Autor Thema: Tvheadend QAM256  (Gelesen 41319 mal)
ehfred10
Tvheadend QAM256
« am: Februar 07, 2021, 08:38:22 Vormittag »
Still in my new setup, copying the muxes configuration from my old setup (which is still runing perfectly).
When I set a muxes with this setup (I'm from belgium):
Freq : 314000000
Sym : 6875000
Const : QAM/256
I have no services to map.
I tried to enable logs and seen this:
2021-02-07 07:34:26 [340] Setting Frequency: 314000000
2021-02-07 07:34:26 [340] Setting Symbolrate: 6875000
2021-02-07 07:34:26 [340] Setting Modulation: 5
2021-02-07 07:34:26 [340] re-writing symbolrate to 6900KSym (please report if it causes problems!)
2021-02-07 07:34:26 [340] setting symbolrate: 6875
2021-02-07 07:34:26 [340] Tuning DVB-C Frequency: 314000000
2021-02-07 07:34:26 [340] Frontend has locked
2021-02-07 07:34:31 [340] Setting Frequency: 118500000
2021-02-07 07:34:31 [340] Setting Symbolrate: 6875000
2021-02-07 07:34:31 [340] Setting Modulation: 5
2021-02-07 07:34:31 [340] re-writing symbolrate to 6900KSym (please report if it causes problems!)
2021-02-07 07:34:31 [340] setting symbolrate: 6875
2021-02-07 07:34:31 [340] Tuning DVB-C Frequency: 118500000
2021-02-07 07:34:32 [340] Frontend has locked
Result of /opt/bin/mediaclient --readsignal=0 -d /dev/dvb/adapter0/frontend0:
SIGNAL: [...............................  ] ( 95%) BER:      0 CNR: 35.20 FREQ: 118500000  Hz LOCKED: YES SYM: 6875000 MOD: QAM256
SIGNAL: [...............................  ] ( 95%) BER:      0 CNR: 35.50 FREQ: 118500000  Hz LOCKED: YES SYM: 6875000 MOD: QAM256
The QAM64 are working normaly.
Have an idea?
Thank you
Re: Tvheadend QAM256
« Antwort #1 am: Februar 07, 2021, 09:51:14 Vormittag »
Which System do you use?
Which Tuner do you use? I think that's a MediaTV Pro or Digital Home from before 2014?
What do following commands show up when tvheadend is not started (and when nothing is connected in /opt/bin/mediaclient --lc)
/opt/bin/mediaclient -m DVBC -f 314000000 -S 6875000 -M Q256
ehfred10
« Antwort #2 am: Februar 07, 2021, 11:01:58 Vormittag »
I'm running under Unraid
Tvheadend as a docker container
It's correct, it's a MediaTV Pro older than 2014
root@55da84545884:/# /config/opt/bin/mediaclient -m DVBC -f 314000000 -S 6875000 -M Q256
root@55da84545884:/# /config/opt/bin/mediaclient --tsscan /dev/dvb/adapter0/dvr0
media scan tp: 0
Timed out after 1 seconds
Scan finished after 2 packets (376 bytes)
« Antwort #3 am: Februar 07, 2021, 11:28:11 Vormittag »
What does lsusb -v show up? I guess the device is set to the wrong device mode (a device mode which is not supported by that system) however the old devices are configurable.
QAM256 is not the problem here for sure.
« Letzte Änderung: Februar 07, 2021, 12:36:18 Nachmittag von Sundtek »
ehfred10
« Antwort #4 am: Februar 07, 2021, 01:07:27 Nachmittag »
Not really relevant:
root@55da84545884:/#  lsusb -v
Bus 004 Device 002: ID 174c:3074
Bus 003 Device 001: ID 1d6b:0002
Bus 001 Device 002: ID 05e3:0610
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 004: ID 2659:1401
Bus 003 Device 002: ID 174c:2074
Bus 004 Device 001: ID 1d6b:0003
Bus 001 Device 003: ID 26ce:01a2
Bus 002 Device 001: ID 1d6b:0003
Bus 004 Device 003: ID 0781:5583
Bus 003 Device 004: ID 0a12:0001
« Antwort #5 am: Februar 07, 2021, 02:37:29 Nachmittag »
that is an embedded version of lsusb but not the real one.
maybe you can get the lsusb output from a normal linux PC?
ehfred10
« Antwort #6 am: Februar 10, 2021, 08:49:15 Nachmittag »
NVM, I made a mistake in my configuration...
Anyway, does a TV Adapter can have a specific configuration applied?
