I'm looking for help on making diseqc work in network mode.
2 satellites, HotBird (diseqc port 0) + Astra (diseqc port 1) on a diseqc 1.2 compliant switch
1) my working setup (networking off):
- raspberrypi on debian
- usb sundtek stick with latest netinst driver
- latest tvheadend from git
2) my failing setup (network mode on)
system A (sat cable is here)
- usb sundtek stick with latest netinst driver + network mode on
system B
- linux PC on debian wheezy
- latest sundtek netinst driver with network mount to system A
The tvheadend configuration is the same on both setups, but on setup 1 when tvheadend starts the tuning the diseqc switch is correctely set to port A for hotbird scanning and to port B for astra scanning.
On setup 2 (network mode) I see from mediaserver log that system A receives diseqc port B switching request before tuning to every single transponder. This happens even if I only configure 1 diseqc port in tvheadend.
I tried to send diseqc commands from mediaclient but I allways get an unrecognized option as a result, do you have any ideas on how to troubleshoot this?
thanks a lot,
btw I love network mode :-)
Alex.
