Autor Thema: Channel search failure  (Gelesen 37402 mal)
revoxs
« am: November 06, 2010, 03:54:10 Nachmittag »
Hey
Just bought Sundtek Media TV Pro (DVB-CT, Radio, analog TV) a week ago.
Cant't find any chanels on search. Have tryed for one week now.
Have 2 genuine Dremboxes dm800 and dm8000. Have tried to install different images like
Gemini, Newnigma, Peter Pan and so on. They all see the stick, but no channels can be found on neither DVC-C or DVB-T. Signal is ok and works in build-in DVB-C tuner in dm8000.
DVB-T signal is also ok.Have also tried to scan channels on Windows xp and Windows 7 in DVB Viewer 4.5.0 without luck. The stick is lighting blue when searching and the tuner is visible in both dreamboxes.
Telnet commands (/usr/sundtek/mediaclient -e)to the box also shows the unit.
Could there be something wrong with the stick ?
Mediasrv.log shows this:
2010-11-06 14:29:37 [932] Starting up Multimedia Framework (Sep 16 2010 23:39:55)
2010-11-06 14:29:37 [934] Starting service processor (PID 934)
2010-11-06 14:29:37 [932] API Version: 5.1
2010-11-06 14:29:37 [932] Running on Linux (2.6.18-7.3-dm8000)
2010-11-06 14:29:37 [932] Detected Dreambox 8000
2010-11-06 14:29:37 [932] Trying to load DM8000 Acceleration module
2010-11-06 14:29:37 [932] scanning devices
2010-11-06 14:29:37 [932] scanning for plugins
2010-11-06 14:29:37 [932] Starting up device manager
2010-11-06 14:29:37 [932] No device information is given
2010-11-06 14:29:37 [932] scanning devices done
2010-11-06 14:29:37 [932] attached devices:
2010-11-06 14:29:37 [932] registering ID: 0
2010-11-06 14:29:37 [932] detected usb acceleration
2010-11-06 14:29:38 [932] attaching Videodecoder
2010-11-06 14:29:41 [932] attaching DVB-T, DVB-C
2010-11-06 14:29:46 [932] demodulator successfully attached (DVB_C)!
2010-11-06 14:29:46 [932] requesting to attach tuner(s) now
2010-11-06 14:29:46 [932] registering: adapter1/0
2010-11-06 14:29:46 [932] registered virtual: /dev/dvb/adapter1/frontend0
2010-11-06 14:29:46 [932] registered virtual: /dev/dvb/adapter1/demux0
2010-11-06 14:29:46 [932] registered virtual: /dev/dvb/adapter1/dvr0
2010-11-06 14:29:46 [932] registered virtual: /dev/video0
2010-11-06 14:29:46 [932] registered virtual: /dev/radio0
2010-11-06 14:29:46 [932] registered virtual: /dev/rds0
2010-11-06 14:29:46 [932] registered virtual: /dev/vbi0
2010-11-06 14:29:46 [932] registered virtual: /dev/mediainput0
2010-11-06 14:29:46 [934] trying to load uinput module
2010-11-06 14:29:46 [934] loading uinput kernel extention failed, remote control will not work with lirc
2010-11-06 14:29:46 [932] Registering OSS emulation
2010-11-06 14:29:46 [932] registered virtual: /dev/dsp0
2010-11-06 14:29:46 [932] Sundtek MediaTV Driver loaded. This driver is licensed for non-commercial use
2010-11-06 14:29:46 [932] with Sundtek MediaTV only
2010-11-06 14:29:46 [932] Initial devicescan done, switching detection mode
PS:
Living in Denmark.
Scanning information:
DVB-C:
Stofa in Aarhus
Freq: 346
Sym:  6900
Mod:  QAM64 (all other channel except dr1, dr2 are on qam 256)
Network id: 1
DVB-T:
Søsterhøj and Hadsten
« Letzte Änderung: November 06, 2010, 04:11:04 Nachmittag von revoxs »
Re:Channel search failure
« Antwort #1 am: November 06, 2010, 04:24:11 Nachmittag »
Did you do a manual scan? -- Auto-scan for DVB-C does not work (this is not implemented in Enigma2 for external tuners yet).