On TVH, I got continuity error only with one adapter. I know that I made a lot of configuration test wile installing the docker, so I'm wondering if I could change something by mistake?
Thank you for your help
« Antwort #7 am: Februar 10, 2021, 08:52:27 Nachmittag »
I don't really know which device that is from before 2014, but you can check the signal strength with following command:
Continuity Errors with old tuners (possible causes):
- Signal Problem on the Antenna
- Performance of the system is throttled too much (check current CPU settings).
- Hardware Problem
ehfred10
« Antwort #8 am: Februar 10, 2021, 09:08:43 Nachmittag »
I don't think I have signal problem:
SIGNAL: [.................................] ( 99%) BER:      0 CNR: 36.50 FREQ: 418000000  Hz LOCKED: YES SYM: 6875000 MOD: QAM256
SIGNAL: [.................................] ( 99%) BER:      0 CNR: 36.20 FREQ: 418000000  Hz LOCKED: YES SYM: 6875000 MOD: QAM256
It's a new computer (Rizen 5 3600 16Go RAM, SSD)
Do you think a new tv adapter will work better?
« Antwort #9 am: Februar 11, 2021, 03:50:34 Vormittag »
Try /opt/bin/mediaclient --transfermode=bulk -d /dev/dvb/adapter0/frontend0
and reconnect the device.
not sure if that will help since you did not show me the proper lsusb -v output (the embedded lsusb version doesn't seem to support the -v flag)
The old tuners should be okay but they need twice the power as the new tuners.
« Letzte Änderung: Februar 11, 2021, 07:46:46 Vormittag von Sundtek »
ehfred10
« Antwort #10 am: Februar 11, 2021, 10:12:13 Vormittag »
Ok I'll try the command this evening :)
This is the output of lsusb -v (only concerning the sundtek)
Bus 001 Device 003: ID 2659:1401 Sundtek MediaTV Digital Home III (EU)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x2659 Sundtek
  idProduct          0x1401
  bcdDevice           40.01
  iManufacturer           1 Sundtek
  iProduct                2 MediaTV Digital Home III (EU)
  iSerial                 3 U150106134613
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0158
    bNumInterfaces          7
    bConfigurationValue     1
    iConfiguration          4 MediaTV Digital Home III (EU)
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              500mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol    255 Vendor Specific Protocol
      iInterface             32 MediaTV Digital Home III (EU)
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x8e  EP 14 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0020  1x 32 bytes
        bInterval               4
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x0e  EP 14 OUT
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               4
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         1
      bInterfaceCount         6
      bFunctionClass        255 Vendor Specific Class
      bFunctionSubClass     255 Vendor Specific Subclass
      bFunctionProtocol     255 Vendor Specific Protocol
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              7 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x8f  EP 15 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval               7
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              8 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              9 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Transfer Type            Isochronous
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface             10 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0080  1x 128 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface             11 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x013c  1x 316 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       4
      bNumEndpoints           1
      iInterface             12 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x02c8  1x 712 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       5
      bNumEndpoints           1
      iInterface             13 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0ac8  2x 712 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface             20 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface             21 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x001c  1x 28 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface             22 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0034  1x 52 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface             23 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface             24 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x00b8  1x 184 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface             25 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x02d8  1x 728 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface             26 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x13c4  3x 964 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       4
      bNumEndpoints           1
      iInterface             27 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0b84  2x 900 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        5
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface             28 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x85  EP 5 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        5
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface             31 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x05  EP 5 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        6
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface             29 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x86  EP 6 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        6
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface             30 MediaTV Digital Home III (EU)
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0240  1x 576 bytes
        bInterval               1
Bus 001 Device 002: ID 2659:1401 Sundtek MediaTV Digital Home III (EU)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         2
  bMaxPacketSize0        64
  idProduct          0x1401
  bcdDevice           40.01
  iSerial                 3 U150106134556
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0158
    bNumInterfaces          7
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               4
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               4
      bLength                 8
      bDescriptorType        11
      bFirstInterface         1
      bInterfaceCount         6
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               7
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       2
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       3
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       4
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       5
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       1
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       2
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       1
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       2
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       3
      bNumEndpoints           1
        bLength        &
« Letzte Änderung: Februar 11, 2021, 11:10:15 Vormittag von Sundtek »
« Antwort #11 am: Februar 11, 2021, 11:11:52 Vormittag »
https://support.sundtek.com/index.php?topic=2474.msg19536#msg19536
try those commands again after switching back to bulk, you might also join the chat so we can check it together.
