Autor Thema: merkwürdiges Problem bei zeitgleichen Aufnahmen  (Gelesen 77353 mal)
sundown
  • Sundtek Member
Re:merkwürdiges Problem bei zeitgleichen Aufnahmen
« Antwort #30 am: November 03, 2010, 07:38:23 Nachmittag »
Kann ich bei mir nicht bestätigen.
Gerade EinsExtra geschaut dann springt der Timer an um Pro7 aufzunehmen.
syslog:
Nov  3 18:09:00 udattsvdr vdr: [1349] switching device 1 to channel 2
Nov  3 18:09:00 udattsvdr vdr: [1349] timer 3 (2 1809-1848 'Die Simpsons') start
Nov  3 18:09:00 udattsvdr vdr: [1349] Title: 'Die Simpsons' Subtitle: '(null)'
Nov  3 18:09:00 udattsvdr vdr: [1349] executing '/usr/lib/vdr/vdr-recordingaction before "/srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec"'
Nov  3 18:09:00 udattsvdr vdr: [1497] TS buffer on device 1 thread ended (pid=1349, tid=1497)
Nov  3 18:09:00 udattsvdr vdr: [1496] buffer stats: 124644 (2%) used
Nov  3 18:09:01 udattsvdr vdr: [1496] receiver on device 1 thread ended (pid=1349, tid=1496)
Nov  3 18:09:01 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] wait_stream_sync: discard_index 1624479048 != curpos 1624435808 ! (diff 43240)
Nov  3 18:09:01 udattsvdr recordingaction: executing /usr/share/vdr/recording-hooks/R90.custom before recording /srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec as shell script
Nov  3 18:09:01 udattsvdr vdr: [1349] record /srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec
Nov  3 18:09:01 udattsvdr vdr: [1349] creating directory /srv/vdr/video.00/Die_Simpsons
Nov  3 18:09:01 udattsvdr vdr: [1349] creating directory /srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec
Nov  3 18:09:01 udattsvdr vdr: [1349] recording to '/srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec/00001.ts'
Nov  3 18:09:01 udattsvdr vdr: [1609] recording thread started (pid=1349, tid=1609)
Nov  3 18:09:01 udattsvdr vdr: [1610] ecmhandler 0 filter thread started (pid=1349, tid=1610)
Nov  3 18:09:01 udattsvdr vdr: [1611] receiver on device 1 thread started (pid=1349, tid=1611)
Nov  3 18:09:01 udattsvdr vdr: [1349] markad: executing "/usr/bin"/markad  -v  -B  -G  -O  -a  -r 2 -l "/var/lib/markad" --online=2 before "/srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec"
Nov  3 18:09:01 udattsvdr vdr: [1613] TS buffer on device 1 thread started (pid=1349, tid=1613)
Nov  3 18:09:02 udattsvdr vdr: [1433] channel 2 (ProSieben) event Mit 03.11.2010 18:01-18:11 'NEWSTIME' status 4
Nov  3 18:09:02 udattsvdr vdr: [1433] channel 4 (kabel eins) event Mit 03.11.2010 17:53-18:46 'Abenteuer Leben - täglich Wissen' status 4
Nov  3 18:09:09 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] No data in 8 seconds, queuing no signal image
Nov  3 18:09:09 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] using custom "no signal" image /usr/share/libxine1-xvdr/nosignal.mpg
Nov  3 18:09:17 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] No data in 8 seconds, queuing no signal image
Nov  3 18:09:17 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] using custom "no signal" image /usr/share/libxine1-xvdr/nosignal.mpg
Nov  3 18:09:25 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] No data in 8 seconds, queuing no signal image
Nov  3 18:09:25 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] using custom "no signal" image /usr/share/libxine1-xvdr/nosignal.mpg
Nov  3 18:09:34 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] No data in 8 seconds, queuing no signal image
Nov  3 18:09:34 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] using custom "no signal" image /usr/share/libxine1-xvdr/nosignal.mpg
Nov  3 18:09:42 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] No data in 8 seconds, queuing no signal image
Nov  3 18:09:42 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] using custom "no signal" image /usr/share/libxine1-xvdr/nosignal.mpg
Nov  3 18:09:51 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] No data in 8 seconds, queuing no signal image
Nov  3 18:09:51 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] using custom "no signal" image /usr/share/libxine1-xvdr/nosignal.mpg
Nov  3 18:09:59 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] No data in 8 seconds, queuing no signal image
Nov  3 18:09:59 udattsvdr vdr-sxfe[1439]: [1464] [input_vdr] using custom "no signal" image /usr/share/libxine1-xvdr/nosignal.mpg
Nov  3 18:10:00 udattsvdr vdr: [1349] PANIC: watchdog timer expired - exiting!