You might switch on the loglevel:
/usr/sundtek/mediaclient --loglevel=max (for the dreambox)
revoxs
« Antwort #2 am: November 07, 2010, 09:03:17 Vormittag »
Yes I have done a manual scan. When scanning Freq. 346 and logging set to max. mediasrv.log shows this:
2010-11-07 06:44:23 [931] Starting up Multimedia Framework (Sep 16 2010 23:39:55)
2010-11-07 06:44:23 [933] Starting service processor (PID 933)
2010-11-07 06:44:23 [931] API Version: 5.1
2010-11-07 06:44:23 [931] Running on Linux (2.6.18-7.3-dm8000)
2010-11-07 06:44:23 [931] Detected Dreambox 8000
2010-11-07 06:44:23 [931] Trying to load DM8000 Acceleration module
2010-11-07 06:44:23 [931] scanning devices
2010-11-07 06:44:23 [931] scanning for plugins
2010-11-07 06:44:23 [931] Starting up device manager
2010-11-07 06:44:23 [931] No device information is given
2010-11-07 06:44:23 [931] scanning devices done
2010-11-07 06:44:23 [931] attached devices:
2010-11-07 06:44:23 [931] registering ID: 0
2010-11-07 06:44:23 [931] detected usb acceleration
2010-11-07 06:44:24 [931] attaching Videodecoder
2010-11-07 06:44:27 [931] attaching DVB-T, DVB-C
2010-11-07 06:44:32 [931] demodulator successfully attached (DVB_C)!
2010-11-07 06:44:32 [931] requesting to attach tuner(s) now
2010-11-07 06:44:32 [931] registering: adapter1/0
2010-11-07 06:44:32 [931] registered virtual: /dev/dvb/adapter1/frontend0
2010-11-07 06:44:32 [931] registered virtual: /dev/dvb/adapter1/demux0
2010-11-07 06:44:32 [931] registered virtual: /dev/dvb/adapter1/dvr0
2010-11-07 06:44:32 [931] registered virtual: /dev/video0
2010-11-07 06:44:32 [931] registered virtual: /dev/radio0
2010-11-07 06:44:32 [931] registered virtual: /dev/rds0
2010-11-07 06:44:32 [931] registered virtual: /dev/vbi0
2010-11-07 06:44:32 [931] registered virtual: /dev/mediainput0
2010-11-07 06:44:32 [933] trying to load uinput module
2010-11-07 06:44:33 [933] loading uinput kernel extention failed, remote control will not work with lirc
2010-11-07 06:44:33 [931] Registering OSS emulation
2010-11-07 06:44:33 [931] registered virtual: /dev/dsp0
2010-11-07 06:44:33 [931] Sundtek MediaTV Driver loaded. This driver is licensed for non-commercial use
2010-11-07 06:44:33 [931] with Sundtek MediaTV only
2010-11-07 06:44:33 [931] Initial devicescan done, switching detection mode
2010-11-07 07:58:14 [931] dreambox: reconnecting frontend
2010-11-07 07:58:14 [931] SETTING DVB-C
2010-11-07 07:58:15 [931] reinitializing previous digital TV parameters
2010-11-07 07:58:15 [931] Setting Frequency: 346000000
2010-11-07 07:58:15 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:15 [931] Setting Modulation: 3
2010-11-07 07:58:16 [931] Enabling Hardwarefilter
2010-11-07 07:58:16 [931] dreambox: reconnecting demuxng
2010-11-07 07:58:16 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:16 [931] Setting Frequency: 346000000
2010-11-07 07:58:16 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:16 [931] Setting Modulation: 3
2010-11-07 07:58:18 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:18 [931] Setting Frequency: 346000000
2010-11-07 07:58:18 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:18 [931] Setting Modulation: 3
2010-11-07 07:58:20 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:20 [931] Setting Frequency: 346000000
2010-11-07 07:58:20 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:20 [931] Setting Modulation: 3
2010-11-07 07:58:22 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:22 [931] Setting Frequency: 346000000
2010-11-07 07:58:22 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:22 [931] Setting Modulation: 3
2010-11-07 07:58:24 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:24 [931] Setting Frequency: 346000000
2010-11-07 07:58:24 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:24 [931] Setting Modulation: 3
2010-11-07 07:58:26 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:26 [931] Setting Frequency: 346000000
2010-11-07 07:58:26 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:26 [931] Setting Modulation: 3
2010-11-07 07:58:28 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:28 [931] Setting Frequency: 346000000
2010-11-07 07:58:28 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:28 [931] Setting Modulation: 3
