Autor Thema: Sundtek docker unraid  (Gelesen 27670 mal)
ehfred10
« am: Februar 04, 2021, 01:02:41 Nachmittag »
Hello,
I'm running under unraid OS with tvheadend docker.
I've tried to follow the wiki (https://sundtek.de/wiki/index.php?title=Docker) without any success.
I've noticed an error in logs:
[ ERROR] linuxdvb: unable to open /dev/dvb/adapter0/frontend0
Any kind of help would be greatly appreciated
Thank you,
Re: Sundtek docker unraid
« Antwort #1 am: Februar 04, 2021, 07:59:05 Nachmittag »
You will have to create the device nodes on the host before creating the docker, the documentation in the wiki is referring to Docker on a Synology NAS.
The nodes need to exist before you create and start a docker image because docker needs this to know which devices it should allow.
mkdir -p /dev/dvb/adapter0
mkdir -p /dev/dvb/adapter1
mknod /dev/dvb/adapter1/frontend0 c 212 7
mknod /dev/dvb/adapter1/dvr0 c 212 11
mknod /dev/dvb/adapter1/demux0 c 212 9
mkdir -p /dev/dvb/adapter2
mknod /dev/dvb/adapter2/frontend0 c 212 13
mknod /dev/dvb/adapter2/dvr0 c 212 17
mknod /dev/dvb/adapter2/demux0 c 212 15
so that was for the host, now in docker you have to install the driver like we've written in the wiki documentation.
ehfred10
« Antwort #2 am: Februar 04, 2021, 08:01:18 Nachmittag »
Ok, thanks for your quick reply.
Do I have to run the setup on the host?
« Antwort #3 am: Februar 04, 2021, 08:09:00 Nachmittag »
I have updated the documentation a bit, yes the mknod commands have to be started on the native host (please read the updated documentation in the wiki). If something's unclear let me know so we can update it again.
I added some documentation about unraid
https://sundtek.com/wiki/index.php?title=Docker#Unraid
If there are any further issues just let us know.
« Letzte Änderung: November 01, 2022, 01:52:41 Nachmittag von Sundtek »
ehfred10
« Antwort #4 am: Februar 04, 2021, 09:24:00 Nachmittag »
Now the adapter is correctly configured and works like a charm...
Thank you for your help and the update of the wiki :)