Nov  3 18:10:01 udattsvdr init: vdr main process (1349) terminated with status 1
Nov  3 18:10:01 udattsvdr vdr-sxfe[1439]: [1439] [vdr-fe]    caught signal 15
Nov  3 18:10:01 udattsvdr init: pipecountlog main process (1400) killed by TERM signal
Nov  3 18:10:01 udattsvdr vdr-sxfe[1439]: [1439] [input_vdr] Connections closed.
Nov  3 18:10:01 udattsvdr vdr-sxfe[1439]: [1439] [vdr-fe]    Failed to open connection to bus: /bin/dbus-launch terminated abnormally without any error message
Nov  3 18:10:01 udattsvdr vdr-sxfe[1439]: [1439] [vdr-fe]       (ERROR (tools/gnome_screensaver.c,61): Resource temporarily unavailable)
Nov  3 18:10:03 udattsvdr init: vdr-frontend main process (1399) terminated with status 255
Nov  3 18:10:03 udattsvdr init: logo-stop main process (1619) killed by TERM signal
Nov  3 18:10:03 udattsvdr vdr: [1671] cTimeMs: using monotonic clock (resolution is 1 ns)
Nov  3 18:10:03 udattsvdr init: logo-start main process (1658) killed by TERM signal
Nov  3 18:10:03 udattsvdr vdr: [1659] cTimeMs: using monotonic clock (resolution is 1 ns)
Nov  3 18:10:03 udattsvdr vdr: [1659] VDR version 1.7.16 started
nachdem ich kein sudo stop vdr mehr half, musste man den vdr mit killall -9 vdr beenden und wieder mit sudo start vdr starten.
Dann sah Syslog wie folgt aus.
Nov  3 18:11:20 udattsvdr vdr-sxfe[2347]: [2372] [demux_vdr] PMT changed, resetting demuxer
Nov  3 18:11:20 udattsvdr vdr: [2270] switching device 1 to channel 2
Nov  3 18:11:21 udattsvdr vdr: [2270] timer 3 (2 1809-1848 'Die Simpsons') start
Nov  3 18:11:21 udattsvdr vdr: [2270] Title: 'Die Simpsons' Subtitle: '(null)'
Nov  3 18:11:21 udattsvdr vdr: [2270] executing '/usr/lib/vdr/vdr-recordingaction before "/srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec"'
Nov  3 18:11:21 udattsvdr recordingaction: executing /usr/share/vdr/recording-hooks/R90.custom before recording /srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec as shell script
Nov  3 18:11:21 udattsvdr vdr: [2270] record /srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec
Nov  3 18:11:21 udattsvdr vdr: [2270] recording to '/srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec/00002.ts'
Nov  3 18:11:21 udattsvdr vdr: [2388] recording thread started (pid=2270, tid=2388)
Nov  3 18:11:21 udattsvdr vdr: [2270] markad: executing "/usr/bin"/markad  -v  -B  -G  -O  -a  -r 2 -l "/var/lib/markad" --online=2 before "/srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec"
Nov  3 18:11:21 udattsvdr markad: [2390] starting v0.0.7
Nov  3 18:11:21 udattsvdr markad: [2390] on /video/Die_Simpsons/2010-11-03.18.09.2-0.rec
Nov  3 18:11:21 udattsvdr vdr: [2270] max. latency time 1 seconds
Nov  3 18:11:21 udattsvdr vdr: [2349] EPGSearch: search timer update started
Nov  3 18:11:21 udattsvdr vdr: [2350] EPGSearch: timer conflict check started
Nov  3 18:11:22 udattsvdr vdr: [2341] channel 2 (ProSieben) event Mit 03.11.2010 18:11-18:38 'Die Simpsons' status 4
Nov  3 18:11:22 udattsvdr vdr: [2341] channel 4 (kabel eins) event Mit 03.11.2010 17:53-18:46 'Abenteuer Leben - täglich Wissen' status 4
Nov  3 18:11:22 udattsvdr vdr: [2350] EPGSearch: timer conflict check finished
Nov  3 18:11:22 udattsvdr vdr: [2349] EPGSearch: search timer update finished
Nov  3 18:11:23 udattsvdr vdr: [2270] stopping recording due to modification of channel 2
Nov  3 18:11:23 udattsvdr vdr: [2388] recording thread ended (pid=2270, tid=2388)
Nov  3 18:11:23 udattsvdr vdr: [2270] buffer stats: 35532 (0%) used
Nov  3 18:11:23 udattsvdr vdr: [2270] timer 3 (2 1809-1848 'Die Simpsons') stop
Nov  3 18:11:23 udattsvdr vdr: [2270] executing '/usr/lib/vdr/vdr-recordingaction after "/srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec"'
