Autor Thema: Drivers from October'12. Freeze issue.  (Gelesen 46398 mal)
StAlex
« am: Oktober 10, 2012, 08:27:06 Vormittag »
Hello again.
I am catch a something, IMHO, required your, or other VU+ users attention.
With the latest drivers from Sundtek, dated ~ first days of october'12 (dated 29-sep-2012 - last driver which is work ok), AND the any 2012 drivers from Marusys (I tried vary from the beginning of 2012 to the latest)
when box is rebooted on the encrypted DVB-C channel, it will freezed to respond after reboot (when STB starts on the encrypted DVB-C channel). Just:
- info bar appears with the name of the channel;
- NO indicator of encryption;
- NO update of local time (always displayed 01.01.1970 03:00);
- NO picture resolution of the channel (atomic symbol "x");
- The spinner rounding at the left top corner of screen.
Expecting the "top" command on telnet, it shows that enigma2 process eat more than 40% of cpu.
In my case, I'm experiences a troubles with the CI-module (pairing conax CAM, troubles described here), but that issue appears with OR without insertion of any CAM. Only one way to unfreeze: physically unplug USB tuner and kill the enigma2 processes (or reboot).
This is again ugly Marysys drivers (as says the one of maintainers of OpenPLi project) ?
;o)
Re:Drivers from October'12. Freeze issue.
« Antwort #1 am: Oktober 10, 2012, 10:57:00 Vormittag »
Please test with the latest drivers from 9th September from our side, we had to add some "workarounds" for some other systems which interfered for 2 days with some Settopbox Versions.
After that please give some feedback.
Did you really reboot or just restart enigma?
StAlex
« Antwort #2 am: Oktober 10, 2012, 11:16:19 Vormittag »
No matter, how STB was restarted - reboot or kill the enigma2. For the first couple of time - I am always did the reboot by the switch on rearpanel or sending the 'reboot' command via telnet. But later - when I am start to searching workarounds - do that via killing the enigma2 and reinstalling the drivers.
Did you mean 9th october ?
With this one: 121009.203043 ?
Ok, this evening (~19:00 - 20:00 CET) I'll try.
« Antwort #3 am: Oktober 10, 2012, 11:31:55 Vormittag »
9th October of course yes.
StAlex
« Antwort #4 am: Oktober 10, 2012, 07:31:50 Nachmittag »
I am try latest version 121009.203043
No success: after reboot, symptoms are the same:
- CPU load
- Frozen info ba
- the spinner
- date 1970
- and so on
I am going back to driver from 29-sep
« Antwort #5 am: Oktober 10, 2012, 10:37:12 Nachmittag »
Try to update the driver, a workaround for dreamboxes caused the problem for others. We hope that all scenarios are okay now.
StAlex
« Antwort #6 am: Oktober 11, 2012, 08:49:44 Nachmittag »
yes, your hopes are completely realised. on the drivers from 10 october, after reboot on encrypted channel STB starts correctly.
