Autor Thema: Aufnahmen von Composite und Line  (Gelesen 14151 mal)
leoguiders
« am: November 07, 2024, 04:13:27 Nachmittag »
ich versuche mit dem MediaTV Pro III und ffmpeg/DirectShow Videokassetten unter Windows 11 zu digitalisieren.
ffmpeg -list_devices true -f dshow -i dummy
Zeigt alles an was ich brauche:
[dshow @ 000002a56de17380] "Sundtek Video Capture" (audio, video)
[dshow @ 000002a56de17380]   Alternative name "@device_pnp_\\?\usb#vid_2659&pid_1210&mi_01#6&7df4f7a&1&0001#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4}"
Und dazu ffplay -f dshow -list_options true -i video="Sundtek Video Capture"
zeigt
[dshow @ 000001da302d6580] DirectShow video device options (from video devices)
[dshow @ 000001da302d6580]  Pin "Capture" (alternative pin name "2")
[dshow @ 000001da302d6580]   pixel_format=uyvy422  min s=88x72 fps=25 max s=720x576 fps=25
[dshow @ 000001da302d6580]   pixel_format=uyvy422  min s=80x60 fps=29.97 max s=720x480 fps=29.97
[dshow @ 000001da302d6580]   pixel_format=gray  min s=88x72 fps=25 max s=720x576 fps=25
[dshow @ 000001da302d6580]   pixel_format=uyvy422  min s=80x60 fps=29.97 max s=360x240 fps=29.97
[dshow @ 000001da302d6580]   pixel_format=gray  min s=80x60 fps=29.97 max s=360x240 fps=29.97
[dshow @ 000001da302d6580]   pixel_format=uyvy422  min s=88x72 fps=25 max s=360x288 fps=25
[dshow @ 000001da302d6580]   pixel_format=gray  min s=88x72 fps=25 max s=360x288 fps=25
[dshow @ 000001da302d6580]  Pin "Audio Out" (alternative pin name "3")
[dshow @ 000001da302d6580] Crossbar Switching Information for Sundtek Video Capture:
[dshow @ 000001da302d6580]   Crossbar Output pin 0: "Video Decoder" related output pin: 1 current input pin: 1 compatible input pins: 0 1 2 5
[dshow @ 000001da302d6580]   Crossbar Output pin 1: "Audio Decoder" related output pin: 0 current input pin: 4 compatible input pins: 3 4
[dshow @ 000001da302d6580]   Crossbar Input pin 0 - "Video Tuner" related input pin: 3
[dshow @ 000001da302d6580]   Crossbar Input pin 1 - "Video Composite" related input pin: 4
[dshow @ 000001da302d6580]   Crossbar Input pin 2 - "S-Video" related input pin: 4
[dshow @ 000001da302d6580]   Crossbar Input pin 3 - "Audio Tuner" related input pin: 0
[dshow @ 000001da302d6580]   Crossbar Input pin 4 - "Audio Line" related input pin: 1
[dshow @ 000001da302d6580]   Crossbar Input pin 5 - "Video YRYBY" related input pin: 4
Bild bekomm ich damit auch wunderbar, allerdings habe ich auf der Tonspur nur elektronisches Geraschel und Gepiepse.
Habe mal eine Beispieldatei angehängt (ja, die hat kein Bildinhalt weil ich keine Quelle angeschlossen hatte, das ist so richtig).
Hat jemand eine Idee, ich komme da mit ffmpeg nicht weiter. Leider hat der Laptop mit dem ich aufnehme auch keinen Line-In sonst würde ich das einfach dort einstecken.
Verwende den Treiber 2016-07-13 für die MTV Pro 3.
Re: Aufnahmen von Composite und Line
« Antwort #1 am: November 15, 2024, 04:56:00 Vormittag »
um einen neuen Treiber bereitstellen zu können benötigen wir einen Microsoft Developer Account um einen signierten Treiber bereitstellen zu können, Microsoft's Zugansgsystem ist leider defekt wir müssen abwarten bis die das gelöst haben. Es betrifft zur Zeit auch viele andere Entwickler. Wir sind an diesem Thema aktiv dran (seit nahezu 3 Monaten, es geht leider nur schrittweise vorwärts bei Microsoft...)
Ein gültiges EV Zertifikat haben wir seit einer geraumen Zeit, aber das System bei Microsoft hat sich verändert sodass Microsoft die Treiber nun direkt signiert und unser EV Zertifikat nur noch quasi als Eintrittskarte für die Registrierung des Developer Accounts genutzt wird.
Dauert also leider noch etwas, wir aktualisieren das hier sobald Microsoft die Fehler im Zugangsportal behoben hat.
« Letzte Änderung: November 15, 2024, 12:33:37 Nachmittag von Sundtek »
