Autor Thema: Betreiben des DVB-C Home auf der DM500HD mit Ridax Hardware  (Gelesen 64159 mal)
bonzaii
Re:Betreiben des DVB-C Home auf der DM500HD mit Ridax Hardware
« Antwort #15 am: Dezember 30, 2010, 11:23:59 Nachmittag »
2010-12-30 21:09:32 [734] Starting up Multimedia Framework (Dec 29 2010 12:13:03)
2010-12-30 21:09:32 [736] Starting service processor (PID 736)
2010-12-30 21:09:32 [734] API Version: 5.1
2010-12-30 21:09:32 [734] Running on Linux (2.6.18-7.4-dm500hd)
2010-12-30 21:09:32 [734] Detected BCM97xxx Settop Platform
2010-12-30 21:09:32 [734] unable to load acceleration module
2010-12-30 21:09:32 [734] scanning devices
2010-12-30 21:09:32 [734] scanning for plugins
2010-12-30 21:09:32 [734] Starting up device manager
2010-12-30 21:09:32 [734] Created Masterlock
2010-12-30 21:09:32 [734] scanning devices done
2010-12-30 21:09:32 [734] attached devices:
2010-12-30 21:09:32 [734] registering ID: 0
2010-12-30 21:09:32 [734] disconnecting kernel driver
2010-12-30 21:09:33 [736] Autostarting scripts in /etc/sundtek/
2010-12-30 21:09:33 [736] executed all available items
2010-12-30 21:09:33 [734] attaching DVB-T, DVB-C
2010-12-30 21:09:33 [734] Using second generation demodulator
2010-12-30 21:09:34 [734] demodulator successfully attached (DVB_C)!
2010-12-30 21:09:34 [734] requesting to attach tuner(s) now
2010-12-30 21:09:35 [734] This device uses the second generation Tuner
2010-12-30 21:09:35 [734] registering: adapter1/0
2010-12-30 21:09:35 [734] registered virtual: /dev/dvb/adapter1/frontend0
2010-12-30 21:09:35 [734] registered virtual: /dev/dvb/adapter1/demux0
2010-12-30 21:09:35 [734] registered virtual: /dev/dvb/adapter1/dvr0
2010-12-30 21:09:35 [734] registered virtual: /dev/mediainput0
2010-12-30 21:09:35 [736] trying to load uinput module
2010-12-30 21:09:35 [736] loading uinput kernel extention failed, remote control will not work with lirc
2010-12-30 21:09:35 [734] Sundtek MediaTV Driver loaded. This driver is licensed for non-commercial use
2010-12-30 21:09:35 [734] with Sundtek MediaTV only
2010-12-30 21:09:35 [734] Driver loaded within 2927 milliseconds
2010-12-30 21:09:37 [734] Initial devicescan done, switching detection mode
2010-12-30 21:09:50 [734] Enabling standby
bonzaii
« Antwort #16 am: Dezember 30, 2010, 11:26:06 Nachmittag »
Dec 30 21:09:55 dm500hd user.warn kernel: [4294738.309000] VTUNER ioctl 2
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.112000] set current avs auto aspect to 4:3
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.112000] disable wss on display 0
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.113000] disable wss on display 1
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.113000] set sb to 3(2)
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.151000] set current avs auto aspect to 4:3
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.152000] disable wss on display 0
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.153000] disable wss on display 1
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.153000] set sb to 3(2)
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.155000] disable wss on display 0
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.156000] set wss 8 on display 1
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.192000] set input to 0
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.192000] set fb to 2(0)
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.193000] set current avs auto aspect to 4:3
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.193000] disable wss on display 0
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.194000] set wss 8 on display 1
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.194000] set sb to 3(2)
Dec 30 21:10:00 dm500hd user.warn kernel: [4294743.198000] set ac3 to downmix
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.211000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.212000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.213000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.213000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.251000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.252000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.253000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.253000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.255000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.255000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.257000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.258000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.258000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.259000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.263000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.264000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.265000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.265000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.266000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.267000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.268000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.268000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.269000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.270000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.271000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.272000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.273000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.273000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.278000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.279000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.279000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.280000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.281000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.282000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.282000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.283000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.285000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.285000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.287000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