Nov  3 18:11:24 udattsvdr recordingaction: executing /usr/share/vdr/recording-hooks/R90.custom after recording /srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec as shell script
Nov  3 18:11:24 udattsvdr vdr: [2270] retuning due to modification of channel 2
Nov  3 18:11:24 udattsvdr vdr: [2270] switching to channel 2
Nov  3 18:11:24 udattsvdr vdr-sxfe[2347]: [2371] [input_vdr] vdr_flush_engine: playback is paused <0>
Nov  3 18:11:24 udattsvdr vdr-sxfe[2347]: [2372] [input_vdr] wait_stream_sync: discard_index 756136 != curpos 739216 ! (diff 16920)
Nov  3 18:11:24 udattsvdr vdr: [2270] switching device 1 to channel 2
Nov  3 18:11:24 udattsvdr vdr: [2270] timer 3 (2 1809-1848 'Die Simpsons') start
Nov  3 18:11:24 udattsvdr vdr: [2270] Title: 'Die Simpsons' Subtitle: '(null)'
Nov  3 18:11:24 udattsvdr vdr: [2270] executing '/usr/lib/vdr/vdr-recordingaction before "/srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec"'
Nov  3 18:11:24 udattsvdr recordingaction: executing /usr/share/vdr/recording-hooks/R90.custom before recording /srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec as shell script
Nov  3 18:11:24 udattsvdr vdr: [2270] record /srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec
Nov  3 18:11:24 udattsvdr vdr: [2270] cFileName::SetOffset: removing zero-sized file /srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec/00002.ts
Nov  3 18:11:24 udattsvdr vdr: [2270] recording to '/srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec/00002.ts'
Nov  3 18:11:24 udattsvdr vdr: [2403] recording thread started (pid=2270, tid=2403)
Nov  3 18:11:24 udattsvdr vdr: [2270] markad: executing "/usr/bin"/markad  -v  -B  -G  -O  -a  -r 2 -l "/var/lib/markad" --online=2 before "/srv/vdr/video.00/Die_Simpsons/2010-11-03.18.09.2-0.rec"
Nov  3 18:11:24 udattsvdr markad: [2405] starting v0.0.7
Nov  3 18:11:24 udattsvdr markad: [2405] on /video/Die_Simpsons/2010-11-03.18.09.2-0.rec
Nov  3 18:11:24 udattsvdr markad: [2405] another instance is running on this recording
Nov  3 18:11:24 udattsvdr vdr-sxfe[2347]: [2372] [demux_vdr] PMT changed, resetting demuxer
Nov  3 18:11:25 udattsvdr vdr: [2378] [xine..put] Detected video size 720x576
Nov  3 18:11:25 udattsvdr vdr: [2381] Text2Skin: channelInfo display update thread ended (pid=2270, tid=2381)
sundown
  • Sundtek Member
« Antwort #31 am: November 03, 2010, 07:40:19 Nachmittag »
mediasrv dazu:
2010-11-03 18:08:58 [1039] Symbol rate: 6899887
2010-11-03 18:08:58 [1039] Constellation: QAM64
2010-11-03 18:08:58 [1039] Mirroring: Mirrored
2010-11-03 18:08:59 [1039] Channel found (458000000)
2010-11-03 18:08:59 [1039] =============
2010-11-03 18:08:59 [1039] Symbol rate: 6899887
2010-11-03 18:08:59 [1039] Constellation: QAM64
2010-11-03 18:08:59 [1039] Mirroring: Mirrored
2010-11-03 18:09:00 [1039] Channel found (458000000)
2010-11-03 18:09:00 [1039] =============
2010-11-03 18:09:00 [1039] Symbol rate: 6899889
2010-11-03 18:09:00 [1039] Constellation: QAM64
2010-11-03 18:09:00 [1039] Mirroring: Mirrored
2010-11-03 18:09:01 [1039] Channel found (458000000)
2010-11-03 18:09:01 [1039] =============
2010-11-03 18:09:01 [1039] Symbol rate: 6899887
2010-11-03 18:09:01 [1039] Constellation: QAM64
2010-11-03 18:09:01 [1039] Mirroring: Mirrored
2010-11-03 18:09:01 [1039] Setting Frequency: 330000000
2010-11-03 18:09:01 [1039] Setting Symbolrate: 6900000
2010-11-03 18:09:01 [1039] Setting Modulation: 5
2010-11-03 18:09:01 [1039] Channel found (330000000)
2010-11-03 18:09:01 [1039] Symbol rate: 6899932
2010-11-03 18:09:01 [1039] Constellation: QAM256
2010-11-03 18:09:01 [1039] Symbol rate: 6899935
2010-11-03 18:09:02 [1039] Channel found (330000000)
2010-11-03 18:09:02 [1039] =============
2010-11-03 18:09:02 [1039] Symbol rate: 6899934
2010-11-03 18:09:02 [1039] Constellation: QAM256
