Autor Thema: Channelscan funktioniert nicht: "====tmbslTDA182I2Reset : Fail"  (Gelesen 25292 mal)
pucojazu
« am: Dezember 15, 2011, 03:32:58 Vormittag »
ich habe den Sundtek MediaTV Pro, aber bekomme ihn leider nicht zum Laufen.
Mit der Treiberinstallation scheint alles geklappt zu haben und der Stick wird auch erkannt:
2011-12-14 05:15:00 [1811] Starting up Multimedia Framework (Dec  9 2011 00:42:22)
2011-12-14 05:15:00 [1812] Starting service processor (PID 1812)
2011-12-14 05:15:00 [1811] Detected DVB version.h
2011-12-14 05:15:00 [1811] API Version: 5.3
2011-12-14 05:15:00 [1811] Running on Linux (3.1.5-gentoo)
2011-12-14 05:15:00 [1811] Detected: GenuineIntel
2011-12-14 05:15:00 [1811] This CPU supports: MMX and SSE
2011-12-14 05:15:00 [1811] scanning devices
2011-12-14 05:15:00 [1811] Scanning for drivers
2011-12-14 05:15:00 [1811] found lib: libdrv_net.so
2011-12-14 05:15:00 [1811] found lib: libdrv_em28xx.so
2011-12-14 05:15:00 [1811] found lib: libdrv_vivi.so
2011-12-14 05:15:00 [1811] Scanning for plugins
2011-12-14 05:15:00 [1811] *WARNING* could not open plugin path
2011-12-14 05:15:00 [1811] Starting up device manager
2011-12-14 05:15:00 [1811] unable to open /dev/misc
2011-12-14 05:15:00 [1811] scanning devices done
2011-12-14 05:15:00 [1811] attached devices:
2011-12-14 05:15:00 [1811] registering ID: 0
2011-12-14 05:15:00 [1811] disconnecting kernel driver
2011-12-14 05:15:00 [1812] Autostarting scripts in /etc/sundtek/
2011-12-14 05:15:00 [1812] executed all available items
2011-12-14 05:15:01 [1811] Video is set to first transfer option
2011-12-14 05:15:01 [1811] Audio is set to first transfer option
2011-12-14 05:15:01 [1811] DVB is set to second transfer option
2011-12-14 05:15:01 [1811] attaching Videodecoder
2011-12-14 05:15:03 [1811] attaching DVB-T, DVB-C
2011-12-14 05:15:03 [1811] Using second generation demodulator
2011-12-14 05:15:05 [1811] SETTING DVB-C
2011-12-14 05:15:05 [1811] demodulator successfully attached (DVBC)!
2011-12-14 05:15:05 [1811] requesting to attach tuner(s) now
2011-12-14 05:15:05 [1811] This device uses the second generation Tuner
2011-12-14 05:15:05 [1811] registering: adapter0/0
2011-12-14 05:15:05 [1811] registered virtual: /dev/dvb/adapter0/frontend0
2011-12-14 05:15:05 [1811] registered virtual: /dev/dvb/adapter0/demux0
2011-12-14 05:15:05 [1811] registered virtual: /dev/dvb/adapter0/dvr0
2011-12-14 05:15:05 [1811] registered virtual: /dev/video1
2011-12-14 05:15:05 [1811] registered virtual: /dev/radio0
2011-12-14 05:15:05 [1811] registered virtual: /dev/rds0
2011-12-14 05:15:05 [1811] registered virtual: /dev/vbi0
2011-12-14 05:15:05 [1811] Setting RC Protocol to NEC
2011-12-14 05:15:05 [1811] registered virtual: /dev/mediainput0
2011-12-14 05:15:05 [1812] trying to load uinput module
2011-12-14 05:15:05 [1812] loading uinput kernel extention failed, remote control will not work with lirc
2011-12-14 05:15:05 [1811] No remote control support available
2011-12-14 05:15:05 [1811] Registering OSS emulation
2011-12-14 05:15:05 [1811] registered virtual: /dev/dsp0
2011-12-14 05:15:05 [1811] Sundtek MediaTV Driver loaded. This driver is licensed for non-commercial use
2011-12-14 05:15:05 [1811] with Sundtek MediaTV only
2011-12-14 05:15:05 [1811] Driver loaded within 4793 milliseconds
2011-12-14 05:15:05 [1811] Serial(0): U110714105213
2011-12-14 05:15:07 [1811] Initial devicescan done, switching detection mode
2011-12-14 05:17:49 [1482] attaching DVB-T, DVB-C
2011-12-14 05:17:49 [1482] Using second generation demodulator
2011-12-14 05:17:51 [1482] SETTING DVB-C
2011-12-14 05:17:51 [1482] demodulator successfully attached (DVBC)!
