Autor Thema: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED on Win 11  (Gelesen 26437 mal)
Tryon
« am: März 03, 2023, 05:08:44 Nachmittag »
...common Windows 1_ error that occurs mainly due to an outdated or incompatible driver.
V tuner will get pretty hot with red LED! Only 14 days left on this eval. Enterprise OS...
« Letzte Änderung: März 03, 2023, 05:12:16 Nachmittag von Tryon »
Re: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED on Win 11
« Antwort #1 am: März 03, 2023, 06:32:55 Nachmittag »
Can you describe your problem a little bit more detailed?
Tryon
« Antwort #2 am: März 03, 2023, 08:03:40 Nachmittag »
another proof that tuner is obv. broken when connecting to TV:
overcurrent error!
And that is all without 12V adapter which is bad idea...
« Antwort #3 am: März 04, 2023, 05:39:02 Vormittag »
If you think your tuner is defect you can send an email to kontakt at sundtek de
Tryon
« Antwort #4 am: März 04, 2023, 07:41:53 Nachmittag »
Thank you.
Hopefully this can lead to new products. For example, we can see that some are interested in Controlling a USALS motor with a USB tuner...
But why stop only on that - Power Consumption:
UPD Panel's ingenious design means that if you want...
Supports up to 5V/3A,15W power charging
...PD_PWR1 connector needs to be connected to the power supply unit.**JUSB6 doesn’t support USB 2.0 and older USB devices.
For multi-device users, MSI Z790 motherboards support USB Power Delivery up to 20V@3A 60W, which can help charge your laptops, tablets and mobile phones.
  • Power Delivery Spec
And this one is fav:
  • The XHCI controller should have better performance. You'll need to use an alternate method of powering the RPi 4 such as PoE or via the expansion header.
  • USB-C port works wonderfully as both a device and host port
  • While you're getting mangled files, we are getting "spurious spikes" on our oscilloscopes...
  • It's perfectly valid to have an XHCI controller that has only USB2 ports (but operating systems tend to...
  • ...or Barrel jack (5v 2.4 Amp or higher PSU).
  • Adjustable Voltage Regulator DC, DROK Buck Boost Converter 6.0V-36V 9v 12v to DC 0.6-36V 24v 5A Power Supply Panel - Digital Display --- input or out voltage, current, temperature, power(and position in custom ver?)
  • if you ever try to find a laptop that gives more than 5 V on its USB-C port, I wish you good luck. As far as I’m aware, such laptops do not exist...
  • ...it would be much faster to go only 50 pulses instead of...
« Letzte Änderung: März 05, 2023, 03:34:52 Vormittag von Tryon »
« Antwort #5 am: März 05, 2023, 11:24:57 Vormittag »
So far I did not see an email from you, and your previous email seems to be expired.
Send a support request via Email to kontakt at sundtek de as mentioned.
