Autor Thema: controle center  (Gelesen 37867 mal)
donald
controle center
« am: April 26, 2012, 09:54:28 Vormittag »
i will use in my vu duo -pli, sundtek controle center, see it in de aplication.
but when i activate it it comes with the question every time "It seems the sundtek driver is not installed or not installed properly. Install the driver now?"
i have install. the driver follow your documentation ,
what to do?
Re:controle center
« Antwort #1 am: April 26, 2012, 12:21:18 Nachmittag »
Did you start the Device in DVB-C or DVB-T mode according to our instruction?
The Control Center needs some updates for settopboxes other than Dreambox
donald
Re:controle center
« Antwort #2 am: April 26, 2012, 01:57:53 Nachmittag »
were can i see the instuctions controle center?
controle center:
dvb transm.way = dvb-c
usb network    = via network
network ip     =192.168.----
autostart      =ja
Re:controle center
« Antwort #3 am: April 26, 2012, 02:06:07 Nachmittag »
Are you using the driver via network?
http://support.sundtek.com/index.php/topic,348.0.html
start from "cd /usr/script"
donald
Re:controle center
« Antwort #4 am: April 26, 2012, 04:27:18 Nachmittag »
no, the driver is in the vu duo
Re:controle center
« Antwort #5 am: April 26, 2012, 04:40:17 Nachmittag »
remove the control center and just follow our documentation:
donald
Re:controle center
« Antwort #6 am: April 26, 2012, 05:14:52 Nachmittag »
thanks, i shell do that,
were can i see of i have the latest driver?
Re:controle center
« Antwort #7 am: April 26, 2012, 05:48:33 Nachmittag »
You can just repeat the installation to update the driver
on the console following command will show you the driver build date:
/opt/bin/mediaclient --build