2011-12-14 05:17:51 [1482] requesting to attach tuner(s) now
2011-12-14 05:17:51 [1482] This device uses the second generation Tuner
2011-12-14 05:17:51 [1482] registering: adapter0/0
2011-12-14 05:17:51 [1482] registered virtual: /dev/dvb/adapter0/frontend0
2011-12-14 05:17:51 [1482] registered virtual: /dev/dvb/adapter0/demux0
2011-12-14 05:17:51 [1482] registered virtual: /dev/dvb/adapter0/dvr0
2011-12-14 05:17:51 [1482] registered virtual: /dev/video1
2011-12-14 05:17:51 [1482] registered virtual: /dev/radio0
2011-12-14 05:17:51 [1482] registered virtual: /dev/rds0
2011-12-14 05:17:51 [1482] registered virtual: /dev/vbi0
2011-12-14 05:17:51 [1482] Setting RC Protocol to NEC
2011-12-14 05:17:51 [1482] registered virtual: /dev/mediainput0
2011-12-14 05:17:51 [1483] loading uinput kernel extention failed, remote control will not work with lirc
2011-12-14 05:17:51 [1482] No remote control support available
2011-12-14 05:17:51 [1482] Registering OSS emulation
2011-12-14 05:17:51 [1482] registered virtual: /dev/dsp0
2011-12-14 05:17:51 [1482] Sundtek MediaTV Driver loaded. This driver is licensed for non-commercial use
2011-12-14 05:17:51 [1482] with Sundtek MediaTV only
2011-12-14 05:17:51 [1482] Driver loaded within 4793 milliseconds
2011-12-14 05:17:51 [1482] Serial(0): U110714105213
2011-12-14 05:17:53 [1482] Initial devicescan done, switching detection mode
2011-12-14 05:18:06 [1482] Enabling standby
Wenn ich dann versuche, den Adapter mit VLC im DVB-C Modus zu öffnen, woraufhin VLC mit dem Scannen anfängt, steht im Log immer Folgendes:
2011-12-15 02:22:28 [1482] SETTING DVB-C
2011-12-15 02:22:28 [1482] Using second datatransfer
2011-12-15 02:22:28 [1482] Setting Frequency: 410000000
2011-12-15 02:22:28 [1482] Setting Symbolrate: 6875000
2011-12-15 02:22:28 [1482] Setting Modulation: 6
2011-12-15 02:22:28 [1482] QAM Auto modulation not supported by device
the driver indicates this option in the capability
flags, please fix your application
2011-12-15 02:22:28 [1482] The driver will now try to probe for Q64/Q128 and Q256
2011-12-15 02:22:28 [1482] Trying QAM 64
2011-12-15 02:22:28 [1482] ====tmbslTDA182I2Reset : Fail
2011-12-15 02:22:31 [1482] Retrying with QAM 128
2011-12-15 02:22:32 [1482] ====tmbslTDA182I2Reset : Fail
2011-12-15 02:22:32 [1482] Retrying with QAM 256
2011-12-15 02:22:33 [1482] ====tmbslTDA182I2Reset : Fail
2011-12-15 02:22:34 [1482] QAM64/128/256 did not lock
2011-12-15 02:22:44 [1482] Setting Frequency: 410000000
2011-12-15 02:22:44 [1482] Setting Symbolrate: 6875000
2011-12-15 02:22:44 [1482] Setting Modulation: 6
2011-12-15 02:22:44 [1482] QAM Auto modulation not supported by device
2011-12-15 02:22:44 [1482] The driver will now try to probe for Q64/Q128 and Q256
2011-12-15 02:22:44 [1482] Trying QAM 64
2011-12-15 02:22:44 [1482] ====tmbslTDA182I2Reset : Fail