2010-11-03 18:09:02 [1039] Mirroring: Mirrored
2010-11-03 18:09:03 [1039] Channel found (330000000)
2010-11-03 18:09:03 [1039] =============
2010-11-03 18:09:03 [1039] Symbol rate: 6899931
2010-11-03 18:09:03 [1039] Constellation: QAM256
2010-11-03 18:09:03 [1039] Mirroring: Mirrored
2010-11-03 18:09:04 [1039] Channel found (330000000)
2010-11-03 18:09:04 [1039] =============
2010-11-03 18:09:04 [1039] Symbol rate: 6899934
2010-11-03 18:09:04 [1039] Constellation: QAM256
2010-11-03 18:09:04 [1039] Mirroring: Mirrored
2010-11-03 18:09:06 [1039] Channel found (330000000)
2010-11-03 18:09:06 [1039] =============
2010-11-03 18:09:06 [1039] Symbol rate: 6899936
2010-11-03 18:09:06 [1039] Constellation: QAM256
2010-11-03 18:09:06 [1039] Mirroring: Mirrored
2010-11-03 18:11:20 [1039] Channel found (330000000)
2010-11-03 18:11:20 [1039] =============
2010-11-03 18:11:20 [1039] Symbol rate: 6899934
2010-11-03 18:11:20 [1039] Constellation: QAM256
2010-11-03 18:11:20 [1039] Mirroring: Mirrored
2010-11-03 18:11:20 [1039] Setting Frequency: 330000000
2010-11-03 18:11:20 [1039] Setting Symbolrate: 6900000
2010-11-03 18:11:20 [1039] Setting Modulation: 5
2010-11-03 18:11:20 [1039] Symbol rate: 6899933
2010-11-03 18:11:20 [1039] Symbol rate: 6899932
2010-11-03 18:11:21 [1039] Channel found (330000000)
2010-11-03 18:11:21 [1039] =============
2010-11-03 18:11:21 [1039] Symbol rate: 6899933
2010-11-03 18:11:21 [1039] Constellation: QAM256
2010-11-03 18:11:21 [1039] Mirroring: Mirrored
2010-11-03 18:11:22 [1039] Channel found (330000000)
2010-11-03 18:11:22 [1039] =============
2010-11-03 18:11:22 [1039] Symbol rate: 6899934
2010-11-03 18:11:22 [1039] Constellation: QAM256
2010-11-03 18:11:22 [1039] Mirroring: Mirrored
2010-11-03 18:11:23 [1039] Channel found (330000000)
2010-11-03 18:11:23 [1039] =============
2010-11-03 18:11:23 [1039] Symbol rate: 6899935
2010-11-03 18:11:23 [1039] Constellation: QAM256
2010-11-03 18:11:23 [1039] Mirroring: Mirrored
2010-11-03 18:11:24 [1039] Channel found (330000000)
2010-11-03 18:11:24 [1039] =============
2010-11-03 18:11:24 [1039] Symbol rate: 6899934
2010-11-03 18:11:24 [1039] Constellation: QAM256
2010-11-03 18:11:24 [1039] Mirroring: Mirrored
2010-11-03 18:11:24 [1039] Symbol rate: 6899935
2010-11-03 18:11:25 [1039] Channel found (330000000)
2010-11-03 18:11:25 [1039] =============
2010-11-03 18:11:25 [1039] Symbol rate: 6899934
2010-11-03 18:11:25 [1039] Constellation: QAM256
2010-11-03 18:11:25 [1039] Mirroring: Mirrored
2010-11-03 18:11:26 [1039] Channel found (330000000)
2010-11-03 18:11:26 [1039] =============
2010-11-03 18:11:26 [1039] Symbol rate: 6899935
2010-11-03 18:11:26 [1039] Constellation: QAM256
2010-11-03 18:11:26 [1039] Mirroring: Mirrored
2010-11-03 18:11:27 [1039] Channel found (330000000)
2010-11-03 18:11:27 [1039] =============
2010-11-03 18:11:27 [1039] Symbol rate: 6899935
2010-11-03 18:11:27 [1039] Constellation: QAM256
2010-11-03 18:11:27 [1039] Mirroring: Mirrored
2010-11-03 18:11:28 [1039] Channel found (330000000)
2010-11-03 18:11:28 [1039] =============
2010-11-03 18:11:28 [1039] Symbol rate: 6899935
2010-11-03 18:11:28 [1039] Constellation: QAM256
2010-11-03 18:11:28 [1039] Mirroring: Mirrored
2010-11-03 18:11:29 [1039] Channel found (330000000)
2010-11-03 18:11:29 [1039] =============
2010-11-03 18:11:29 [1039] Symbol rate: 6899933
2010-11-03 18:11:29 [1039] Constellation: QAM256
2010-11-03 18:11:29 [1039] Mirroring: Mirrored
2010-11-03 18:11:31 [1039] Channel found (330000000)
2010-11-03 18:11:31 [1039] =============
2010-11-03 18:11:31 [1039] Symbol rate: 6899935
2010-11-03 18:11:31 [1039] Constellation: QAM256
2010-11-03 18:11:31 [1039] Mirroring: Mirrored
2010-11-03 18:11:32 [1039] Channel found (330000000)