.287000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.288000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.288000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.293000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.294000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.294000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.295000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.297000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.297000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.298000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.298000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.300000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.301000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.302000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.303000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.303000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.304000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.308000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.309000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.309000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.310000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.311000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.312000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.312000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.313000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.317000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.318000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.318000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.319000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.320000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.321000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.321000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.322000] set sb to 3(1)
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.323000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.323000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.324000] set current avs auto aspect to 16:9
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.325000] disable wss on display 0
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.326000] set wss 7 on display 1
Dec 30 21:10:03 dm500hd user.warn kernel: [4294746.326000] set sb to 3(1)
Dec 30 21:10:06 dm500hd user.warn kernel: [4294749.034000] set mute 0 (000) 1
Dec 30 21:10:06 dm500hd user.warn kernel: [4294749.143000] bcm4506 channel 0 is in normale mode now
Dec 30 21:10:06 dm500hd user.warn kernel: [4294749.619000] start pcr0 on dmx 0 pid:1ff index 5
Dec 30 21:10:06 dm500hd user.warn kernel: [4294749.620000] start audio on dmx 0 pid:200
Dec 30 21:10:06 dm500hd user.warn kernel: [4294749.621000] audio xpt start
Dec 30 21:10:06 dm500hd user.warn kernel: [4294749.622000] sync is off so we enable it
Dec 30 21:10:06 dm500hd user.warn kernel: [4294749.622000] demux-index 0 pcr0pid 1ff
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.623000] using 5 as pcr0 pidchannel
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.623000] MPEG
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.624000] audio: streamtype set 0
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.624000] audio: streamtype_set: stop rave
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.625000] audio: streamtype_set: restart rave
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.626000] set mute 0 (111) 1
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.627000] audio: decoder start 2
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.629000] video delay 0 (0 ms)
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.630000] total video delay: 0 (0 ms)
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.632000] start video0 on dmx 0 pid:1ff
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.632000] total video delay: 0 (0 ms)
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.636000] VIDEO0: start decode
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.800000] RAP first pts 0x11c427fe8, stc 0xd1cb2a36, pcr valid
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.803000] audio_cdb_itb_error_isr! underflow
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.807000] audio_cdb_itb_error_isr! underflow
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.811000] audio_cdb_itb_error_isr! underflow
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.814000] audio_cdb_itb_error_isr! underflow
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.818000] audio_cdb_itb_error_isr! underflow
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.822000] audio_cdb_itb_error_isr! underflow
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.826000] audio_cdb_itb_error_isr! underflow
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.830000] audio_cdb_itb_error_isr! underflow
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.834000] audio_cdb_itb_error_isr! underflow
Dec 30 21:10:07 dm500hd user.warn kernel: [4294749.838000] audio_cdb_itb_error_isr! underflow
Dec 30 21:10:07 dm500hd user.warn kernel: [4294750.013000] signal_strength -45.27dbm
Dec 30 21:10:07 dm500hd daemon.debug CCcam: EMM: not interested in 09C4:000000
Dec 30 21:10:07 dm500hd daemon.debug CCcam: EMM: not interested in 09AF:000000
Dec 30 21:10:08 dm500hd user.warn kernel: [4294751.035000] signal_strength -45.42dbm
Dec 30 21:10:08 dm500hd user.warn kernel: [4294751.263000] ch0: lock
Dec 30 21:10:08 dm500hd user.warn kernel: [4294751.492000] VIDEO0: first pts 0xd1ce0b08
Dec 30 21:10:08 dm500hd user.warn kernel: [4294751.492000] VIDEO0: resolution changed (544 576)
Dec 30 21:10:09 dm500hd user.warn kernel: [4294751.649000] enable tsm0
Dec 30 21:10:09 dm500hd user.warn kernel: [4294751.652000] VIDEO0: progressive changed (0)
Dec 30 21:10:09 dm500hd user.warn kernel: [4294752.057000] signal_strength -45.17dbm
Dec 30 21:10:10 dm500hd user.warn kernel: [4294753.078000] signal_strength -45.39dbm
Dec 30 21:10:11 dm500hd user.warn kernel: [4294754.080000] signal_strength -45.40dbm
