Sundtek Support Forum
Willkommen
Gast
. Bitte
einloggen
oder
registrieren
1 Stunde
1 Tag
1 Woche
1 Monat
Immer
Übersicht
Support Chat
Discord
Shop
Ticketsystem
Hilfe
Suche
Einloggen
Registrieren
English
VU+ - VU Duo Settopbox
Solo 4k
« vorheriges
nächstes »
Drucken
Seiten: [
1
2
Autor
Thema: Solo 4k (Gelesen 36832 mal)
DaMacFunkin
Newbie
Solo 4k
am:
Oktober 30, 2015, 06:09:14 Nachmittag »
Hello I now have Solo4k as well as Duo2 and Solo2.
Do you have plug in and drivers for your products for New Solo4k?
If so does it work on VTI 9, they are the only image at the moment.
Thank you.
Gespeichert
Administrator
Hero Member
Re:Solo 4k
Antwort #1 am:
Oktober 30, 2015, 07:23:58 Nachmittag »
For sure we have a driver for it but I don't think that the installer will detect it as a settopbox. It will just detect it as ARM system.
Can you contact us via Skype so we can update the installer script to detect your system as settopbox?
Gespeichert
DaMacFunkin
Newbie
Re:Solo 4k
Antwort #2 am:
Oktober 30, 2015, 10:48:06 Nachmittag »
I'm sorry I do not Skype, is there some other way for me to provide the information you require?
Gespeichert
Administrator
Hero Member
Re:Solo 4k
Antwort #3 am:
Oktober 31, 2015, 01:22:14 Vormittag »
can you join the chatroom tomorrow?
http://chat.sundtek.de
if that one causes issues for you - you might use an alternative chat:
http://webchat.freenode.net
Channel #sundtek
Gespeichert
DaMacFunkin
Newbie
Re:Solo 4k
Antwort #4 am:
Oktober 31, 2015, 09:28:05 Vormittag »
Yes what time? I can be available from 9 am GMT.
Gespeichert
DaMacFunkin
Newbie
Re:Solo 4k
Antwort #5 am:
Oktober 31, 2015, 11:23:17 Vormittag »
Hello, i am on chat now.
Gespeichert
Administrator
Hero Member
Re:Solo 4k
Antwort #6 am:
Oktober 31, 2015, 12:57:46 Nachmittag »
The next driver update later today will have full support for the solo4k. I have set it up manually for now on your system.
Gespeichert
DaMacFunkin
Newbie
Re:Solo 4k
Antwort #7 am:
Oktober 31, 2015, 01:10:02 Nachmittag »
my box has just locked up again like it did before, i changed channel to check if the video was smooth because it looked a little bit twitchy and after a few seconds it has locked up?
Gespeichert
DaMacFunkin
Newbie
Re:Solo 4k
Antwort #8 am:
Oktober 31, 2015, 01:17:19 Nachmittag »
It rebooted from telnet command, will continue to test.
Gespeichert
Administrator
Hero Member
Re:Solo 4k
Antwort #9 am:
Oktober 31, 2015, 01:19:49 Nachmittag »
if you keep having issues join the chat again.
Gespeichert
DaMacFunkin
Newbie
Re:Solo 4k
Antwort #10 am:
Oktober 31, 2015, 01:38:07 Nachmittag »
box has locked up again, i am on chat now.
Gespeichert
Administrator
Hero Member
Re:Solo 4k
Antwort #11 am:
Oktober 31, 2015, 02:12:23 Nachmittag »
Ok seems like the settopbox does not like the infrared support of our tuner (just like all the other VU+ settopboxes). I disabled it for now. The next driver update will disable it for all Sundtek devices for that new Settopbox.
USB Tuner Infrared Support is not needed anyway since you are using the original settopbox infrared.
The problem is that the USB Controller driver of the VU+ settopbox cannot handle USB interrupt transfers properly - which the USB tuner is using.
However for using the tuner it's all no problem since you only want the video data from it.
Gespeichert
DaMacFunkin
Newbie
Re:Solo 4k
Antwort #12 am:
Oktober 31, 2015, 05:19:41 Nachmittag »
I have to tell you I have another problem, I powered box off and inserted sundtek sky dvb-s2 stick and the box would not boot with both USB tuners plugged in.
I turned box off, unplugged -s2 stick and box booted fine with dvb-c still installed.
Gespeichert
Administrator
Hero Member
Re:Solo 4k
Antwort #13 am:
Oktober 31, 2015, 05:38:11 Nachmittag »
Let's wait for the update which disables the IR support on that settopbox first because the DVB-S/S2 tuner is still affected by this problem on your side.
The IR support is loaded as soon as the driver is loaded - even before engima2.
Gespeichert
Administrator
Hero Member
Re:Solo 4k
Antwort #14 am:
November 01, 2015, 11:34:48 Vormittag »
the driver has been updated.
Gespeichert
Drucken
Seiten: [
1
2
« vorheriges
nächstes »
English
Solo 4k
