Autor Thema: Sundtek Streaming Server (Englisch / English)  (Gelesen 28361 mal)
« am: Juni 24, 2016, 06:43:14 Vormittag »
German Version | English Version
This streamingserver is already integrated into the MacOSX driver
Following is the installation procedure on regular Linux systems:
sudo /opt/bin/mediaclient --installstreamer
(Please restart the system after the update)
The tuner can then be configured via the web interface
Http: // localhost: 22000
The streamingserver is compatible with :
* Most Linux based systems (eg. Debian, Ubuntu, Suse, Redhat, Fedora, ...)
*Routers (eg. AVM (Fritzbox 7490), TP-Link (using DD-WRT/OPENWRT),Netgear (DD-WRT/OPENWRT)
*NAS Systems (QNAP, Synology, XPenology,etc)
*Raspberry PI
*as mentioned MacOSX
*FreeBSD
*Windows
  The streamingserver is also ported to Windows, we have already created a port successfully under Windows.
  (Windows 10 as well as Windows 7 were tested so far, the switching times are about 1-2 seconds)
And streams can also be added to Kodi, XBMC.
Updates:
23. Juni 2016
- rewriting SDT Table in order to improve channel switching with VLC
- database will be re-initialized once the streamingserver gets updated
- added Frequency table for UPC Switzerland
- added MacOSX Hibernation support
Once the streamingserver is installed the driver will start it automatically.
Multiple clients are able to stream individual programs at the same time, multiple devices are also supported. Currently supported standards (DVB-C, DVB-T/T2, DVB-S/S2, ATSC, ISDB-T)
EPG will be parsed completely (usually up to 2 weeks in Europe, eg. for German TV Stations)
Once the device is set up via the website following playlists will be available:
http://localhost:22000/freesdtv.m3u
http://localhost:22000/freehdtv.m3u
http://localhost:22000/radio.m3u
First page (if device is not set up):
[UPDATE] Setup:
The menu will be extended automatically depending on the scan result:
SDTV Channels:
Filter Options:
Available playlists:
« Letzte Änderung: April 02, 2017, 09:39:46 Vormittag von Sundtek »
DidierB
Re:Sundtek Streaming Server (Englisch / English)
« Antwort #1 am: August 23, 2016, 11:44:14 Vormittag »
two small questions:
1. is this streaming server also working for analog tv?
2. how to configure kodi to read tv stream from your streaming server. is there a dedicated PVR addon for the sundtek streaming server or do I need to use an exiting one (like vdr or tvheadend) and configure it properly?
Thanks
« Antwort #2 am: August 23, 2016, 11:50:44 Vormittag »
currently it only supports Digital TV.
We are adding FM Radio and DAB / DAB+ Support at the moment, afterwards possibly AnalogTV.
Digital TV can be used using kodi's IPTV Simple plugin.
The server is work in progress.
DidierB
« Antwort #3 am: August 23, 2016, 01:19:05 Nachmittag »
thanks for your reply,
it would be nice to have the analog tv supported but I understand it's not high priority ;-)
I tried it for DVB-c channels and I had some issues:
first of all the web interface is all in german which makes it quite complex for me to make the first setup.
--> is there a way to switch to english for the web interface?
secondly, I'm located in Belgium (french speaking part of the country) and the only provider available in the predefined frequencies list is from the flemish region -IN.DI-Integan- . using this predefined set I found only 10 paytv channels for which I have no subscription, so I can't use them.
I then tried with the automatic search ("Automatischer Suchlauf" google translate helped me here) but I was not able to find other channels.
FYI, I've been able to use the sundtek stick with tvheadend for dvb-c channels, I had the same issue (no predefined channels list for my provider -VOO-) but in tvheadend I was able to create manually the dvb-c muxes (frequencies) to get freetv channels and radio channels working.
--> I can provide you the muxes detailled info
tomorrow I'll try to look for dvb-t channels.
Thanks
« Antwort #4 am: August 23, 2016, 02:04:06 Nachmittag »
English will be available with one of the next updates.
Can you provide the channel list?
I think we will add some feature to allow a detailed background scan in the future.
