Autor Thema: Continuity errors  (Gelesen 29408 mal)
solipsists
Continuity errors
« am: Februar 24, 2013, 03:36:26 Nachmittag »
ich habe stockende Sender:
Setup:
TV Ultimate
XBMC
TVHeadend
i5 mit 16gb Ram & GT520 - VPDAU aktiv
Irgendwelche Tips?
SIGNAL: [..............................   ] ( 91%)  BER:      0 FREQ: 1611750    Hz LOCKED: YES SYS: DVB-S2 SYM: 22000000 FEC: FEC_2_3 MOD: PSK_8 VOLTAGE: H(18V) TONE: OFF
TVHeadend:
Feb 24 14:28:03 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: H264 @ #6110: Continuity counter error, 17 duplicate log lines suppressed
Feb 24 14:28:03 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: Transport error indicator
Feb 24 14:28:03 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: TELETEXT @ #6130: Continuity counter error
Feb 24 14:28:08 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: H264 @ #6110: Continuity counter error, 19 duplicate log lines suppressed
Feb 24 14:28:23 tdt-tot: time is 2013/02/24 13:27:15
Feb 24 14:28:24 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: H264 @ #6110: Continuity counter error
Feb 24 14:28:28 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: H264 @ #6110: Continuity counter error, 2 duplicate log lines suppressed
Feb 24 14:28:29 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: Transport error indicator
Feb 24 14:28:29 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: H264 @ #6110: Continuity counter error, 4 duplicate log lines suppressed
Feb 24 14:28:32 tdt-tot: time is 2013/02/24 13:27:23
Feb 24 14:28:34 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: H264 @ #6110: Continuity counter error, 5 duplicate log lines suppressed
Feb 24 14:28:34 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: Transport error indicator, 1 duplicate log lines suppressed
Feb 24 14:28:36 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: H264 @ #6110: Continuity counter error, 7 duplicate log lines suppressed
Feb 24 14:28:40 dvb: "_dev_dvb_adapter0_Sundtek_DVB_S_S2__III_" ts sync lost
Feb 24 14:28:40 dvb: "_dev_dvb_adapter0_Sundtek_DVB_S_S2__III_" ts sync found
Feb 24 14:28:40 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: H264 @ #6110: Continuity counter error, 9 duplicate log lines suppressed
Feb 24 14:28:42 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: H264 @ #6110: Continuity counter error, 11 duplicate log lines suppressed
Feb 24 14:28:42 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,361,750 kHz Horizontal (Default (Port 0, Universal LNB))/ZDF HD: Transport error indicator, 2 duplicate log lines suppressed
mediasrv.log
2013-02-24 14:24:38 [931] skipped everything ...
2013-02-24 14:24:39 [931] skipped everything ...
2013-02-24 14:26:00 [931] voltage is high/0
2013-02-24 14:26:01 [931] Diseqc execution time: 120 ms
2013-02-24 14:26:01 [931] Diseqc execution time: 104 ms
2013-02-24 14:26:01 [931] diseqc send burst Unmodulated (SEC_MINI_A)
2013-02-24 14:26:01 [931] Frequency: 1611
2013-02-24 14:26:01 [931] Symbolrate: 22000
2013-02-24 14:26:02 [931] skipped everything ...
2013-02-24 14:26:03 [931] skipped everything ...
2013-02-24 14:26:04 [931] skipped everything ...
2013-02-24 14:28:40 [931] skipped everything ...
« Letzte Änderung: Februar 24, 2013, 03:58:51 Nachmittag von solipsists »
Re:Continuity errors
« Antwort #1 am: Februar 24, 2013, 05:55:58 Nachmittag »
Hmm..Wie sieht denn die CPU Auslastung aus?
solipsists
« Antwort #2 am: Februar 25, 2013, 02:27:20 Nachmittag »
CPU ist auf 23%, meiste wird durch XMBC verursacht, mediaclient braucht 7%...
Ubuntu 12.10 mit 3.5er kernel ist up to date...
« Antwort #3 am: Februar 25, 2013, 03:58:08 Nachmittag »
Passiert das auf allen Sendern?
Wenn ja versuche den Stick an einem USB 2.0 Port anzuschliessen.