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.375000] stop pcr0 on dmx 0 pid:1ff
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.376000] stop video0 on dmx 0 pid:1ff
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.378000] VIDEO0: stop decode
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.379000] VIDEO0: set blank to 1
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.380000] audio: decoder stop
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.381000] stop audio on dmx 0 pid:200
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.381000] audio: xpt stop(3)
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.382000] no decoder left in sync handling so disable xpt_sync
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.383000] bcm_audio_channel_stop(3) done
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.413000] start pcr0 on dmx 0 pid:cff index 4
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.415000] start audio on dmx 0 pid:d00
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.416000] audio xpt start
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.416000] sync is off so we enable it
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.417000] demux-index 0 pcr0pid cff
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.417000] using 4 as pcr0 pidchannel
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.418000] MPEG
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.418000] audio: decoder start 0
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.421000] video delay 0 (0 ms)
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.421000] total video delay: 0 (0 ms)
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.423000] start video0 on dmx 0 pid:cff
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.424000] total video delay: 0 (0 ms)
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.428000] VIDEO0: start decode
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.506000] signal_strength -45.37dbm
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.546000] RAP first pts 0x114adf564, stc 0xd695fd94, pcr valid
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.547000] printk: 366 messages suppressed.
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.548000] audio_cdb_itb_error_isr! underflow
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.551000] audio_cdb_itb_error_isr! underflow
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.555000] audio_cdb_itb_error_isr! underflow
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.559000] audio_cdb_itb_error_isr! underflow
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.563000] audio_cdb_itb_error_isr! underflow
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.567000] audio_cdb_itb_error_isr! underflow
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.571000] audio_cdb_itb_error_isr! underflow
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.574000] audio_cdb_itb_error_isr! underflow
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.578000] audio_cdb_itb_error_isr! underflow
Dec 30 21:25:19 dm500hd user.warn kernel: [  694.582000] audio_cdb_itb_error_isr! underflow
Dec 30 21:25:19 dm500hd daemon.debug CCcam: EMM: not interested in 09C4:000000
Dec 30 21:25:19 dm500hd daemon.debug CCcam: EMM: not interested in 09AF:000000
Dec 30 21:25:20 dm500hd user.warn kernel: [  695.509000] signal_strength -45.18dbm
Dec 30 21:25:20 dm500hd user.warn kernel: [  695.690000] ch0: lock
Dec 30 21:25:20 dm500hd user.warn kernel: [  696.028000] VIDEO0: first pts 0xd69886c0
Dec 30 21:25:20 dm500hd user.warn kernel: [  696.028000] VIDEO0: resolution changed (720 576)
Dec 30 21:25:20 dm500hd user.warn kernel: [  696.180000] enable tsm0
Dec 30 21:25:21 dm500hd user.warn kernel: [  696.530000] signal_strength -45.43dbm
Dec 30 21:25:22 dm500hd user.warn kernel: [  697.551000] signal_strength -45.13dbm
Dec 30 21:25:23 dm500hd user.warn kernel: [  698.572000] signal_strength -45.17dbm
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.644000] stop pcr0 on dmx 0 pid:cff
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.645000] stop video0 on dmx 0 pid:cff
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.647000] VIDEO0: stop decode
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.648000] VIDEO0: set blank to 1
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.649000] audio: decoder stop
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.651000] stop audio on dmx 0 pid:d00
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.651000] audio: xpt stop(2)
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.652000] no decoder left in sync handling so disable xpt_sync
bonzaii
« Antwort #17 am: Dezember 30, 2010, 11:26:19 Nachmittag »
[code]Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.652000] bcm_audio_channel_stop(2) done
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.684000] start pcr0 on dmx 0 pid:1ff index 4
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.686000] start audio on dmx 0 pid:200
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.686000] audio xpt start
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.687000] sync is off so we enable it
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.687000] demux-index 0 pcr0pid 1ff
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.688000] using 4 as pcr0 pidchannel
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.689000] MPEG
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.689000] audio: decoder start 0
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.692000] video delay 0 (0 ms)
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.692000] total video delay: 0 (0 ms)
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.694000] start video0 on dmx 0 pid:1ff
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.694000] total video delay: 0 (0 ms)
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.698000] VIDEO0: start decode
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.725000] RAP first pts 0x1d166f13e, stc 0xe3578a5c, pcr valid
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.728000] printk: 292 messages suppressed.
