Autor Thema: linuxserver/tvheadend + sundtek  (Gelesen 66747 mal)
tomasl
« am: November 19, 2021, 11:49:38 Nachmittag »
Hi, I have issues getting adapter present in tvheadend, I think I did everything as I supposed to and can't figure out with my poor knowledge what's wrong.
I have HC4 with odroid's ubuntu image, docker installed and use the image from linuxserver.io based on alpine linux.
I tried both ./sundtek_netinst.sh and ./sundtek_netinst_testing.sh. in fact I don't know what's the difference, haven't tried to make a diff check.
so, on the host I ran:
cd /var/lib/docker/volumes/tvh/_data/
chmod 777 sundtek_netinst.sh
./sundtek_netinst.sh –createnodes
inside the docker container I ran:
docker exec -it tvh /bin/bash
cd /config
./sundtek_netinst.sh -docker -use-custom-path=/config
the docker CLI to create container is:
docker create --name=tvh \
-v tvh:/config \
-v tvhpicons:/picons \
-v /drives/data2/REC/:/recordings \
-e PUID=1000 -e PGID=1000 \
-e TZ=CET \
-p 9981:9981 \
-p 9982:9982 \
--device=/dev/dvb:/dev/dvb \
--device=/dev/sundtek:/dev/sundtek \
--device=/dev/bus/usb:/dev/bus/usb \
--restart unless-stopped \
and obviously it is installed inside the docker container as mediaclient shows it:
root@f53cfe724529:/opt/bin# ./mediaclient -e
     FESTATUS: STANDBY
     LNBVOLTAGE: DISABLED
     LNBSUPPLY: ACADAPTER
Anything you see I'm not doing or doing wrong?
Re: linuxserver/tvheadend + sundtek
« Antwort #1 am: November 21, 2021, 11:00:47 Vormittag »
will check on Monday.
- check which architecture the tvheadend binary and the driver has
./mediaclient --arch
- there needs to be an LD_PRELOAD=/path/to/libmediaclient.so in the tvheadend start script
« Letzte Änderung: November 21, 2021, 01:49:53 Nachmittag von Sundtek »
norbertk
« Antwort #2 am: November 21, 2021, 05:22:10 Nachmittag »
Is this only required for docker ? I have some hard to track down problems with tvheadend too but work under lxc and not docker.
Sundtek SkyTV Ultimate 8 2018 (DVB-S/S2/S2X) unter proxmox/lxc, debian
tomasl
« Antwort #3 am: November 22, 2021, 12:36:38 Vormittag »
Hi, thank for response. see the answers for your questions.
tvheadend startup script content:
#!/bin/sh
/opt/bin/mediasrv -d --wait-for-devices --pluginpath=/opt/bin
LD_PRELOAD=/opt/lib/libmediaclient.so /usr/bin/tvheadend.bin $@
sundtek driver is arm64:
root@odroid:/opt/bin# ./mediaclient --arch
Architecture: arm64
and I asumed same for tvheadend container as it started just fine without specifically downloading the arm64 image. but just to be sure I explicitly downloaded arm64 image with arm64v8-latest tag and I can see the sundtek adapter finally. thank you.
« Antwort #4 am: November 22, 2021, 04:54:04 Vormittag »
Also be sure that the permissions of /dev/dvb and /dev are ok, if you still cannot figure out what's wrong maybe you can set up remote access to that system (eg. Anydesk) so we can have a quick look at it.
tomasl
« Antwort #5 am: November 22, 2021, 09:45:05 Vormittag »
everything is working alright now, thank you.
tomasl
« Antwort #6 am: November 28, 2021, 10:24:44 Nachmittag »
aaand it doesn't work again...