2010-11-03 18:11:32 [1039] =============
2010-11-03 18:11:32 [1039] Symbol rate: 6899934
2010-11-03 18:11:32 [1039] Constellation: QAM256
2010-11-03 18:11:32 [1039] Mirroring: Mirrored
2010-11-03 18:11:33 [1039] Channel found (330000000)
2010-11-03 18:11:33 [1039] =============
2010-11-03 18:11:33 [1039] Symbol rate: 6899934
2010-11-03 18:11:33 [1039] Constellation: QAM256
2010-11-03 18:11:33 [1039] Mirroring: Mirrored
2010-11-03 18:11:34 [1039] Channel found (330000000)
2010-11-03 18:11:34 [1039] =============
2010-11-03 18:11:34 [1039] Symbol rate: 6899935
2010-11-03 18:11:34 [1039] Constellation: QAM256
2010-11-03 18:11:34 [1039] Mirroring: Mirrored
2010-11-03 18:11:35 [1039] Channel found (330000000)
2010-11-03 18:11:35 [1039] =============
2010-11-03 18:11:35 [1039] Symbol rate: 6899934
2010-11-03 18:11:35 [1039] Constellation: QAM256
2010-11-03 18:11:35 [1039] Mirroring: Mirrored
2010-11-03 18:11:36 [1039] Channel found (330000000)
2010-11-03 18:11:36 [1039] =============
2010-11-03 18:11:36 [1039] Symbol rate: 6899934
2010-11-03 18:11:36 [1039] Constellation: QAM256
2010-11-03 18:11:36 [1039] Mirroring: Mirrored
2010-11-03 18:11:37 [1039] Channel found (330000000)
2010-11-03 18:11:37 [1039] =============
2010-11-03 18:11:37 [1039] Symbol rate: 6899934
2010-11-03 18:11:37 [1039] Constellation: QAM256
2010-11-03 18:11:37 [1039] Mirroring: Mirrored
2010-11-03 18:11:38 [1039] Channel found (330000000)
2010-11-03 18:11:38 [1039] =============
2010-11-03 18:11:38 [1039] Symbol rate: 6899935
2010-11-03 18:11:38 [1039] Constellation: QAM256
2010-11-03 18:11:38 [1039] Mirroring: Mirrored
2010-11-03 18:11:39 [1039] Channel found (330000000)
2010-11-03 18:11:39 [1039] =============
2010-11-03 18:11:39 [1039] Symbol rate: 6899934
2010-11-03 18:11:39 [1039] Constellation: QAM256
2010-11-03 18:11:39 [1039] Mirroring: Mirrored
2010-11-03 18:11:40 [1039] Channel found (330000000)
2010-11-03 18:11:40 [1039] =============
2010-11-03 18:11:40 [1039] Symbol rate: 6899933
2010-11-03 18:11:40 [1039] Constellation: QAM256
2010-11-03 18:11:40 [1039] Mirroring: Mirrored
2010-11-03 18:11:41 [1039] Channel found (330000000)
2010-11-03 18:11:41 [1039] =============
2010-11-03 18:11:41 [1039] Symbol rate: 6899934
2010-11-03 18:11:41 [1039] Constellation: QAM256
2010-11-03 18:11:41 [1039] Mirroring: Mirrored
2010-11-03 18:11:43 [1039] Channel found (330000000)
2010-11-03 18:11:43 [1039] =============
2010-11-03 18:11:43 [1039] Symbol rate: 6899936
2010-11-03 18:11:43 [1039] Constellation: QAM256
2010-11-03 18:11:43 [1039] Mirroring: Mirrored
2010-11-03 18:11:44 [1039] Channel found (330000000)
2010-11-03 18:11:44 [1039] =============
2010-11-03 18:11:44 [1039] Symbol rate: 6899934
2010-11-03 18:11:44 [1039] Constellation: QAM256
2010-11-03 18:11:44 [1039] Mirroring: Mirrored
2010-11-03 18:11:45 [1039] Channel found (330000000)
2010-11-03 18:11:45 [1039] =============
2010-11-03 18:11:45 [1039] Symbol rate: 6899935
2010-11-03 18:11:45 [1039] Constellation: QAM256
2010-11-03 18:11:45 [1039] Mirroring: Mirrored
2010-11-03 18:11:46 [1039] Channel found (330000000)
2010-11-03 18:11:46 [1039] =============
2010-11-03 18:11:46 [1039] Symbol rate: 6899935
2010-11-03 18:11:46 [1039] Constellation: QAM256
2010-11-03 18:11:46 [1039] Mirroring: Mirrored
2010-11-03 18:11:47 [1039] Channel found (330000000)
2010-11-03 18:11:47 [1039] =============
2010-11-03 18:11:47 [1039] Symbol rate: 6899935
2010-11-03 18:11:47 [1039] Constellation: QAM256
2010-11-03 18:11:47 [1039] Mirroring: Mirrored
2010-11-03 18:11:48 [1039] Channel found (330000000)
2010-11-03 18:11:48 [1039] =============
2010-11-03 18:11:48 [1039] Symbol rate: 6899936
2010-11-03 18:11:48 [1039] Constellation: QAM256
2010-11-03 18:11:48 [1039] Mirroring: Mirrored