2010-11-07 07:58:30 [931] FE_SET_VOLTAGE not supported by DVB-C
2010-11-07 07:58:30 [931] dreambox: reconnecting frontend
2010-11-07 07:58:30 [931] Enabling Hardwarefilter
2010-11-07 07:58:30 [931] dreambox: reconnecting demuxng
2010-11-07 07:58:30 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:30 [931] Setting Frequency: 346000000
2010-11-07 07:58:30 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:30 [931] Setting Modulation: 3
2010-11-07 07:58:32 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:32 [931] Setting Frequency: 346000000
2010-11-07 07:58:32 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:32 [931] Setting Modulation: 3
2010-11-07 07:58:33 [931] Warning all hardware pid filter are in use unable to set PID 0x0000
2010-11-07 07:58:33 [931] Dump:
2010-11-07 07:58:33 [931] SLOT: 0 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 1 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 2 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 3 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 4 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 5 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 6 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 7 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 8 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 9 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 10 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 11 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 12 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 13 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:33 [931] SLOT: 14 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:34 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:34 [931] Setting Frequency: 346000000
2010-11-07 07:58:34 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:34 [931] Setting Modulation: 3
2010-11-07 07:58:37 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:37 [931] Setting Frequency: 346000000
2010-11-07 07:58:37 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:37 [931] Setting Modulation: 3
2010-11-07 07:58:39 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:39 [931] Setting Frequency: 346000000
2010-11-07 07:58:39 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:39 [931] Setting Modulation: 3
2010-11-07 07:58:41 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:41 [931] Setting Frequency: 346000000
2010-11-07 07:58:41 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:41 [931] Setting Modulation: 3
2010-11-07 07:58:43 [931] FE_SET_FRONTEND: 346000000
2010-11-07 07:58:43 [931] Setting Frequency: 346000000
2010-11-07 07:58:43 [931] Setting Symbolrate: 6900000
2010-11-07 07:58:43 [931] Setting Modulation: 3
2010-11-07 07:58:45 [931] FE_SET_VOLTAGE not supported by DVB-C
2010-11-07 07:58:46 [931] dreambox: reconnecting frontend
2010-11-07 07:58:46 [931] Enabling Hardwarefilter
2010-11-07 07:58:46 [931] dreambox: reconnecting demuxng
2010-11-07 07:58:46 [931] Warning all hardware pid filter are in use unable to set PID 0x0000
2010-11-07 07:58:46 [931] Dump:
2010-11-07 07:58:46 [931] SLOT: 0 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 1 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 2 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 3 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 4 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 5 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 6 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 7 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 8 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 9 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 10 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 11 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 12 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 13 PID: -1/ffffffff ENABLED: 0
2010-11-07 07:58:46 [931] SLOT: 14 PID: -1/ffffffff ENABLED: 0
« Antwort #3 am: November 07, 2010, 01:24:29 Nachmittag »
revoxs
« Antwort #4 am: November 07, 2010, 05:27:35 Nachmittag »
Sorry, no luck with that either. Have tried on new kernel 2.6.18-7.4 (Newnigma2 ver. 3.1) as well. Have also manually scanned all known freq. in my cabelnet and dvb-t. Also tried Transedit blindscan on my laptop  ???