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.729000] audio_cdb_itb_error_isr! underflow
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.732000] audio_cdb_itb_error_isr! underflow
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.736000] audio_cdb_itb_error_isr! underflow
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.740000] audio_cdb_itb_error_isr! underflow
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.744000] audio_cdb_itb_error_isr! underflow
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.748000] audio_cdb_itb_error_isr! underflow
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.752000] audio_cdb_itb_error_isr! underflow
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.755000] audio_cdb_itb_error_isr! underflow
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.759000] audio_cdb_itb_error_isr! underflow
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.763000] audio_cdb_itb_error_isr! underflow
Dec 30 22:04:39 dm500hd user.warn kernel: [ 3053.802000] signal_strength -45.31dbm
Dec 30 22:04:39 dm500hd daemon.debug CCcam: EMM: not interested in 09C4:000000
Dec 30 22:04:39 dm500hd daemon.debug CCcam: EMM: not interested in 09AF:000000
Dec 30 22:04:40 dm500hd user.warn kernel: [ 3054.680000] ch0: lock
Dec 30 22:04:40 dm500hd user.warn kernel: [ 3054.823000] signal_strength -45.35dbm
Dec 30 22:04:40 dm500hd user.warn kernel: [ 3055.008000] VIDEO0: first pts 0xe359b188
Dec 30 22:04:40 dm500hd user.warn kernel: [ 3055.009000] VIDEO0: resolution changed (544 576)
Dec 30 22:04:40 dm500hd user.warn kernel: [ 3055.160000] enable tsm0
Dec 30 22:04:41 dm500hd user.warn kernel: [ 3055.845000] signal_strength -45.11dbm
Dec 30 22:04:42 dm500hd user.warn kernel: [ 3056.866000] signal_strength -45.38dbm
Dec 30 22:04:43 dm500hd user.warn kernel: [ 3057.887000] signal_strength -45.31dbm
Dec 30 22:13:58 dm500hd user.warn kernel: [ 3614.294000] stop pcr0 on dmx 0 pid:1ff
Dec 30 22:13:58 dm500hd user.warn kernel: [ 3614.295000] stop video0 on dmx 0 pid:1ff
Dec 30 22:13:58 dm500hd user.warn kernel: [ 3614.297000] VIDEO0: stop decode
Dec 30 22:13:58 dm500hd user.warn kernel: [ 3614.298000] VIDEO0: set blank to 1
Dec 30 22:13:58 dm500hd user.warn kernel: [ 3614.299000] audio: decoder stop
Dec 30 22:13:58 dm500hd user.warn kernel: [ 3614.302000] stop audio on dmx 0 pid:200
Dec 30 22:13:58 dm500hd user.warn kernel: [ 3614.303000] audio: xpt stop(2)
Dec 30 22:13:58 dm500hd user.warn kernel: [ 3614.303000] no decoder left in sync handling so disable xpt_sync
Dec 30 22:13:58 dm500hd user.warn kernel: [ 3614.304000] bcm_audio_channel_stop(2) done
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.416000] signal_strength -45.27dbm
Dec 30 22:13:59 dm500hd user.err kernel: [ 3614.872000] dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.873000] start pcr0 on dmx 0 pid:4ff index 4
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.875000] start audio on dmx 0 pid:500
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.875000] audio xpt start
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.876000] sync is off so we enable it
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.876000] demux-index 0 pcr0pid 4ff
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.877000] using 4 as pcr0 pidchannel
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.878000] AC3
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.878000] audio: streamtype set 1
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.879000] audio: streamtype_set: stop rave
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.879000] decode
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.880000] audio: streamtype_set: restart rave
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.880000] set mute 0 (111) 0
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.881000] audio: decoder start 0
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.884000] video delay 0 (0 ms)
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.884000] total video delay: 0 (0 ms)
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.886000] VIDEO0: set streamtype!