DidierB
« Antwort #5 am: August 23, 2016, 02:35:20 Nachmittag »
here is the content of the channels.conf file:
NPO1;Voo:314000:M64:C:6900:160+1300=2:80=fre@4:40:186C,100,181D,1850,500:10601:0:0:0
Piwi+;Voo:314000:M64:C:6900:161=2:84=fre@4:0:186C,100,181D,1850:10602:0:0:0
13ème Rue;Voo:314000:M64:C:6900:162=2:88=fre@4,89=eng:0;42,142:186C,100,181D,1850,500:10603:0:0:0
Mediaset Italia;Voo:314000:M64:C:6900:163=2:92=ita@4:0:186C,100,181D,1850:10604:0:0:0
Rai 3;Voo:314000:M64:C:6900:164=2:96=ita@4:44:186C,100,181D,1850,500:10605:0:0:0
Nat Geo Channel;Voo:314000:M64:C:6900:165=2:100=gre@4:0:186C,100,181D,1850,500:10606:0:0:0
RTP Internacional;Voo:314000:M64:C:6900:166=2:104=por@4:46:186C,100,181D,1850,500:10607:0:0:0
Ushuaïa TV;Voo:314000:M64:C:6900:167=2:108=fre@4:0;47:186C,100,181D,1850:10608:0:0:0
Be 1+1h;Voo:330000:M64:C:6875:161=2:84=fre@4,85=eng:41:186C,100,181D,1812,1850:102:1:1:0
Be Séries;Voo:330000:M64:C:6875:163=2:92=fre@4,93=eng:43:186C,100,181D,1812,1850:104:1:1:0
Be Sport 1;Voo:330000:M64:C:6875:164=2:96=fre@4:0:186C,100,181D,1812,1850:105:1:1:0
Be Sport 2;Voo:330000:M64:C:6875:165=2:100=fre@4:0:186C,100,181D,1812,1850:106:1:1:0
Be 1;Voo:330000:M64:C:6875:166=2:104=fre@4,105=eng:46:186C,100,181D,1812,1850:107:1:1:0
Be Ciné;Voo:330000:M64:C:6875:167=2:108=fre@4,109=eng:47:186C,100,181D,1812,1850:108:1:1:0
VOOsport 1;Voo:330000:M64:C:6875:168=2:112=fre@4:0:186C,100,181D,1812,1850:109:1:1:0
VOOsport 1;Voo:330000:M64:C:6875:168=2:112=fre@4:0:186C,100,181D,1812,1850:119:1:1:0
June;Voo:322000:M64:C:6900:160=2:81=eng@4,80=fre:0;40,140:186C,100,181D,1850:601:0:0:0
VH1 Classic;Voo:322000:M64:C:6900:161=2:84=fre@4:0:186C,100,181D,1850:602:0:0:0
Trace Urban;Voo:322000:M64:C:6900:162=2:88=fre@4:0:186C,100,181D,1850:603:0:0:0
Bloomberg;Voo:322000:M64:C:6900:163=2:92=eng@4:0:186C,100,181D,1850:604:0:0:0
BFM TV;Voo:322000:M64:C:6900:164=2:96=fre@4:0:186C,100,181D,1850,500:605:0:0:0
Nat Geo Wild;Voo:322000:M64:C:6900:165=2:100=fre@4:0:186C,100,181D,1850:606:0:0:0
Histoire;Voo:322000:M64:C:6900:167=2:108=fre@4:0;147:186C,100,181D,1850:608:0:0:0
Extreme Sports;Voo:322000:M64:C:6900:168=2:112=fre@4:0:186C,100,181D,1850:609:0:0:0
Fashion TV;Voo:322000:M64:C:6900:170=2:120=fre@4:0:186C,100,181D,1850:611:0:0:0
CNN;Voo:338000:M64:C:6900:160=2:80=eng@4:0:186C,100,181D,1850,500:10301:0:0:0
MTV;Voo:338000:M64:C:6900:161=2:84=fre@4:41:186C,100,181D,1850,500:10302:0:0:0
MCM;Voo:338000:M64:C:6900:162=2:88=fre@4:0;142:186C,100,181D,1850:10303:0:0:0
M6 Boutique & Co;Voo:338000:M64:C:6900:163=2:92=fre@4:0:186C,100,181D,1850:10304:0:0:0
BBC 1;Voo:338000:M64:C:6900:164=2:96=fre@4:44:186C,100,181D,1850,500:10305:0:0:0
TV5 Monde;Voo:338000:M64:C:6900:165=2:100=fre@4:45:186C,100,181D,1850,500:10306:0:0:0