Mediasrv.log from sundtek_installer_development driver:
2010-11-07 16:20:11 [937] dreambox: reconnecting frontend
2010-11-07 16:20:11 [937] SETTING DVB-C
2010-11-07 16:20:11 [937] reinitializing previous digital TV parameters
2010-11-07 16:20:11 [937] Setting Frequency: 346000000
2010-11-07 16:20:11 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:11 [937] Setting Modulation: 5
2010-11-07 16:20:12 [937] Enabling Hardwarefilter
2010-11-07 16:20:12 [937] dreambox: reconnecting demuxng
2010-11-07 16:20:12 [937] Setting Frequency: 842000000
2010-11-07 16:20:12 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:12 [937] Setting Modulation: 5
2010-11-07 16:20:14 [937] Setting Frequency: 842000000
2010-11-07 16:20:14 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:14 [937] Setting Modulation: 5
2010-11-07 16:20:16 [937] Setting Frequency: 842000000
2010-11-07 16:20:16 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:16 [937] Setting Modulation: 5
2010-11-07 16:20:19 [937] Setting Frequency: 842000000
2010-11-07 16:20:19 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:19 [937] Setting Modulation: 5
2010-11-07 16:20:21 [937] Setting Frequency: 842000000
2010-11-07 16:20:21 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:21 [937] Setting Modulation: 5
2010-11-07 16:20:23 [937] Setting Frequency: 842000000
2010-11-07 16:20:23 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:23 [937] Setting Modulation: 5
2010-11-07 16:20:25 [937] Setting Frequency: 842000000
2010-11-07 16:20:25 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:25 [937] Setting Modulation: 5
2010-11-07 16:20:27 [937] Setting Frequency: 842000000
2010-11-07 16:20:27 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:27 [937] Setting Modulation: 5
2010-11-07 16:20:29 [937] closing demuxfd
2010-11-07 16:20:29 [937] FE_SET_VOLTAGE not supported by DVB-C
2010-11-07 16:20:30 [937] dreambox: reconnecting frontend
2010-11-07 16:20:30 [937] Enabling Hardwarefilter
2010-11-07 16:20:30 [937] dreambox: reconnecting demuxng
2010-11-07 16:20:30 [937] Warning all hardware pid filter are in use unable to set PID 0x00f8
2010-11-07 16:20:30 [937] Dump:
2010-11-07 16:20:30 [937] SLOT: 0 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 1 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 2 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 3 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 4 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 5 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 6 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 7 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 8 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 9 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 10 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 11 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 12 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 13 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:30 [937] SLOT: 14 PID: -1/ffffffff ENABLED: 0
2010-11-07 16:20:41 [937] Setting Frequency: 346000000
2010-11-07 16:20:41 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:41 [937] Setting Modulation: 3
2010-11-07 16:20:43 [937] Setting Frequency: 346000000
2010-11-07 16:20:43 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:43 [937] Setting Modulation: 3
2010-11-07 16:20:45 [937] Setting Frequency: 346000000
2010-11-07 16:20:45 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:45 [937] Setting Modulation: 3
2010-11-07 16:20:47 [937] Setting Frequency: 346000000
2010-11-07 16:20:47 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:47 [937] Setting Modulation: 3
2010-11-07 16:20:49 [937] Setting Frequency: 346000000
2010-11-07 16:20:49 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:49 [937] Setting Modulation: 3
2010-11-07 16:20:52 [937] Setting Frequency: 346000000
2010-11-07 16:20:52 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:52 [937] Setting Modulation: 3
2010-11-07 16:20:54 [937] Setting Frequency: 346000000
2010-11-07 16:20:54 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:54 [937] Setting Modulation: 3
2010-11-07 16:20:56 [937] Setting Frequency: 346000000
2010-11-07 16:20:56 [937] Setting Symbolrate: 6900000
2010-11-07 16:20:56 [937] Setting Modulation: 3
« Antwort #5 am: November 07, 2010, 05:31:58 Nachmittag »
2.6.18-7.4 does not work yet, DreamMultimedia is currently preparing an update for it. The USB Tuner interface is currently broken and causes a memory corruption
revoxs
« Antwort #6 am: November 08, 2010, 04:49:49 Nachmittag »
Still the same with new driver, have tried 834000 qam256 where there also are channels.
Next step could be to transfer the hole sh.. to my mothers apartment where they have cable tv from the second provider in Aarhus (TDC YouSEE).
