelesen 106741 mal)
Re:MediaTV Pro und Azbox Me
« Antwort #45 am: Februar 12, 2013, 03:50:24 Nachmittag »
6, 7 und 8 mhz
ubrell
« Antwort #46 am: Februar 15, 2013, 05:36:47 Nachmittag »
Hi while testing with the azbox devs I noticed in the openpli service scan screen that there are more bandwidth optiosn than just 6,7 and 8Mhz.
tp.Bandwidth_8MHz : "Bw 8MHz", tp.Bandwidth_7MHz : "Bw 7MHz", tp.Bandwidth_6MHz : "Bw 6MHz",
tp.Bandwidth_Auto : "Bw Auto", tp.Bandwidth_5MHz : "Bw 5MHz",
tp.Bandwidth_1_712MHz : "Bw 1.712MHz", tp.Bandwidth_10MHz : "Bw 10MHz"
so the Azbox devs have asked me if you could clarify what you would expect to receive for those 1.712, 5 and 10 Mhz settings.
maybe vtuner shall pass the hz and not a 0,1,2,3 value.
« Antwort #47 am: Februar 15, 2013, 05:41:01 Nachmittag »
that will only work out if they use the new API with SYS_DVBT, eg. DTV_BANDWIDTH_HZ.
Using FE_SET_FRONTEND is not recommended when using DTV_BANDWIDTH_HZ.
