Autor Thema: Kaffeine Ubuntu / Linux Mate (2024)  (Gelesen 40330 mal)
« am: Oktober 08, 2024, 01:30:36 Vormittag »
Kaffeine benötigt einen Patch um die Tuner aktuell zu erkennen, wir haben ein aktuelles Ubuntu / Mint Paket zusammengestellt:
https://sundtek.com/wiki/index.php?title=Driver_Installation#Kaffeine
Informationen zum Patch findet man ebenfalls im Wiki.
rvi
Re: Kaffeine Ubuntu / Linux Mate (2024)
« Antwort #1 am: November 27, 2024, 10:50:28 Vormittag »
@Markus,
Habe natürlich sofort versucht das Paket zu installieren; leider geht das nicht :
apt install ./kaffeine_2.0.18+git20230226.439cd0d-1build2_amd64.deb
gibt :
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'kaffeine' instead of './kaffeine_2.0.18+git20230226.439cd0d-1build2_amd64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies.
 kaffeine : Depends: libc6 (>= 2.38) but 2.23-0ubuntu11.3 is to be installed
            Depends: libdvbv5-0t64 (>= 1.12.1) but it is not installable
            Depends: libkf5widgetsaddons5 (>= 5.100.0) but 5.18.0-0ubuntu1 is to be installed
            Depends: libkf5windowsystem5 (>= 5.91.0) but 5.18.0-0ubuntu1 is to be installed
            Depends: libqt5core5t64 (>= 5.15.1) but it is not installable
            Depends: libqt5dbus5t64 (>= 5.14.1) but it is not installable
            Depends: libqt5gui5t64 (>= 5.14.1) but it is not installable or
                     libqt5gui5-gles (>= 5.14.1) but it is not going to be installed
            Depends: libqt5sql5t64 (>= 5.4.0) but it is not installable
            Depends: libqt5widgets5t64 (>= 5.11.0~rc1) but it is not installable
            Depends: libqt5x11extras5 (>= 5.6.0) but 5.5.1-3build1 is to be installed
            Depends: libqt5xml5t64 (>= 5.4.0) but it is not installable
            Depends: libstdc++6 (>= 13.1) but 5.4.0-6ubuntu1~16.04.12 is to be installed
            Depends: libvlc5 (>= 3.0.0) but 2.2.2-5ubuntu0.16.04.4 is to be installed
            Depends: vlc-plugin-base but it is not installable
            Depends: vlc-plugin-video-output but it is not installable
E: Unable to correct problems, you have held broken packages.
Was mache Ich falsch ?
« Antwort #2 am: November 28, 2024, 01:01:17 Nachmittag »
Welche Ubutnu Version ist das? Wir haben es für Ubuntu Noble gebaut, für ältere Ubuntu Versionen müsstest Du es selber bauen
apt-get source kaffeine
cd kaffeine [tab drücken]
wget http://sundtek.de/support/kaffeine-2.0.18_support_sundtek_devices.diff
patch -p1 < kaffeine-2.0.18_support_sundtek_devices.diff
« Letzte Änderung: November 29, 2024, 07:03:49 Nachmittag von Sundtek »
rvi
« Antwort #3 am: November 30, 2024, 06:28:45 Nachmittag »
Linux Mint 18.3
« Antwort #4 am: Dezember 09, 2024, 01:24:09 Nachmittag »
Das ist schon ein bißchen älter, kannst Du uns eventuell Remote Zugang geben auf das System, z.B mit RustDesk? Dann können wir dafür ein einfaches Skript vorbereiten.
Schaue eventuell im Discord Chat vorbei.
« Letzte Änderung: Dezember 09, 2024, 01:42:36 Nachmittag von Sundtek »
rvi
« Antwort #5 am: Dezember 09, 2024, 02:57:28 Nachmittag »
Rustdesk kenne Ich nicht ? Sie haben früher mal ein anderes System benutzt, Ich glaube Anydesk ?
Irgendwann muß Ich ein Upgrade auf mein NUC machen - an sich kein Problem, nur Arbeit.
Leider aber sind die Zeiten vorbei daß Linux auf wenig leistungsstarke hardware installiert werden könnte : Ubuntu 24 (Noble) brauch mindestens 4 Gb RAM ... also vermute Ich daß Mint 22 (daß auf die Ubuntu 24 ¨Package Base¨ basiert ist) auch 4 Gb braucht ..... Für das Intel NUC kein Problem, aber :
Hatte eigentlich vor um in Zukunft RPI 3B+ als TV client zu benutzen : mit 1Gb RAM wird daß wohl nicht funktionieren ....
« Antwort #6 am: Dezember 09, 2024, 05:19:40 Nachmittag »
rustDesk ist eine kostenlose Remote Version welche auch ständig aktualisiert wird.
« Antwort #7 am: Dezember 30, 2024, 03:26:31 Vormittag »
Hier noch eine Alternative für Kaffeine:
sudo -s
cd
wget http://sundtek.de/support/ubuntukaffeine.sh
chmod 777 ubuntukaffeine.sh
./ubuntukaffeine.sh
« Letzte Änderung: März 06, 2025, 05:51:43 Vormittag von Sundtek »
« Antwort #8 am: März 06, 2025, 05:10:39 Vormittag »
Das Skript wurde aktualisiert, ein nicht so offensichtlicher Bug wurde behoben.
« Letzte Änderung: März 09, 2025, 06:35:25 Nachmittag von Sundtek »