From log with new sundtek_installer_development:
2010-11-08 15:39:32 [956] Starting up Multimedia Framework (Nov  7 2010 16:36:42)
2010-11-08 15:39:32 [958] Starting service processor (PID 958)
2010-11-08 15:39:32 [956] API Version: 5.1
2010-11-08 15:39:32 [956] Running on Linux (2.6.18-7.3-dm8000)
2010-11-08 15:39:32 [956] Detected Dreambox 8000
2010-11-08 15:39:32 [956] Trying to load DM8000 Acceleration module
2010-11-08 15:39:32 [956] scanning devices
2010-11-08 15:39:32 [956] scanning for plugins
2010-11-08 15:39:32 [956] Starting up device manager
2010-11-08 15:39:32 [956] Created Masterlock
2010-11-08 15:39:32 [956] scanning devices done
2010-11-08 15:39:32 [956] attached devices:
2010-11-08 15:39:32 [956] registering ID: 0
2010-11-08 15:39:32 [956] detected usb acceleration
2010-11-08 15:39:33 [958] Autostarting scripts in /etc/sundtek/
2010-11-08 15:39:33 [958] executed all available items
2010-11-08 15:39:33 [956] attaching Videodecoder
2010-11-08 15:39:36 [956] attaching DVB-T, DVB-C
2010-11-08 15:39:36 [956] Using old settings
2010-11-08 15:39:41 [956] demodulator successfully attached (DVB_C)!
2010-11-08 15:39:41 [956] requesting to attach tuner(s) now
2010-11-08 15:39:41 [956] registering: adapter1/0
2010-11-08 15:39:41 [956] registered virtual: /dev/dvb/adapter1/frontend0
2010-11-08 15:39:41 [956] registered virtual: /dev/dvb/adapter1/demux0
2010-11-08 15:39:41 [956] registered virtual: /dev/dvb/adapter1/dvr0
2010-11-08 15:39:41 [956] registered virtual: /dev/video0
2010-11-08 15:39:41 [956] registered virtual: /dev/radio0
2010-11-08 15:39:41 [956] registered virtual: /dev/rds0
2010-11-08 15:39:41 [956] registered virtual: /dev/vbi0
2010-11-08 15:39:41 [956] registered virtual: /dev/mediainput0
2010-11-08 15:39:41 [958] trying to load uinput module
2010-11-08 15:39:42 [958] loading uinput kernel extention failed, remote control will not work with lirc
2010-11-08 15:39:42 [956] Registering OSS emulation
2010-11-08 15:39:42 [956] registered virtual: /dev/dsp0
2010-11-08 15:39:42 [956] Sundtek MediaTV Driver loaded. This driver is licensed for non-commercial use
2010-11-08 15:39:42 [956] with Sundtek MediaTV only
2010-11-08 15:39:42 [956] Initial devicescan done, switching detection mode
2010-11-08 15:41:01 [956] dreambox: reconnecting frontend
2010-11-08 15:41:01 [956] SETTING DVB-C
2010-11-08 15:41:01 [956] Enabling Hardwarefilter
2010-11-08 15:41:01 [956] dreambox: reconnecting demuxng
2010-11-08 15:41:01 [956] Setting Frequency: 346000000
2010-11-08 15:41:01 [956] Setting Symbolrate: 6900000
2010-11-08 15:41:01 [956] Setting Modulation: 3
2010-11-08 15:41:04 [956] Setting Frequency: 346000000
2010-11-08 15:41:04 [956] Setting Symbolrate: 6900000
2010-11-08 15:41:04 [956] Setting Modulation: 3
2010-11-08 15:41:06 [956] Setting Frequency: 346000000
2010-11-08 15:41:06 [956] Setting Symbolrate: 6900000
2010-11-08 15:41:06 [956] Setting Modulation: 3
2010-11-08 15:41:08 [956] Setting Frequency: 346000000
2010-11-08 15:41:08 [956] Setting Symbolrate: 6900000
2010-11-08 15:41:08 [956] Setting Modulation: 3
2010-11-08 15:41:11 [956] Setting Frequency: 346000000
2010-11-08 15:41:11 [956] Setting Symbolrate: 6900000
2010-11-08 15:41:11 [956] Setting Modulation: 3
2010-11-08 15:41:13 [956] Setting Frequency: 346000000
2010-11-08 15:41:13 [956] Setting Symbolrate: 6900000
2010-11-08 15:41:13 [956] Setting Modulation: 3
2010-11-08 15:41:15 [956] Setting Frequency: 346000000
2010-11-08 15:41:15 [956] Setting Symbolrate: 6900000
2010-11-08 15:41:15 [956] Setting Modulation: 3
2010-11-08 15:41:16 [956] closing demuxfd
2010-11-08 15:41:16 [956] FE_SET_VOLTAGE not supported by DVB-C