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.886000] set H264
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.887000] sw rave disabled!
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.887000] audio delay 9000 (100 ms)
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.888000] total video delay: 9000 (100 ms)
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.889000] start video0 on dmx 0 pid:4ff
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.890000] total video delay: 9000 (100 ms)
Dec 30 22:13:59 dm500hd user.warn kernel: [ 3614.893000] VIDEO0: start decode
Dec 30 22:13:59 dm500hd user.err kernel: [ 3615.168000] dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.378000] RAP first pts 0x1d60e4b00, stc 0xa51cb0c8, pcr valid
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.380000] printk: 258 messages suppressed.
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.381000] audio_cdb_itb_error_isr! underflow
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.384000] audio_cdb_itb_error_isr! underflow
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.388000] audio_cdb_itb_error_isr! underflow
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.392000] audio_cdb_itb_error_isr! underflow
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.396000] audio_cdb_itb_error_isr! underflow
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.400000] audio_cdb_itb_error_isr! underflow
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.404000] audio_cdb_itb_error_isr! underflow
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.408000] audio_cdb_itb_error_isr! underflow
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.412000] audio_cdb_itb_error_isr! underflow
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.415000] audio_cdb_itb_error_isr! underflow
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.437000] signal_strength -44.28dbm
Dec 30 22:14:00 dm500hd user.warn kernel: [ 3615.633000] ch0: lock
Dec 30 22:14:01 dm500hd user.warn kernel: [ 3616.424000] VIDEO0: first pts 0xa51effd0
Dec 30 22:14:01 dm500hd user.warn kernel: [ 3616.424000] VIDEO0: resolution changed (1440 1080)
Dec 30 22:14:01 dm500hd user.warn kernel: [ 3616.458000] signal_strength -44.41dbm
Dec 30 22:14:01 dm500hd user.warn kernel: [ 3616.575000] enable tsm0
Dec 30 22:14:03 dm500hd user.warn kernel: [ 3617.479000] signal_strength -44.34dbm
Dec 30 22:14:04 dm500hd user.warn kernel: [ 3618.501000] signal_strength -44.38dbm
Dec 30 22:14:21 dm500hd user.warn kernel: [ 3636.266000] stop pcr0 on dmx 0 pid:4ff
Dec 30 22:14:21 dm500hd user.warn kernel: [ 3636.267000] stop video0 on dmx 0 pid:4ff
Dec 30 22:14:21 dm500hd user.warn kernel: [ 3636.278000] VIDEO0: stop decode
Dec 30 22:14:21 dm500hd user.warn kernel: [ 3636.278000] VIDEO0: set blank to 1
Dec 30 22:14:21 dm500hd user.warn kernel: [ 3636.279000] audio: decoder stop
Dec 30 22:14:21 dm500hd user.warn kernel: [ 3636.285000] stop audio on dmx 0 pid:500
Dec 30 22:14:21 dm500hd user.warn kernel: [ 3636.285000] audio: xpt stop(3)
Dec 30 22:14:21 dm500hd user.warn kernel: [ 3636.286000] no decoder left in sync handling so disable xpt_sync
Dec 30 22:14:21 dm500hd user.warn kernel: [ 3636.286000] bcm_audio_channel_stop(3) done
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.400000] signal_strength -44.48dbm
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.835000] start pcr0 on dmx 0 pid:177a index 5
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.837000] start audio on dmx 0 pid:1784
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.837000] audio xpt start
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.838000] sync is off so we enable it
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.838000] demux-index 0 pcr0pid 177a
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.839000] using 5 as pcr0 pidchannel
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.840000] MPEG
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.840000] audio: streamtype set 0
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.840000] audio: streamtype_set: stop rave
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.841000] audio: streamtype_set: restart rave
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.842000] set mute 0 (111) 0
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.842000] audio: decoder start 0