2010-11-03 18:11:49 [1039] Channel found (330000000)
2010-11-03 18:11:49 [1039] =============
2010-11-03 18:11:49 [1039] Symbol rate: 6899936
2010-11-03 18:11:49 [1039] Constellation: QAM256
2010-11-03 18:11:49 [1039] Mirroring: Mirrored
2010-11-03 18:11:50 [1039] Channel found (330000000)
2010-11-03 18:11:50 [1039] =============
2010-11-03 18:11:50 [1039] Symbol rate: 6899935
2010-11-03 18:11:50 [1039] Constellation: QAM256
2010-11-03 18:11:50 [1039] Mirroring: Mirrored
2010-11-03 18:11:51 [1039] Channel found (330000000)
2010-11-03 18:11:51 [1039] =============
2010-11-03 18:11:51 [1039] Symbol rate: 6899934
2010-11-03 18:11:51 [1039] Constellation: QAM256
2010-11-03 18:11:51 [1039] Mirroring: Mirrored
2010-11-03 18:11:52 [1039] Channel found (330000000)
2010-11-03 18:11:52 [1039] =============
2010-11-03 18:11:52 [1039] Symbol rate: 6899934
2010-11-03 18:11:52 [1039] Constellation: QAM256
2010-11-03 18:11:52 [1039] Mirroring: Mirrored
2010-11-03 18:11:53 [1039] Channel found (330000000)
2010-11-03 18:11:53 [1039] =============
2010-11-03 18:11:53 [1039] Symbol rate: 6899936
2010-11-03 18:11:53 [1039] Constellation: QAM256
2010-11-03 18:11:53 [1039] Mirroring: Mirrored
2010-11-03 18:11:55 [1039] Channel found (330000000)
2010-11-03 18:11:55 [1039] =============
2010-11-03 18:11:55 [1039] Symbol rate: 6899935
2010-11-03 18:11:55 [1039] Constellation: QAM256
2010-11-03 18:11:55 [1039] Mirroring: Mirrored
2010-11-03 18:11:56 [1039] Channel found (330000000)
2010-11-03 18:11:56 [1039] =============
2010-11-03 18:11:56 [1039] Symbol rate: 6899933
2010-11-03 18:11:56 [1039] Constellation: QAM256
2010-11-03 18:11:56 [1039] Mirroring: Mirrored
2010-11-03 18:11:57 [1039] Channel found (330000000)
2010-11-03 18:11:57 [1039] =============
2010-11-03 18:11:57 [1039] Symbol rate: 6899935
2010-11-03 18:11:57 [1039] Constellation: QAM256
2010-11-03 18:11:57 [1039] Mirroring: Mirrored
2010-11-03 18:11:58 [1039] Channel found (330000000)
2010-11-03 18:11:58 [1039] =============
2010-11-03 18:11:58 [1039] Symbol rate: 6899935
2010-11-03 18:11:58 [1039] Constellation: QAM256
2010-11-03 18:11:58 [1039] Mirroring: Mirrored
2010-11-03 18:11:59 [1039] Channel found (330000000)
2010-11-03 18:11:59 [1039] =============
2010-11-03 18:11:59 [1039] Symbol rate: 6899934
2010-11-03 18:11:59 [1039] Constellation: QAM256
2010-11-03 18:11:59 [1039] Mirroring: Mirrored
2010-11-03 18:12:00 [1039] Channel found (330000000)
2010-11-03 18:12:00 [1039] =============
2010-11-03 18:12:00 [1039] Symbol rate: 6899935
2010-11-03 18:12:00 [1039] Constellation: QAM256
2010-11-03 18:12:00 [1039] Mirroring: Mirrored
2010-11-03 18:12:01 [1039] Channel found (330000000)
2010-11-03 18:12:01 [1039] =============
2010-11-03 18:12:01 [1039] Symbol rate: 6899935
2010-11-03 18:12:01 [1039] Constellation: QAM256
2010-11-03 18:12:01 [1039] Mirroring: Mirrored
2010-11-03 18:12:02 [1039] Channel found (330000000)
2010-11-03 18:12:02 [1039] =============
2010-11-03 18:12:02 [1039] Symbol rate: 6899935
2010-11-03 18:12:02 [1039] Constellation: QAM256
2010-11-03 18:12:02 [1039] Mirroring: Mirrored
2010-11-03 18:12:03 [1039] Channel found (330000000)
2010-11-03 18:12:03 [1039] =============
2010-11-03 18:12:03 [1039] Symbol rate: 6899936
2010-11-03 18:12:03 [1039] Constellation: QAM256
2010-11-03 18:12:03 [1039] Mirroring: Mirrored
2010-11-03 18:12:04 [1039] Channel found (330000000)
2010-11-03 18:12:04 [1039] =============
2010-11-03 18:12:04 [1039] Symbol rate: 6899933
2010-11-03 18:12:04 [1039] Constellation: QAM256
2010-11-03 18:12:04 [1039] Mirroring: Mirrored
2010-11-03 18:12:05 [1039] Channel found (330000000)
2010-11-03 18:12:05 [1039] =============
2010-11-03 18:12:05 [1039] Symbol rate: 6899936
