Autor Thema: Media Center Windows7 (x64)  (Gelesen 27071 mal)
pilzus
« am: Oktober 12, 2009, 01:06:02 Nachmittag »
I've a problem regarding the mediacenter in win7.
I am aware of the digital signature issue and used the "F8" workaround.
Device is detected and marked "This device is working properly".
When I attempt to start the media center and select the setup TV option it produces an error saying that no TV device was detected.
Arghh what do I do wrong, please help.
/Thank you
Re:Media Center Windows7 (x64)
« Antwort #1 am: Oktober 12, 2009, 01:48:23 Nachmittag »
According to the Windows Driver Engineers this is a codec issue, you might try to install a Codec Package (eg. following free codec package):
http://www.free-codecs.com/download/Vista_Codec_Package.htm
pilzus
« Antwort #2 am: Oktober 12, 2009, 03:56:26 Nachmittag »
Thanks for the quick reply, no luck though.
Had to install the windows7 codecs, but it didn't help.
I'll give it a try on my ubuntu box, that should work!
Thanks again!
« Antwort #3 am: Oktober 12, 2009, 04:52:09 Nachmittag »
We will check it again and put up a codec package for it lateron. Our primary target at the beginning has been Linux.
We received some suggestions from some customers and expect to finish those requests till 16th October 09. After this is done we will focus on Windows and Mac again.
Your problem is mainly a codec Problem, that for sure.