2010-11-08 15:41:31 [956] Enabling standby
2010-11-08 15:43:06 [956] dreambox: reconnecting frontend
2010-11-08 15:43:06 [956] SETTING DVB-C
2010-11-08 15:43:06 [956] reinitializing previous digital TV parameters
2010-11-08 15:43:06 [956] Setting Frequency: 346000000
2010-11-08 15:43:06 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:06 [956] Setting Modulation: 3
2010-11-08 15:43:07 [956] Enabling Hardwarefilter
2010-11-08 15:43:07 [956] dreambox: reconnecting demuxng
2010-11-08 15:43:07 [956] Setting Frequency: 834000000
2010-11-08 15:43:07 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:07 [956] Setting Modulation: 5
2010-11-08 15:43:09 [956] Setting Frequency: 834000000
2010-11-08 15:43:09 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:09 [956] Setting Modulation: 5
2010-11-08 15:43:11 [956] Setting Frequency: 834000000
2010-11-08 15:43:11 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:11 [956] Setting Modulation: 5
2010-11-08 15:43:13 [956] Setting Frequency: 834000000
2010-11-08 15:43:13 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:13 [956] Setting Modulation: 5
2010-11-08 15:43:15 [956] Setting Frequency: 834000000
2010-11-08 15:43:15 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:15 [956] Setting Modulation: 5
2010-11-08 15:43:16 [956] Setting Frequency: 834000000
2010-11-08 15:43:16 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:16 [956] Setting Modulation: 5
2010-11-08 15:43:18 [956] Setting Frequency: 834000000
2010-11-08 15:43:18 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:18 [956] Setting Modulation: 5
2010-11-08 15:43:20 [956] Setting Frequency: 834000000
2010-11-08 15:43:20 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:20 [956] Setting Modulation: 5
2010-11-08 15:43:22 [956] Setting Frequency: 834000000
2010-11-08 15:43:22 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:22 [956] Setting Modulation: 5
2010-11-08 15:43:24 [956] Setting Frequency: 834000000
2010-11-08 15:43:24 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:24 [956] Setting Modulation: 5
2010-11-08 15:43:26 [956] Setting Frequency: 834000000
2010-11-08 15:43:26 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:26 [956] Setting Modulation: 5
2010-11-08 15:43:28 [956] Setting Frequency: 834000000
2010-11-08 15:43:28 [956] Setting Symbolrate: 6900000
2010-11-08 15:43:28 [956] Setting Modulation: 5
2010-11-08 15:43:30 [956] closing demuxfd
2010-11-08 15:43:30 [956] FE_SET_VOLTAGE not supported by DVB-C
2010-11-08 15:43:46 [956] Enabling standby
« Antwort #7 am: November 08, 2010, 05:01:56 Nachmittag »
Maybe that's a usecase for our new tuners with improved DVB-C error correction.
We might be able to replace this one with a tuner from the new series once they arrive in Berlin.
revoxs
« Antwort #8 am: November 09, 2010, 07:47:12 Vormittag »
Thanks that sounds great  :)
Do you know when they will arrive ?
« Antwort #9 am: November 09, 2010, 08:26:55 Vormittag »
Supposed to be at the end of this week.
revoxs
« Antwort #10 am: Dezember 06, 2010, 06:24:50 Nachmittag »
Hi
I returned the USB tuner on November 17 but it was not picked up in Berlin (delivered on saturday nov. 19). It cost me dkr 195 (25 euro) to send it and it costs me additional 25 euro to retrieve it at the local post office.
My question is now, do I pick it up and pay 25 euro and then pay another 25 euro to sent it once more ?
It starts to get pretty expensive this Christmas.
revoxs
« Antwort #11 am: Dezember 29, 2010, 04:09:45 Nachmittag »
Have recieved a new tuner and all is working perfect  :D
Happy new year
