Willkommen
Gast
. Bitte
einloggen
oder
registrieren
1 Stunde
1 Tag
1 Woche
1 Monat
Immer
Übersicht
Support Chat
Discord
Shop
Ticketsystem
Hilfe
Suche
Einloggen
Registrieren
English
{Single, Dual, Quad} Sundtek SkyTV Ultimate
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED on Win 11
« vorheriges
nächstes »
Seiten: [
1
Autor
Thema: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED on Win 11 (Gelesen 26311 mal)
Tryon
am:
März 03, 2023, 05:08:44 Nachmittag »
common Windows 1_ error that occurs mainly due to an outdated or incompatible driver.
V tuner will get pretty hot with red LED! Only 14 days left on this eval. Enterprise OS...
Letzte Änderung: März 03, 2023, 05:12:16 Nachmittag von Tryon
Re: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED on Win 11
Antwort #1 am:
März 03, 2023, 06:32:55 Nachmittag »
Can you describe your problem a little bit more detailed?
Tryon
Antwort #2 am:
März 03, 2023, 08:03:40 Nachmittag »
another proof that tuner is obv. broken when connecting to TV:
over
c
urrent error
maximum
c
urrent
https://www.delock.com/produkt/89935/pdf.html?sprache=de
https://www.delock.com/produkt/89001/pdf.html?sprache=de
large upgra
d
e package
And that is all without 12V adapter which is bad idea...
Antwort #3 am:
März 04, 2023, 05:39:02 Vormittag »
If you think your tuner is defect you can send an email to kontakt at sundtek de
Tryon
Antwort #4 am:
März 04, 2023, 07:41:53 Nachmittag »
Thank you.
Hopefully this can lead to new products. For example, we can see that some are interested in
C
ontrolling a USALS motor with a USB tuner
But why stop only on that -
Power Con
s
umption:
UPD
P
anel's ingenious design means that if you want...
Supports up to 5V/3A,15W power charging
PD_PWR1 connector needs to be connected to the power supply unit.**JUSB6 doesn’t support USB 2.0 and older USB devices.
For
m
ulti-device users, MSI Z790 motherboards support USB Power Delivery up to 20V@3A 60W, which can help charge your laptops, tablets and mobile phones.
Po
w
er Delivery Spec
And this one is fav:
The XH
C
I controller should have better performance. You'll need to use an alternate method of powering the RPi 4 such as PoE or via the expansion header.
USB-C port works wonderfully as both a device and host port
While you're getting mangled files, we are getting "spurious spikes" on our oscilloscopes...
It's perfectly valid to have an XHCI controller that has only USB2 ports (but operating systems tend to...
o
r
Barrel jack (5v 2.4 Amp or higher PSU).
Adjustable Voltage Regulator DC, DROK Buck Boost Converter 6.0V-36V 9v 12v to DC 0.6-36V 24v 5A Power Supply Panel - Digital Display --- input or out voltage, current, temperature, power
(and position in custom ver?)
if you
ever
try to find a laptop that gives more than 5 V on its USB-C port, I wish you good luck. As far as I’m aware, such laptops do not exist...
...it would be much faster to go only 50 pulses instea
d
of...
Letzte Änderung: März 05, 2023, 03:34:52 Vormittag von Tryon
Antwort #5 am:
März 05, 2023, 11:24:57 Vormittag »
So far I did not see an email from you, and your previous email seems to be expired.
Send a support request via Email to kontakt at sundtek de as mentioned.
Seiten: [
1
« vorheriges
nächstes »
English