2010-11-03 18:12:05 [1039] Constellation: QAM256
2010-11-03 18:12:05 [1039] Mirroring: Mirrored
2010-11-03 18:12:07 [1039] Channel found (330000000)
2010-11-03 18:12:07 [1039] =============
2010-11-03 18:12:07 [1039] Symbol rate: 6899935
2010-11-03 18:12:07 [1039] Constellation: QAM256
2010-11-03 18:12:07 [1039] Mirroring: Mirrored
2010-11-03 18:12:08 [1039] Channel found (330000000)
2010-11-03 18:12:08 [1039] =============
2010-11-03 18:12:08 [1039] Symbol rate: 6899934
2010-11-03 18:12:08 [1039] Constellation: QAM256
2010-11-03 18:12:08 [1039] Mirroring: Mirrored
2010-11-03 18:12:09 [1039] Channel found (330000000)
2010-11-03 18:12:09 [1039] =============
2010-11-03 18:12:09 [1039] Symbol rate: 6899935
2010-11-03 18:12:09 [1039] Constellation: QAM256
2010-11-03 18:12:09 [1039] Mirroring: Mirrored
2010-11-03 18:12:10 [1039] Channel found (330000000)
2010-11-03 18:12:10 [1039] =============
2010-11-03 18:12:10 [1039] Symbol rate: 6899935
2010-11-03 18:12:10 [1039] Constellation: QAM256
2010-11-03 18:12:10 [1039] Mirroring: Mirrored
2010-11-03 18:12:11 [1039] Channel found (330000000)
2010-11-03 18:12:11 [1039] =============
2010-11-03 18:12:11 [1039] Symbol rate: 6899934
2010-11-03 18:12:11 [1039] Constellation: QAM256
2010-11-03 18:12:11 [1039] Mirroring: Mirrored
2010-11-03 18:12:12 [1039] Channel found (330000000)
2010-11-03 18:12:12 [1039] =============
2010-11-03 18:12:12 [1039] Symbol rate: 6899935
2010-11-03 18:12:12 [1039] Constellation: QAM256
2010-11-03 18:12:12 [1039] Mirroring: Mirrored
2010-11-03 18:12:13 [1039] Channel found (330000000)
2010-11-03 18:12:13 [1039] =============
2010-11-03 18:12:13 [1039] Symbol rate: 6899935
2010-11-03 18:12:13 [1039] Constellation: QAM256
2010-11-03 18:12:13 [1039] Mirroring: Mirrored
2010-11-03 18:12:14 [1039] Channel found (330000000)
2010-11-03 18:12:14 [1039] =============
2010-11-03 18:12:14 [1039] Symbol rate: 6899934
2010-11-03 18:12:14 [1039] Constellation: QAM256
2010-11-03 18:12:14 [1039] Mirroring: Mirrored
2010-11-03 18:12:15 [1039] Channel found (330000000)
2010-11-03 18:12:15 [1039] =============
2010-11-03 18:12:15 [1039] Symbol rate: 6899933
2010-11-03 18:12:15 [1039] Constellation: QAM256
2010-11-03 18:12:15 [1039] Mirroring: Mirrored
2010-11-03 18:12:16 [1039] Channel found (330000000)
2010-11-03 18:12:16 [1039] =============
und der pipelog
[2010-11-03 18:09:02]    3901440 bytes |    3810.00 kb |       3.72 mb transferred
[2010-11-03 18:09:07]    1873920 bytes |    1830.00 kb |       1.79 mb transferred
[2010-11-03 18:09:12]    1792000 bytes |    1750.00 kb |       1.71 mb transferred
[2010-11-03 18:09:17]    1781760 bytes |    1740.00 kb |       1.70 mb transferred
[2010-11-03 18:09:22]    1996800 bytes |    1950.00 kb |       1.90 mb transferred
[2010-11-03 18:09:27]    1853440 bytes |    1810.00 kb |       1.77 mb transferred
[2010-11-03 18:09:32]    1802240 bytes |    1760.00 kb |       1.72 mb transferred
[2010-11-03 18:09:37]    1802240 bytes |    1760.00 kb |       1.72 mb transferred
[2010-11-03 18:09:42]    1843200 bytes |    1800.00 kb |       1.76 mb transferred
[2010-11-03 18:09:47]    2682880 bytes |    2620.00 kb |       2.56 mb transferred
[2010-11-03 18:09:52]    3266560 bytes |    3190.00 kb |       3.12 mb transferred
[2010-11-03 18:09:57]    2508800 bytes |    2450.00 kb |       2.39 mb transferred
[2010-11-03 18:11:22]   18554880 bytes |   18120.00 kb |      17.70 mb transferred
[2010-11-03 18:11:27]    1863680 bytes |    1820.00 kb |       1.78 mb transferred
Edit:
mediasrv --build
Build date: Nov  2 2010
mediaclient --build
« Letzte Änderung: November 03, 2010, 07:41:56 Nachmittag von sundown »
« Antwort #32 am: November 03, 2010, 08:23:34 Nachmittag »
Der Entwicklungstreiber vom 1. ist nicht wirklich stabil.
