Autor Thema: MediaTV dvb-c stick, is really a dual tuner?  (Gelesen 16474 mal)
eikido
« am: Januar 02, 2013, 02:26:48 Nachmittag »
I managed somehow in some cases to watch two different channels simultanously with my setup.
I use tvheadend as backbone and watched some channels simultanously.
I then use two different xbmc setups with tvheadend clients.
On someother channels i couldn't do it. I got "no subscription".
Is it dual tuner? How can i watch the other channels simultanously?
Re:MediaTV dvb-c stick, is really a dual tuner?
« Antwort #1 am: Januar 02, 2013, 02:45:48 Nachmittag »
Sundtek MediaTV Pro / Digital Home are no dualtuners.
One DVB-C transponder usually carries several TV channels, as long as you stay within the same frequency you can watch another channel, but you cannot switch to a second frequency at the same time.
eikido
« Antwort #2 am: Januar 04, 2013, 10:46:45 Vormittag »
I see. Can i use two MediaTV stick simultanously to watch two different channels simultanously? Will openelec / xbmc / your drivers allow that?
« Antwort #3 am: Januar 04, 2013, 12:24:54 Nachmittag »
yes, that is possible.