Euronews;Voo:338000:M64:C:6900:166=2:104=fre@4,105=eng,106=ger,107=ita:0:186C,100,181D,1850,500:10307:0:0:0
BBC 2;Voo:338000:M64:C:6900:167=2:112=fre@4:47:186C,100,181D,1850,500:10308:0:0:0
CBBC/BBC 3;Voo:338000:M64:C:6900:168=2:116=fre@4:48:186C,100,181D,1850:10309:0:0:0
CBeebies/BBC 4;Voo:338000:M64:C:6900:169=2:120=fre@4:49:186C,100,181D,1850:10310:0:0:0
La Une;Voo:346000:M64:C:6900:160=2:80=fre@4,81=eng:40:1850,100,181D,500,186C:10801:0:0:0
La Deux;Voo:346000:M64:C:6900:161=2:84=fre@4,85=eng:41:1850,100,181D,500,186C:10802:0:0:0
La Trois;Voo:346000:M64:C:6900:162=2:88=fre@4,89=eng:42:0:10803:0:0:0
RTL TVI;Voo:346000:M64:C:6900:163=2:92=fre@4:43:100,181D,1850,500,186C:10804:0:0:0
Club RTL;Voo:346000:M64:C:6900:164=2:96=fre@4:44:1850,100,181D,500,186C:10805:0:0:0
Plug RTL;Voo:346000:M64:C:6900:165=2:100=fre@4:45:1850,100,181D,500,186C:10806:0:0:0
Bel RTL;Voo:346000:M64:C:6900:0:120=fre@3:0:0:10811:0:0:0
Mint;Voo:346000:M64:C:6900:0:124=fre@3:0:0:10812:0:0:0
Radio Contact;Voo:346000:M64:C:6900:0:128=fre@3:0:0:10813:0:0:0
Contact R'n'B;Voo:346000:M64:C:6900:0:136=fre@3:0:0:10815:0:0:0
TF1;Voo:354000:M64:C:6900:160=2:80=fre@4,81=eng,82=qad:0;40,140:186C,100,181D,1850,500:10401:0:0:0
France 2;Voo:354000:M64:C:6900:161=2:84=fre@4,85=eng,86=qad:41:186C,100,181D,1850,500:10402:0:0:0
France 3;Voo:354000:M64:C:6900:162=2:88=fre@4:42:186C,100,181D,1850,500:10403:0:0:0
France 4;Voo:354000:M64:C:6900:163=2:92=fre@4,93=qad:43:186C,100,181D,1850,500:10404:0:0:0
France 5;Voo:354000:M64:C:6900:164=2:96=fre@4,97=qad:44:186C,100,181D,1850,500:10405:0:0:0
TV Breizh;Voo:354000:M64:C:6900:165=2:100=fre@4:0;45,145:186C,100,181D,1850,500:10406:0:0:0
France Ô;Voo:354000:M64:C:6900:166=2:104=fre@4:0;46:186C,100,181D,1850,500:10407:0:0:0
France 24;Voo:354000:M64:C:6900:167=2:108=fre@4:0:186C,100,181D,1850,500:10408:0:0:0
Boomerang;Voo:354000:M64:C:6900:168=2:112=fre@4,113=eng:0;48,148:186C,100,181D,1850:10409:0:0:0
Kombat Sport;Voo:362000:M64:C:6900:160=2:80=fre@4:0:186C,100,181D,1850:201:0:0:0
TéléToon+;Voo:362000:M64:C:6900:161=2:84=fre@4:0;141:186C,100,181D,1850:202:0:0:0
Melody;Voo:362000:M64:C:6900:162=2:88=fre@4:0:186C,100,181D,1850:203:0:0:0
AB Moteurs;Voo:362000:M64:C:6900:163=2:92=fre@4:0:186C,100,181D,1850:204:0:0:0
Animaux;Voo:362000:M64:C:6900:164=2:96=fre@4:0:186C,100,181D,1850:205:0:0:0
Chasse & Pêche;Voo:362000:M64:C:6900:165=2:100=fre@4:0:186C,100,181D,1850:206:0:0:0
XXL;Voo:362000:M64:C:6900:166=2:104=fre@4:0:186C,100,181D,1850:207:0:0:0
Toute l'Histoire;Voo:362000:M64:C:6900:167=2:108=fre@4:0:186C,100,181D,1850:208:0:0:0
Action;Voo:362000:M64:C:6900:168=2:112=fre@4:0:186C,100,181D,1850:209:0:0:0
Mangas;Voo:362000:M64:C:6900:169=2:116=fre@4:0:186C,100,181D,1850:210:0:0:0