2011-12-15 02:22:47 [1482] Retrying with QAM 128
2011-12-15 02:22:48 [1482] ====tmbslTDA182I2Reset : Fail
2011-12-15 02:22:49 [1482] Retrying with QAM 256
2011-12-15 02:22:49 [1482] ====tmbslTDA182I2Reset : Fail
2011-12-15 02:22:50 [1482] QAM64/128/256 did not lock
2011-12-15 02:23:00 [1482] Setting Frequency: 410000000
2011-12-15 02:23:00 [1482] Setting Symbolrate: 6875000
2011-12-15 02:23:00 [1482] Setting Modulation: 6
2011-12-15 02:23:00 [1482] QAM Auto modulation not supported by device
2011-12-15 02:23:00 [1482] The driver will now try to probe for Q64/Q128 and Q256
2011-12-15 02:23:00 [1482] Trying QAM 64
2011-12-15 02:23:00 [1482] ====tmbslTDA182I2Reset : Fail
2011-12-15 02:23:03 [1482] Retrying with QAM 128
2011-12-15 02:23:04 [1482] ====tmbslTDA182I2Reset : Fail
2011-12-15 02:23:04 [1482] Retrying with QAM 256
2011-12-15 02:23:05 [1482] ====tmbslTDA182I2Reset : Fail
2011-12-15 02:23:06 [1482] QAM64/128/256 did not lock
VLC bleibt währenddessen beim Scannen hängen, ohne dass etwas passiert.
Woran könnte das liegen bzw. was kann ich da machen?
« Letzte Änderung: Dezember 15, 2011, 03:37:07 Vormittag von pucojazu »
pucojazu
Re:Channelscan funktioniert nicht: "====tmbslTDA182I2Reset : Fail"
« Antwort #1 am: Dezember 20, 2011, 02:51:02 Nachmittag »
Kann mir niemand helfen?   :(
Ist evtl. der Stick einfach defekt?
fLoo
« Antwort #2 am: Dezember 20, 2011, 04:12:55 Nachmittag »
Ich habe ein ähnliches Problem beim Tunen auf 546Mhz, da kann der Stick net LOCKen. Ich warte immernoch auf eine Antwort vom Support..
« Antwort #3 am: Dezember 20, 2011, 11:39:10 Nachmittag »
Nein der Stick ist nicht defekt, es muss die jeweilige Modulation bei VLC angegeben werden (In Deutschland QAM64 oder QAM256). In VLC wird dies über das Advanced Menü eingerichtet. Die Modulationsarten sind wohl nicht sehr leserlich im VLC Menü.
QAM_AUTO = 6 (der Tuner teilt der Software eigentlich mit das dies nicht unterstützt wird, es ist Aufgabe der jeweiligen Software dies auch zu verwerten)
QAM_64 = 3 (QAM 64)
QAM_256 = 5 (QAM 256)
pucojazu
« Antwort #4 am: Dezember 21, 2011, 09:04:39 Nachmittag »
Das funktioniert leider auch nicht.
Außerdem müsste es dann über mediaclient ja gehen, oder?
$ /opt/bin/mediaclient -m DVBC -f 113000000 -S 6900000 -M Q64
bzw.
$ /opt/bin/mediaclient -m DVBC -f 113000000 -S 6900000 -M Q256
Funktioniert also auch nicht.
Im Log steht dazu:
2011-12-21 19:48:53 [16485] Setting Frequency: 113000000
2011-12-21 19:48:53 [16485] Setting Symbolrate: 6900000
2011-12-21 19:48:53 [16485] Setting Modulation: 5
2011-12-21 19:48:53 [16485] ====tmbslTDA182I2Reset : Fail
Was kann ich noch machen?
« Antwort #5 am: Dezember 21, 2011, 11:01:22 Nachmittag »
Stick sollte getauscht werden, Email an kontakt at sundtek de (bitte beachten das dies dann ab 23. Dezember bearbeitet wird).