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.845000] audio delay 9000 (100 ms)
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.845000] total video delay: 9000 (100 ms)
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.847000] start video0 on dmx 0 pid:177a
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.848000] total video delay: 9000 (100 ms)
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.852000] VIDEO0: start decode
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.871000] ch0: lock
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.872000] printk: 85 messages suppressed.
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.872000] RAP sampling rate info isr
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.873000] eModeChange Isr.. set source_changed_event!
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.923000] RAP first pts 0x6d4796c6, stc 0x6d47877c, pcr valid
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.924000] audio_cdb_itb_error_isr! underflow
Dec 30 22:14:22 dm500hd user.warn kernel: [ 3636.928000] audio_cdb_itb_error_isr! underflow
Dec 30 22:14:23 dm500hd user.warn kernel: [ 3637.404000] signal_strength -41.36dbm
Dec 30 22:14:23 dm500hd user.warn kernel: [ 3637.783000] VIDEO0: first pts 0x6d4a3af0
Dec 30 22:14:23 dm500hd user.warn kernel: [ 3637.784000] VIDEO0: framerate changed 6
Dec 30 22:14:23 dm500hd user.warn kernel: [ 3637.784000] VIDEO0: resolution changed (1280 720)
Dec 30 22:14:23 dm500hd user.warn kernel: [ 3637.786000] set current avs auto aspect to 16:9
Dec 30 22:14:23 dm500hd user.warn kernel: [ 3637.786000] disable wss on display 0
Dec 30 22:14:23 dm500hd user.warn kernel: [ 3637.787000] set wss 7 on display 1
Dec 30 22:14:23 dm500hd user.warn kernel: [ 3637.788000] set sb to 3(1)
Dec 30 22:14:23 dm500hd user.warn kernel: [ 3637.863000] VIDEO0: progressive changed (1)
Dec 30 22:14:23 dm500hd user.warn kernel: [ 3637.938000] enable tsm0
Dec 30 22:14:24 dm500hd user.warn kernel: [ 3638.427000] signal_strength -41.50dbm
Dec 30 22:14:25 dm500hd user.warn kernel: [ 3639.448000] signal_strength -41.53dbm
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.469000] signal_strength -41.27dbm
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.624000] stop pcr0 on dmx 0 pid:177a
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.626000] stop video0 on dmx 0 pid:177a
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.635000] VIDEO0: stop decode
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.636000] VIDEO0: set blank to 1
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.637000] audio: decoder stop
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.638000] stop audio on dmx 0 pid:1784
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.639000] audio: xpt stop(3)
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.639000] no decoder left in sync handling so disable xpt_sync
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.640000] bcm_audio_channel_stop(3) done
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.672000] start pcr0 on dmx 0 pid:17de index 5
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.673000] start audio on dmx 0 pid:17e8
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.674000] audio xpt start
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.675000] sync is off so we enable it
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.675000] demux-index 0 pcr0pid 17de
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.676000] using 5 as pcr0 pidchannel
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.676000] MPEG
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.677000] audio: decoder start 0
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.679000] audio delay 9000 (100 ms)
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.680000] total video delay: 9000 (100 ms)
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.681000] start video0 on dmx 0 pid:17de
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.682000] total video delay: 9000 (100 ms)
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.685000] VIDEO0: start decode
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.715000] ch0: lock
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.716000] printk: 4 messages suppressed.