I haven't touched it. I turned up the TV and HTSP client couldn't connected.
so I restarted TVH container and I got this error:
root@odroid:~# docker start tvh
Error response from daemon: error gathering device information while adding custom device "/dev/dvb": no such file or directory
Error: failed to start containers: tvh
so I checked directory and it's not present...
root@odroid:~# cd /dev/dvb
-bash: cd: /dev/dvb: No such file or directory
I stopped container, ran ./sundtek_netinst.sh –createnodes and started the container and adapter was missing.
so I installed it inside the container again with ./sundtek_netinst.sh -docker -use-custom-path=/config and still nothing.
I removed container, added it again, ran ./sundtek_netinst.sh -u, then ./sundtek_netinst.sh –createnodes again and ./sundtek_netinst.sh -docker -use-custom-path=/config inside the container, restarted the container and nothing.
I checked tvheadend startup script under /usr/bin and LD_PRELOAD is there with correct values, I checked mediaclient -e and it shows the adapter on the host as well as inside docker container. what the...
« Antwort #7 am: November 29, 2021, 06:19:21 Nachmittag »
If you can set up anydesk we can have a look at it.
Be sure you're using the OTG Port of the Odroid system, which one do you have?
Odroid N2 has known USB Bugs, there's a followup product available from Hardkernel
tomasl
« Antwort #8 am: November 29, 2021, 09:35:38 Nachmittag »
I'll get Anydesk set up and then I'll ping you. please let me know when you're usually available and how I could contact you. it will be difficult to align as with my 3 year old I can't do anything next to him as he wants to do everything with me and instead of me...
btw I'm using HC4 and it has only one USB port and I'm using small powered USB hub. I'm afraid to plug the sundtek dongle directly to the USB port of HC4.
« Antwort #9 am: November 30, 2021, 02:44:46 Vormittag »
maybe you can check the online chat today?
The tuner needs around 450mA (two tuners powered), if you connect it directly the host should provide enough power. Active USB Hubs ... they have a certain quality. However we can check what's going on on your side.
tomasl
« Antwort #10 am: November 30, 2021, 11:54:16 Vormittag »
what do you mean two tuners? both analog and DVB-S2 on SkyTV 6? I don't need that analog one.
HC4 USB port is rated 500mA, so I don't want to take the risk something happens to the USB port or the HW behind that.
do you know of some reliable USB self-powered hub?
I'll try to catch you on the chat one day evening.
« Antwort #11 am: November 30, 2021, 07:09:57 Nachmittag »
early in the morning is best!
oh you have another tuner, sorry I thought you have a dual dvb-s2 tuner.
tomasl
« Antwort #12 am: November 30, 2021, 09:35:20 Nachmittag »
nope, I'm waiting for the quad tuner. ;)
I'll try to get to you early in the morning then. in upcoming 3 days.
tomasl
« Antwort #13 am: Dezember 06, 2021, 01:12:43 Vormittag »
I didn't have chance to contact you. my kid's kindergarten has covid holidays. but I was able to make it work again. so those are steps I took:
1) uninstall sundtek driver
2) delete the /dev/dvb directory
3) I didn't install the driver with the -createnodes parameter but found manual way to do it on your wiki pages for synology
mkdir -p /dev/dvb/adapter0
4) created docker container
-v tvh:/config \
-e TZ=CET \
-p 9981:9981 \
-p 9982:9982 \
--restart always \
linuxserver/tvheadend:arm64v8-latest
5) started and entered the docker container and installed the driver there
6) restarted the container and the adapter appeared in the tvheadend web interface and it's working again.
I have no idea what I did wrong before, I tried many times, but I could swear I did it same except the step 3. I hope this time it will work without issues or at least that this is the way how to replicate the successful installation on HC4 with ubuntu and tvheadend docker image.
tomasl
« Antwort #14 am: Dezember 06, 2021, 02:10:43 Nachmittag »
it again disappeared, but this time it was back again when I restarted container. I don't know why, but I assume because I haven't used the tuner since yesterday. Is there some "keepalive" setting in the driver or tvheadend that would prevent this?