Dorcel TV;Voo:370000:M64:C:6900:160=2:80=fre@4:0:186C,100,181D,1850:301:0:0:0
Planète+;Voo:370000:M64:C:6900:161=2:84=fre@4:0;141:186C,100,181D,1850:302:0:0:0
Voyage;Voo:370000:M64:C:6900:162=2:88=fre@4:0;142:186C,100,181D,1850:303:0:0:0
Canal J;Voo:370000:M64:C:6900:163=2:92=fre@4:0;143:186C,100,181D,1850:304:0:0:0
Cartoon Network;Voo:370000:M64:C:6900:175=2:100=fre@4,101=eng:0;45,145:186C,100,181D,1850,500:306:0:0:0
TCM Cinéma;Voo:370000:M64:C:6900:166=2:104=fre@4,105=eng:46:186C,100,181D,1850:307:0:0:0
Ciné+ Premier;Voo:370000:M64:C:6900:167=2:108=fre@4,109=eng:47:186C,100,181D,1850:308:0:0:0
Ciné+ Classic;Voo:370000:M64:C:6900:168=2:112=fre@4,113=eng:48:186C,100,181D,1850:309:0:0:0
Ciné+ Frisson;Voo:370000:M64:C:6900:169=2:116=fre@4,117=eng:49:186C,100,181D,1850:310:0:0:0
Eén;Voo:378000:M64:C:6900:160=2:80=fre@4,81=fre:40:186C,100,181D,1850,500:10101:0:0:0
Canvas;Voo:378000:M64:C:6900:161=2:84=fre@4:41:186C,100,181D,1850,500:10102:0:0:0
AB3;Voo:378000:M64:C:6900:162=2:88=fre@4:42:186C,100,181D,1850,500:10103:0:0:0
AB4;Voo:378000:M64:C:6900:163=2:92=fre@4:43:186C,100,181D,1850,500:10104:0:0:0
LCI;Voo:378000:M64:C:6900:164=2:96=fre@4:0:186C,100,181D,1850:10105:0:0:0
Canal C;Voo:378000:M64:C:6900:174=2:136=fre@4:0:186C,100,181D,1850,500:10115:0:0:0
HD1;Voo:386000:M64:C:6900:161=2:84=fre@4,85=eng:0;41,141:186C,100,181D,1850:502:0:0:0
Tiji;Voo:386000:M64:C:6900:163=2:92=fre@4:0:186C,100,181D,1850:504:0:0:0
Science & Vie TV;Voo:386000:M64:C:6900:164=2:96=fre@4:0:186C,100,181D,1850:505:0:0:0
Boing;Voo:386000:M64:C:6900:166=2:105=eng@4,104=fre:0;46,146:186C,100,181D,1850:507:0:0:0
Vivolta;Voo:386000:M64:C:6900:167=2:108=fre@4:0:186C,100,181D,1850:508:0:0:0
Planète+ C&I;Voo:386000:M64:C:6900:168=2:112=fre@4:0;148:186C,100,181D,1850:509:0:0:0
Syfy;Voo:386000:M64:C:6900:169=2:116=fre@4,117=eng:0;49,149:186C,100,181D,1850:510:0:0:0
BBC 1 HD;Voo:394000:M256:C:6900:160=27:0;80:40:186C,100,181D,1850,500:20301:0:0:0
TCM Cinéma HD;Voo:394000:M256:C:6900:161=27:0;84,85:41:186C,100,181D,1850:20302:0:0:0
Disney Cinema HD;Voo:394000:M256:C:6900:162=27:0;88,89:0;42,142:186C,100,181D,1850:20303:0:0:0
VIDEOWALL1;Voo:394000:M256:C:6900:163=27:2000=fre@4,2002=fre,2004=fra,2006=fra,2008=fra,2010=fra,2012=fra,2014,2016=fra,2018=fra,2020=fra,2022=fra,2024=fra,2026=fra,2028=fra,2030=fra,2032=fre,2034=fre,2036=fre,2038=fra,2040=fra,2042=fra,2044=fra,2046=fra,2048=fra,2050=fra,2052=fra,2054=fra,2056=fra,2058=fre,2060=fra,2062=fra:0:186C,100,181D,1850:20304:0:0:0
VIDEOWALL2;Voo:394000:M256:C:6900:164=27:3000=fra@4,3002=fre,3004=fre,3006=fre,3008=fre,3010=fre,3012=fre,3014=fre,3016=fra,3018=fra,3020=fra,3022=fra,3024=fra,3026=fra,3028=fra,3030=fra,3032=fra,3034=fra,3036=fra,3038=fra,3040=fre,3042=dut,3044=qaa,3046=fra,3048=fra,3050=fra,3052=fra,3054=fre,3056=fre,3058=fre,3060=fra,3062=fre:0:186C,100,181D,1850:20305:0:0:0