Bitte zumindestens den Treiber vom 2. November verwenden.
(in beiden Faellen handelt es sich um Entwicklungstreiber, die naechste stable Release ist in 1-2 Wochen geplant).
Die angegebenen haenger konnten wir mit 2 Geraeten nachvollziehen und wurden nachgebessert.
Wir haben VDR nun auch auf einem dedizierten Rechner laufen und machen damit Langzeittests.
« Letzte Änderung: November 04, 2010, 08:40:45 Vormittag von Sundtek »
« Antwort #33 am: November 04, 2010, 01:20:25 Vormittag »
Nocheinmal nachgehakt das Problem wurde jetzt soweit verstanden. Je mehr Geraete im VDR haengen desto einfacher kann es auftreten - der Treiber wurde soweit bereits aktualisiert. Die letzten Updates gingen bereits in die richtige Richtung.
Derzeitiger Entwicklungstreiber ist vom 4. November 2010
Aktuell konnten wir eine VDR Restartsituation nachvollziehen.
Tuner A nimmt auf, Tuner B arbeitet auf einem Transponder wo kein Signal (mehr?) vorhanden ist.
Diese Situation kann man jedoch ueber die Logfile ausfindig machen.
syslog:
Nov  4 04:34:39 ubuntu vdr: [14680] frontend 1/0 timed out while tuning to channel 261, tp 458
Nov  4 04:35:01 ubuntu vdr: [14726] ERROR: video data stream broken
Nov  4 04:35:01 ubuntu vdr: [14726] initiating emergency exit
mediasrv.log:
2010-10-27 10:34:06 [4271] Setting Frequency: 458000000
2010-10-27 10:34:06 [4271] Setting Symbolrate: 6900000
2010-10-27 10:34:06 [4271] Setting Modulation: 3
2010-10-27 10:34:07 [4271] Channel found (113000000)
458 Mhz wurde in der mediasrv.log aber nie mit "Channel found" hinterlegt.
$ /opt/bin/mediaclient -m DVBC -f 458000000 -S 6900000 -M Q64
(auf beiden Tuner Modulen konnte hierbei kein Sender gefunden werden).
Nach dem Umschalten auf eine gueltige Frequenz hatte es soweit wieder funktioniert, vdr hing bei dieser Situation nicht - er war durchaus bedienbar jedoch ist der timeout bezueglich des nicht vorhandenen Videos angesprungen.
Die urspruenglichen Situationen das VDR komplett haengt sollte soweit mit der aktuellen Version vom 4. November geloest sein. Wir werden uns die Situation mit ungueltigen Frequenzen noch etwas genauer ansehen- insbesondere ob das mit anderen Karten anders gehandelt wird. Bei einer korrekten Scanliste sollte dies ohnehin nicht auftreten.
Diese Situation wurde soweit abgeklaert und es tritt auf sobald man von einem Transponder aufnehmen will welcher keine Daten liefert (z.B Gewitter bei DVB-S oder Ausfall eines Transponders bei DVB-C -- so wie wir dies nun bei KabelDeutschland hatten).
Zusammengefasst dies sehen wir soweit noch nicht als Problem, die oben von den anderen Anwendern angefuehrten Probleme sollten aber nicht mehr auftreten.
« Letzte Änderung: November 04, 2010, 10:51:25 Vormittag von Sundtek »
Muschimann
« Antwort #34 am: November 06, 2010, 08:32:11 Vormittag »
Hab eben mal den Server gecheckt - kein Absturz, alle 37 Aufnahmen der letzten 3 Tage perfekt aufgezeichnet.
Scheint jetzt wirklich alles Tutti zu sein. Danke Jungs.  ;D
Muschimann
« Antwort #35 am: November 27, 2010, 11:24:36 Vormittag »
Hallöle, ich nochmal. :)
Also nach einem ausführlichen Langzeittest mit knapp 200 Aufnahmen ist mir der VDR 2x abgeraucht, allerdings hatte ich auch noch den "gefährlichen" Treiber vom 1.11. drauf, der stabil lief wie bis dahin kein anderer. ;)
Ich habe eben mak ein Upgrade auf 18.11. gemacht und qwerde die Situation weiter beobachten, allerdings werde ich nicht mehr jeden Scheiß aufnehmen. Jetzt muß ich erstmal die Platte von dem ganzen sinnlosen Zeug befreien. ;)
Bis die Tage...