Ueberpruefe (sofern vorhanden) auch die Bios Einstellungen bezueglich USB.
solipsists
« Antwort #4 am: Februar 25, 2013, 04:24:27 Nachmittag »
Stick ist auf einem USB 2.0 Port angeschlossen... direkt auf dem Board (USB-Header)
Hab BIOS auf Standardeinstellungen gelassen
Das passiert auf allen Sendern, ich werde heute abend noch weitere Logs posten, da sich diese teilweise unterscheiden.
solipsists
« Antwort #5 am: Februar 25, 2013, 08:15:24 Nachmittag »
Das ist ein anderer Log:
Das erste ist direkt nach dem umschalten:
Feb 25 19:07:34 subscription: "127.0.0.1 [ xbmc | XBMC Media Center ]" subscribing on "arte HD", weight: 150, adapter: "Sundtek DVB-S/S2 (III)", network: "ASTRA 1", mux: "ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))", provider: "ARD", service: "arte HD", quality: 100
Feb 25 19:07:34 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: Transport error indicator
Feb 25 19:07:34 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: H264 @ #5111: Continuity counter error
Feb 25 19:07:34 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: TELETEXT @ #5114: Continuity counter error
Feb 25 19:07:34 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: MPEG2AUDIO @ #5113: Continuity counter error
Feb 25 19:07:34 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: AC3 @ #5116: Continuity counter error
Feb 25 19:07:34 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: MPEG2AUDIO @ #5112: Continuity counter error
Feb 25 19:07:35 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: Transport error indicator, 2000 duplicate log lines suppressed
Feb 25 19:07:35 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: H264 @ #5111: Continuity counter error, 189 duplicate log lines suppressed
Feb 25 19:07:35 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: AC3 @ #5116: Continuity counter error, 32 duplicate log lines suppressed
Feb 25 19:07:35 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: MPEG2AUDIO @ #5112: Continuity counter error, 15 duplicate log lines suppressed
Feb 25 19:07:35 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: MPEG2AUDIO @ #5113: Continuity counter error, 17 duplicate log lines suppressed
Feb 25 19:07:35 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: TELETEXT @ #5114: Continuity counter error, 22 duplicate log lines suppressed
Feb 25 19:07:37 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: AC3 @ #5116: Continuity counter error, 69 duplicate log lines suppressed
Feb 25 19:07:37 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: H264 @ #5111: Continuity counter error, 482 duplicate log lines suppressed
Feb 25 19:07:37 TS: Sundtek DVB-S/S2 (III)/ASTRA 1: 11,493,750 kHz Horizontal (Default (Port 0, Universal LNB))/arte HD: Transport error indicator, 3836 duplicate log lines suppressed
Loglevel debug: enabled
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 11,739,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 11,778,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 11,797,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 11,817,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 11,836,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ()
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 11,856,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 11,875,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 11,895,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ()
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 11,914,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 11,973,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ()
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,031,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,051,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,070,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,109,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,129,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,148,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,168,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,187,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,207,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,304,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,343,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,382,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 11,719,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:03 dvb: Configuration for mux "ASTRA 3: 12,402,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_20, )
Feb 25 19:08:04 eit: processing complete
Feb 25 19:08:05 tdt-tot: time is 2013/02/25 18:08:02
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 11,797,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 11,719,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 12,031,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 12,070,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 11,914,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 12,304,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 12,382,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 11,875,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 12,148,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 12,051,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 11,739,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 11,778,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 11,817,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 11,895,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ()
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 11,973,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ()
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 12,129,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 12,187,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 12,343,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 11,836,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ()
Feb 25 19:08:06 dvb: Configuration for mux "ASTRA 1: 12,402,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_20->ROLLOFF_35, )
Feb 25 19:08:08 dvb: Configuration for mux "ASTRA 3: 11,856,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:08 dvb: Configuration for mux "ASTRA 3: 12,109,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:08 dvb: Configuration for mux "ASTRA 3: 12,168,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:08 dvb: Configuration for mux "ASTRA 3: 12,207,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:10 tdt-tot: time is 2013/02/25 18:08:07
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 11,739,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 11,778,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 11,797,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 11,817,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 11,836,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ()
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 11,856,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 11,875,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 11,895,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ()
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 11,914,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 11,973,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ()
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,031,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,051,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,070,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,109,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,129,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,148,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,168,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,187,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,207,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,304,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,343,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,382,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 11,719,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_25, )
Feb 25 19:08:11 dvb: Configuration for mux "ASTRA 3: 12,402,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( QPSK->PSK_8,  SYS_DVBS->SYS_DVBS2,  ROLLOFF_35->ROLLOFF_20, )
Feb 25 19:08:14 epg: now/next 92723/99249 set on Antenne Brandenburg
Feb 25 19:08:14 epg: arm channel timer @ 1361822580 for Antenne Brandenburg
Feb 25 19:08:14 dvb: Configuration for mux "ASTRA 1: 11,797,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:14 dvb: Configuration for mux "ASTRA 1: 11,719,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:14 dvb: Configuration for mux "ASTRA 1: 12,031,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:14 dvb: Configuration for mux "ASTRA 1: 12,070,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery
Feb 25 19:08:14 dvb: Configuration for mux "ASTRA 1: 11,914,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:14 dvb: Configuration for mux "ASTRA 1: 12,304,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:14 dvb: Configuration for mux "ASTRA 1: 12,382,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:14 dvb: Configuration for mux "ASTRA 1: 11,875,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( SYS_DVBS->SYS_DVBS2, )
Feb 25 19:08:14 dvb: Configuration for mux "ASTRA 1: 12,148,500 kHz Horizontal (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_25->ROLLOFF_35, )
Feb 25 19:08:14 dvb: Configuration for mux "ASTRA 1: 12,051,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS, )
Feb 25 19:08:14 dvb: Configuration for mux "ASTRA 1: 11,739,000 kHz Vertical (Default (Port 0, Universal LNB))" updated by automatic mux discovery ( PSK_8->QPSK,  SYS_DVBS2->SYS_DVBS,  ROLLOFF_25->ROLLOFF_35, )
« Antwort #6 am: Februar 25, 2013, 08:27:31 Nachmittag »
Die Signalstatistiken sehen eigentlich nicht schlecht aus.