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.716000] RAP sampling rate info isr
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3640.818000] RAP first pts 0xd5929dd2, stc 0xd5928ed6, pcr valid
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3641.123000] VIDEO0: first pts 0xd59480fa
Dec 30 22:14:26 dm500hd user.warn kernel: [ 3641.274000] enable tsm0
Dec 30 22:14:27 dm500hd user.warn kernel: [ 3641.472000] signal_strength -41.32dbm
Dec 30 22:14:28 dm500hd user.warn kernel: [ 3642.474000] signal_strength -41.29dbm
Dec 30 22:14:29 dm500hd user.warn kernel: [ 3643.497000] signal_strength -41.54dbm
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3644.518000] signal_strength -41.53dbm
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.017000] stop pcr0 on dmx 0 pid:17de
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.018000] stop video0 on dmx 0 pid:17de
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.020000] VIDEO0: stop decode
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.021000] VIDEO0: set blank to 1
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.022000] audio: decoder stop
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.024000] stop audio on dmx 0 pid:17e8
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.024000] audio: xpt stop(3)
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.025000] no decoder left in sync handling so disable xpt_sync
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.026000] bcm_audio_channel_stop(3) done
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.057000] start pcr0 on dmx 0 pid:1842 index 5
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.059000] start audio on dmx 0 pid:184c
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.059000] audio xpt start
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.060000] sync is off so we enable it
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.060000] demux-index 0 pcr0pid 1842
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.061000] using 5 as pcr0 pidchannel
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.062000] AC3
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.062000] audio: streamtype set 1
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.062000] audio: streamtype_set: stop rave
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.063000] decode
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.064000] audio: streamtype_set: restart rave
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.064000] set mute 0 (111) 0
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.065000] audio: decoder start 0
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.067000] audio delay 9000 (100 ms)
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.068000] total video delay: 9000 (100 ms)
Dec 30 22:14:30 dm500hd user.warn kernel: [ 3645.070000] start video0 on dmx 0 pid:1842
[/code]
bonzaii
« Antwort #18 am: Dezember 30, 2010, 11:27:11 Nachmittag »
2010-12-30 21:09:50 [761] down acquire semaphore
2010-12-30 21:09:50 [762] down acquire semaphore
2010-12-30 21:09:50 [763] down acquire semaphore
2010-12-30 21:09:50 [734] down acquire semaphore
Ich hoffe das hilft ein wenig bei meinem Problem ...
bonzaii
« Antwort #19 am: Januar 02, 2011, 12:15:55 Nachmittag »
... auch mit dem aktuellen Treiber bekomme ich kein Bild ...
Es geht wohl nur nach einer frischen Installation - da geht dannn eigentlich alles inklusive Senderscan ... nach dem ersten DeepStandy ist schluss ...
« Antwort #20 am: Januar 02, 2011, 01:17:59 Nachmittag »
Was zeigt den /opt/bin/mediaclient --readsignal=0 -d /dev/dvb/adapter1/frontend0 oder (dreamboxspezifisch)
/usr/sundtek/mediaclient --readsignal=0 -d /dev/dvb/adapter1/frontend0 an?
bonzaii
« Antwort #21 am: Januar 02, 2011, 01:18:32 Nachmittag »
Das habe ich noch gefunden ... aber ich kann nichts damit anfangen ...
