Autor Thema: Dreambox TWO, sundtek media tv pro iii driver don´t start in OpenATV 8  (Gelesen 856 mal)
Magog
Hello, now that OpenATV is wortking really great with the TWO... i have a problem that didn´t matter before because it was unusable.
After every system restart driver won´t load and i must go to Sundtek control center, press Blue (say no to reinstall driver) and then restart Enigma2.
It works ok after that.
Thanks.
Magog
Re: Dreambox TWO, sundtek media tv pro iii driver don´t start in OpenATV 8
« Antwort #1 am: Juni 13, 2026, 10:51:35 Vormittag »
After reboot:
root@dreamtwo:~# /opt/bin/mediaclient -e
device 0: [MediaTV Digital Home III (EU)]  DVB-C, DVB-T, DVB-T2
  [DVB-C,DVB-T,DVB-T2]:
root@dreamtwo:~# cat /proc/bus/nim_sockets
NIM Socket 0:
        Input_Name: A1
        Type: DVB-S2
        Has_Outputs: no
        Frontend_Device: 0
        I2C_Device: 2
NIM Socket 1:
        Input_Name: A2
        Type: DVB-S2
        Has_Outputs: no
        Frontend_Device: 1
        I2C_Device: 2
NIM Socket 2:
        Type: DVB-T2
        Name: Sundtek DVB-T2 (III) (1/0) (USB
        Has_Outputs: no
        Frontend_Device: 2
root@dreamtwo:~#
After Control center action:
     STATUS: ACTIVE
NIM Socket 0:
        Input_Name: A1
        Type: DVB-S2
        Has_Outputs: no
        Frontend_Device: 0
        I2C_Device: 2
NIM Socket 1:
        Input_Name: A2
        Type: DVB-S2
        Has_Outputs: no
        Frontend_Device: 1
        I2C_Device: 2
NIM Socket 2:
        Type: DVB-T2
        Has_Outputs: no
        Frontend_Device: 2
root@dreamtwo:~#
So the tunner starts but standby, don´t now if it can be fixed...
Thanks.
« Letzte Änderung: Juni 13, 2026, 10:54:32 Vormittag von Magog »
Magog
« Antwort #2 am: Juni 13, 2026, 11:38:30 Vormittag »
Upps , sorry ... even a simple interface reboot takes out the tunner from standby.
« Antwort #3 am: Juni 13, 2026, 03:18:22 Nachmittag »
Did you enable autostart?
The standby is normal if the tuner is idle it will go into standby.
Magog
« Antwort #4 am: Juni 13, 2026, 10:23:13 Nachmittag »
Sure.
Autostart - yes.
It starts ok with Dreamos.
Thanks.
« Letzte Änderung: Juni 13, 2026, 10:40:00 Nachmittag von Magog »
« Antwort #5 am: Juni 14, 2026, 03:00:35 Vormittag »
So your problem is fixed?
Magog
« Antwort #6 am: Juni 14, 2026, 11:12:54 Vormittag »
Hello, no... i´m saying that it starts ok under the original OS of the machine (opendreambox 2.6) but under OpeanATV it starts in standby mode... running multiboot.
Thanks.
« Letzte Änderung: Juni 14, 2026, 11:15:56 Vormittag von Magog »
« Antwort #7 am: Juni 14, 2026, 11:39:45 Vormittag »
Ok that is no problem it's just the behavior of Enigma2. The tuner will leave standby once Enigma2 opens the device. Everything absolutely normal.
Anyway thanks for the feedback :-) We just reworked DVB-T2 support for the Dreambox 2.
Magog
« Antwort #8 am: Juni 14, 2026, 12:08:44 Nachmittag »
But that is the problem... it doesn´t leave standby mode.
If i change to a DTT channel... nothing. A simple GUI restart and it runs ok.
Thanks.
« Antwort #9 am: Juni 14, 2026, 01:55:58 Nachmittag »
This is not a problem of the driver itself, maybe the startup routine has changed in OpenATV 8 and enigma2 starts earlier than the driver.
Standby itself is not the problem.
Can you provide remote access to the settopbox so I can check? Eg. via RustDesk?
We have a support chat too:
https://discord.gg/AR5QJhyNnw
« Letzte Änderung: Juni 14, 2026, 04:09:31 Nachmittag von Sundtek »
Magog
« Antwort #10 am: Juni 15, 2026, 01:02:14 Nachmittag »
Sure, i'll contact when i have enought time for you to test...
I hope this evening.
Thanks.
« Antwort #11 am: Juli 03, 2026, 08:20:32 Nachmittag »
The problem is solved.