Es gibt hier 2 Moeglchkeiten:
1. Die USB Datenuebertragung ist defekt Aufgrund einer Inkompatibilitaet des Host PCs (eventuell Verkabelung)
2. Der USB Stick hat ein Problem
um 2. auszuschliessen wende dich am Besten an kontakt at sundtek de um den Stick kurzfristig auszutauschen.
solipsists
« Antwort #7 am: Februar 25, 2013, 10:34:34 Nachmittag »
Danke für den schnellen und kompetenten Support:
Ich werde das morgen nochmal zur Sicherheit an einem anderen PC testen, um USB-Probleme auszuschließen - ich habe das Jetway NC9B-HM67... da kann man zwar im BIOS ne Menge einstellen, aber ich denke mit der std. Einstellung, wird da wohl nichts schief gehen...
http://www.jetway.org.uk/downloads/manual/NC9B-Fv2.0.zip
Die Ruckler kommen wohl weil der Puffer nicht schnell genug vom Stick gefüllt werden kann...
xbmc.log
21:22:22 T:140292472690432 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
21:22:23 T:140292588128000 WARNING: Previous line repeats 6 times.
21:22:23 T:140292588128000 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 31 ms, dec: 2, proc: 0, rend: 0
21:22:23 T:140292472690432 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
21:22:24 T:140292588128000 WARNING: Previous line repeats 6 times.
21:22:24 T:140292588128000 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 35 ms, dec: 2, proc: 0, rend: 0
21:22:24 T:140292472690432 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
21:22:25 T:140292588128000 WARNING: Previous line repeats 5 times.
21:22:25 T:140292588128000 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 36 ms, dec: 2, proc: 0, rend: 0
21:22:25 T:140292472690432 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
21:22:27 T:140292588128000 WARNING: Previous line repeats 7 times.
21:22:27 T:140292588128000 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
21:22:27 T:140292472690432 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
21:22:29 T:140292588128000 WARNING: Previous line repeats 14 times.
21:22:29 T:140292588128000 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 33 ms, dec: 1, proc: 0, rend: 1
21:22:29 T:140292472690432 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
21:22:32 T:140292588128000 WARNING: Previous line repeats 20 times.
21:22:32 T:140292588128000 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 31 ms, dec: 2, proc: 0, rend: 0
21:22:32 T:140292472690432 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
21:22:38 T:140292588128000 WARNING: Previous line repeats 26 times.
21:22:38 T:140292588128000 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 36 ms, dec: 2, proc: 0, rend: 0
21:22:38 T:140292472690432 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
21:22:41 T:140292588128000 WARNING: Previous line repeats 9 times.
« Letzte Änderung: Februar 25, 2013, 10:59:44 Nachmittag von solipsists »
« Antwort #8 am: Februar 25, 2013, 10:37:22 Nachmittag »
Das kann das Problem nicht sein.
Aber eventuell sind die VDPAU Einstellungen nicht ganz richtig, es gab hier im Forum bereits einige Posts bezüglich VDPAU Settings für Xine, das ist aber auch schon länger her.
Du kannst ja versuchen den Datenstrom auf die Festplatte zu übertragen und dann von dort abzuspielen
cat /dev/dvb/adapter0/dvr0 > /tmp/test.ts (dadurch wird der aktuelle Transponder aufgezeichnet)
Beim Abspielen hat die Applikation dann freie Wahl und kann den Puffer so befüllen wie er wirklich benötigt wird
« Antwort #9 am: Februar 25, 2013, 10:39:13 Nachmittag »
solipsists
« Antwort #10 am: Februar 25, 2013, 11:19:59 Nachmittag »
Hi, habe meinen Post oben ergänzt,
ich denke nicht das es an den VPDAU Settings liegt, da anderes 1080p Material ruckelfrei wiedergegeben wird, dieses Bufferverhalten tritt nur bei Live TV auf...
(habe auch testweise mal die deinterlacer deaktiviert um die last zu reduzieren...)
Soll diese Aufnahme bei laufendem Sender getätigt werden, /tmp/ hängt in der ramdisk/tmpfs, insofern sollte das aufnehmen kein problem darstellen...
« Antwort #11 am: Februar 26, 2013, 12:00:21 Vormittag »
Ja, es soll bei einer laufenden Aufnahme zusätzlich ausgeführt werden
