Autor Thema: Kein Ton - PulseAudio Fehler  (Gelesen 13887 mal)
CyberP
« am: Februar 03, 2014, 11:22:32 Nachmittag »
ich bin seit letzter Woche Besitzer eines neuen MediaTV Pro III.
Installation war problemlos. Ich hab Bild über DVB-T und Sender über FM, aber leider keinen Ton.
Es scheint Fehler mit PulseAudio zu geben. Generell funktioniert die Audioausgabe aber auf meinem System.
Auszug aus den Logs mediasrv.log
2014-02-02 15:48:05 [381] Starting up Multimedia Framework (Feb  1 2014 09:40:36)
2014-02-02 15:48:05 [382] Starting service processor (PID 382)
2014-02-02 15:48:05 [381] Detected DVB version.h
2014-02-02 15:48:05 [381] API Version: 5.10
2014-02-02 15:48:05 [381] Running on Linux (3.12.9-2-ARCH)
2014-02-02 15:48:05 [381] Detected: GenuineIntel
2014-02-02 15:48:05 [381] This CPU supports: MMX, SSE, SSE2
2014-02-02 15:48:05 [381] unable to open /dev/misc
2014-02-02 15:48:05 [381] scanning devices
2014-02-02 15:48:05 [381] Scanning for drivers
2014-02-02 15:48:05 [381] found lib: libdrv_em28xx.so
2014-02-02 15:48:05 [381] found lib: libdrv_fm.so
2014-02-02 15:48:05 [381] found lib: libdrv_ngTV.so
2014-02-02 15:48:05 [381] found lib: libdrv_net.so
2014-02-02 15:48:05 [381] found lib: libdrv_hikarisoft_isdb.so
2014-02-02 15:48:05 [381] found lib: libdrv_tntdvb.so
2014-02-02 15:48:05 [381] found lib: libdrv_vivi.so
2014-02-02 15:48:05 [381] Scanning for plugins
2014-02-02 15:48:05 [381] found lib: libencoder_plugin.so
2014-02-02 15:48:05 [381] MediaAVPlugin: MPEG Encoder
2014-02-02 15:48:05 [381] Copyright: (C) Tpe 2011/2012
2014-02-02 15:48:05 [381] Starting up device manager
2014-02-02 15:48:06 [381] scanning devices done
2014-02-02 15:48:06 [381] attached devices:
2014-02-02 15:48:06 [382] Autostarting scripts in /etc/sundtek/
2014-02-02 15:48:06 [382] executed all available items
2014-02-02 15:48:06 [381] registering ID: 0
2014-02-02 15:48:06 [381] Using dynamic configuration
2014-02-02 15:48:06 [381] DTV1 Transfer is set to: Bulk
2014-02-02 15:48:06 [381] Using VCR remote control layout
2014-02-02 15:48:06 [381] Allocation using pg for type 65678
2014-02-02 15:48:06 [381] attaching DVB-T, DVB-C, DVB-T2
2014-02-02 15:48:06 [381] demodulator successfully attached (DVB-C)!