Jan  2 12:08:21 dm500hd user.warn kernel: [ 2381.904000] stop pcr0 on dmx 0 pid:1ff
Jan  2 12:08:21 dm500hd user.warn kernel: [ 2381.905000] stop video0 on dmx 0 pid:1ff
Jan  2 12:08:21 dm500hd user.warn kernel: [ 2381.907000] VIDEO0: stop decode
Jan  2 12:08:21 dm500hd user.warn kernel: [ 2381.908000] VIDEO0: set blank to 1
Jan  2 12:08:21 dm500hd user.warn kernel: [ 2381.910000] audio: decoder stop
Jan  2 12:08:21 dm500hd user.warn kernel: [ 2381.911000] stop audio on dmx 0 pid:203
Jan  2 12:08:21 dm500hd user.warn kernel: [ 2381.911000] audio: xpt stop(3)
Jan  2 12:08:21 dm500hd user.warn kernel: [ 2381.912000] no decoder left in sync handling so disable xpt_sync
Jan  2 12:08:21 dm500hd user.warn kernel: [ 2381.912000] bcm_audio_channel_stop(3) done
Jan  2 12:08:21 dm500hd user.warn kernel: [ 2382.005000] VTUNER ioctl 1
bonzaii
« Antwort #22 am: Januar 02, 2011, 01:30:37 Nachmittag »
während der abgestürzten Box kommt da:
* http://www.newnigma2.to   *
*  the next step is done    *
OpenDreambox
dm500hd login: root
root@dm500hd:~# /opt/bin/mediaclient --readsignal=0 -d /dev/dvb/adapter1/frontend0
-sh: /opt/bin/mediaclient: not found
root@dm500hd:~# /usr/sundtek/mediaclient --readsignal=0 -d /dev/dvb/adapter1/frontend0
SIGNAL: [                                 ] (  0%)  BER:  41248 FREQ: 0          Hz LOCKED:  NO SYM: 0 MOD: unknown
Das ändert sich auch nicht nach einem Reboot ...
Der Tuner ist aber anwählbar in der Kanalsuche ...
« Antwort #23 am: Januar 02, 2011, 01:31:44 Nachmittag »
Naja eine Frequenz muss schon eingestellt sein, ansonsten ist die Ausgabe sinnlos.
Bitte auch auf allen Rechnern http://www.sundtek.de/media/sundtek_installer_development.sh verwenden (nie Versionen mischen).
bonzaii
« Antwort #24 am: Januar 02, 2011, 01:42:37 Nachmittag »
Ich verwende auf allen Geräten immer die neueste Version ...
Die Ausgabe bleibt bei angewähltem Sender die gleiche -> die Box ist dann aber abgestürzt und reagiert gar nicht mehr ...
Über das Sundtek Control Center läßt sich auch alles einstellen. Es gibt keine Fehlermeldung bei der Treiberaktivierung.
« Antwort #25 am: Januar 02, 2011, 01:46:28 Nachmittag »
Wäre ssh oder telnet Zugriff möglich / wenn ja Zugangsdaten bitte an kontakt at sundtek de
bonzaii
« Antwort #26 am: Januar 02, 2011, 01:49:21 Nachmittag »
Das ist sicher möglich ... weiss aber nicht, wie ich das mache soll?
« Antwort #27 am: Januar 02, 2011, 02:19:35 Nachmittag »
Skype: sundtek
ggf. können wir später weiterhelfen.
bonzaii
« Antwort #28 am: Januar 02, 2011, 02:39:48 Nachmittag »
skype ist möglich ...
bonzaii
« Antwort #29 am: Januar 02, 2011, 03:43:07 Nachmittag »
Nochmals einen Versuch gestartet:
iCVS installiert ...
SundtekControlCenter installiert ...
Sendersuchlauf gemacht ...
Fernsehen geht auf allen Kanälen, Umschaltzeiten sind gut ...
... und dann ...
Reboot ...
Selber Fehler, wie schon beschrieben: Unendlicher Spinner und die Box reagiert nicht mehr auf die Fernbedienung ...
Ich warte auf Hilfe  ;)