2014-02-02 15:48:07 [469] RC: IR Event /dev/input/event15
2014-02-02 15:48:07 [381] This device uses the third generation Tuner
2014-02-02 15:48:07 [381] Power up demodulator
2014-02-02 15:48:07 [479] RC: IR Event /dev/input/event15
2014-02-02 15:48:17 [381] Allocation using pg for type 16
2014-02-02 15:48:17 [381] attaching video decoder
2014-02-02 15:48:17 [381] SETTING PAL/SECAM
2014-02-02 15:48:17 [381] Setting frequency: 245250000
2014-02-02 15:48:17 [381] Setting analogTV Parameters
2014-02-02 15:48:17 [381] Setting PAL-B
2014-02-02 15:48:17 [381] attaching radio module
2014-02-02 15:48:18 [381] configure urbs for bulk
2014-02-02 15:48:18 [381] Registering OSS emulation
2014-02-02 15:48:18 [381] registering: adapter0/0
2014-02-02 15:48:18 [381] registered virtual: /dev/dvb/adapter0/frontend0
2014-02-02 15:48:18 [381] registered virtual: /dev/dvb/adapter0/demux0
2014-02-02 15:48:18 [381] registered virtual: /dev/dvb/adapter0/dvr0
2014-02-02 15:48:18 [381] registered virtual: /dev/dsp0
2014-02-02 15:48:18 [381] registered virtual: /dev/video1
2014-02-02 15:48:18 [381] registered virtual: /dev/vbi0
2014-02-02 15:48:18 [381] registered virtual: /dev/radio0
2014-02-02 15:48:18 [381] registered virtual: /dev/rds0
2014-02-02 15:48:18 [381] Initializing Remote Control Support
2014-02-02 15:48:18 [381] This system does not support memory mapped USB transfers
2014-02-02 15:48:18 [381] Once your system reaches the latest kernel version the
2014-02-02 15:48:18 [381] performance will increase automatically
2014-02-02 15:48:18 [381] registered virtual: /dev/mediainput0
2014-02-02 15:48:18 [381] Trying to load ffmpeg codecs
2014-02-02 15:48:18 [381] could not load libavutil.so
2014-02-02 15:48:18 [381] could not load libswscale.so
2014-02-02 15:48:18 [381] could not load libavcodec.so
2014-02-02 15:48:18 [381] could not load libavformat.so
2014-02-02 15:48:18 [381] AnalogTV encoding won't be possible in driver's side
2014-02-02 15:48:18 [381] Initialized MediaTV Pro III USB (EU)
2014-02-02 15:48:18 [381] Driver loaded within 12487 milliseconds
2014-02-02 15:48:18 [381] Initial devicescan done, switching detection mode
2014-02-02 15:48:33 [381] Enabling Standby
2014-02-02 15:54:00 [381] Waking up device
2014-02-02 15:54:00 [381] Setting frequency: 245250000
2014-02-02 15:54:00 [381] Setting analogTV Parameters
2014-02-02 15:54:00 [381] Setting PAL-B
2014-02-02 15:54:00 [381] switching over to radio
2014-02-02 15:54:00 [381] requesting to tune to frequency: 87900000 4
2014-02-02 15:54:00 [381] requesting to tune to frequency: 105500000 180
2014-02-02 15:54:02 [381] Initializing data transfer
2014-02-02 15:54:02 [381] unmute fm radio
2014-02-02 15:54:02 [1043] Starting audio processor (PID 1043)
2014-02-02 15:54:02 [1043] initializing audio in audio processor
2014-02-02 15:54:02 [1043] Starting audio service
2014-02-02 15:54:02 [1043] loaded local pulseaudio driver
2014-02-02 15:54:02 [1043] select error() in audio processor (can be caused because of pulseaudio) (Interrupted system call)
2014-02-02 15:54:02 [1043] Pulseaudio connect reported an error (6 - Connection refused)
Ich benutze Arch-Linux mit Kernel Version 3.12.9-2-ARCH und pulseaudio 4.0-271-g09e8-dirty.
Es gibt teilweise auch komplette Software/Hardware-Freezes, d.h. kein Shutdown mehr möglich, eingefrorenen Bildschirm --> Strom muss aus.
Kann mir da jemand einen Tipp geben?
Viele Grüße und vielen Dank
Christian
Re:Kein Ton - PulseAudio Fehler
« Antwort #1 am: Februar 04, 2014, 12:15:19 Vormittag »
Bezüglich den Crashes, sprichst du Englisch?
Eine Mitarbeiterin von Intel kümmert sich aktuell um USB 3.0 Bugs im Linux Kernel.
Bezüglich Pulseaudio, kontaktiere uns am Besten via Skype (sundtek).
Die Pulseaudio Implementierung im Treiber ist für Ubuntu optimiert.
Läuft denn Pulseaudio überhaupt?