France 2 HD;Voo:394000:M256:C:6900:165=27:0;100,101,102:45:186C,100,181D,1850,500:20306:0:0:0
Be 1 HD;Voo:402000:M256:C:6900:160=27:0;80,81:0;40:186C,100,181D,1812,1850:901:0:0:0
Be Séries HD;Voo:402000:M256:C:6900:161=27:0;84,85:0;41:186C,100,181D,1812,1850:902:0:0:0
Be Ciné HD;Voo:402000:M256:C:6900:162=27:0;88,89:0;42:186C,100,181D,1812,1850:903:0:0:0
Be Sport 1 HD;Voo:402000:M256:C:6900:164=27:0;96:0:186C,100,181D,1812,1850:905:0:0:0
VOOsport 1 HD;Voo:402000:M256:C:6900:165=27:0;100:0:186C,100,181D,1850:906:0:0:0
La Une HD;Voo:410000:M256:C:6900:160+1300=27:0;80,81:40:1850,100,181D,500,186C:20101:0:0:0
La Deux HD;Voo:410000:M256:C:6900:161+1301=27:0;84,85:41:1850,100,181D,500,186C:20102:0:0:0
La Trois HD;Voo:410000:M256:C:6900:162+1302=27:0;88,89:42:0:20103:0:0:0
TF1 HD;Voo:410000:M256:C:6900:163=27:0;92,93,94:0;43,143:1850,100,181D,500,186C:20104:0:0:0
13ème Rue HD;Voo:410000:M256:C:6900:164=27:0;96,97:0;44,144:1850,100,181D,186C,500:20105:0:0:0
RTL TVI HD;Voo:418000:M256:C:6900:160+1300=27:0;80:40:181D,100,1850,500,186C:20201:0:0:0
Club RTL HD;Voo:418000:M256:C:6900:161+1301=27:0;84:41:500,181D,100,1850,186C:20202:0:0:0
Plug RTL HD;Voo:418000:M256:C:6900:162+1302=27:0;88:42:500,1850,181D,100,186C:20203:0:0:0
Arte Belgique HD;Voo:418000:M256:C:6900:163+1303=27:0;92,93,94:43:500,1850,181D,100,186C:20204:0:0:0
Ushuaïa TV HD;Voo:418000:M256:C:6900:164=27:0;96:0;44:181D,100,1850,186C:20205:0:0:0
MCM Top;Voo:126500:M64:C:6875:160=2:80=fre@4:0;140:186C,100,181D,1850:701:1:7:0
RFM TV;Voo:126500:M64:C:6875:161=2:84=fre@4:0;141:186C,100,181D,1850:702:1:7:0
I> TELE;Voo:126500:M64:C:6875:162=2:88=fre@4:0:186C,100,181D,1850:703:1:7:0
E!;Voo:126500:M64:C:6875:163=2:92=fre@4:0:186C,100,181D,1850:704:1:7:0
CBS Reality;Voo:126500:M64:C:6875:164=2:96=eng@4:0:186C,100,181D,1850:705:1:7:0
Nautical Channel;Voo:126500:M64:C:6875:175=2:100=fre@4,101=eng:0:186C,100,181D,1850:706:1:7:0
Seasons;Voo:126500:M64:C:6875:167=2:108=fre@4:0;147:186C,100,181D,1850:708:1:7:0
Motors TV;Voo:126500:M64:C:6875:168=2:112=fre@4:0:186C,100,181D,1850:709:1:7:0
Be Sport 3;Voo:118500:M64:C:6875:160=2:80=fre@4:0:186C,100,181D,1812,1850:801:1:8:0
VOOsport 2;Voo:118500:M64:C:6875:161=2:84=fre@4:0:186C,100,181D,1812,1850:802:1:8:0
VOOsport 3;Voo:118500:M64:C:6875:162=2:88=fre@4:0:186C,100,181D,1812,1850:803:1:8:0
VOOsport 4;Voo:118500:M64:C:6875:163=2:92=fre@4:0:186C,100,181D,1812,1850:804:1:8:0
VOOsport 5;Voo:118500:M64:C:6875:164=2:96=fre@4:0:186C,100,181D,1812,1850:805:1:8:0
MTV Hits;Voo:306000:M64:C:6875:160=2:80=fre@4:0:186C,100,181D,1850:401:1:106:0
M6 Music;Voo:306000:M64:C:6875:161=2:84=fre@4:0;141:186C,100,181D,1850:402:1:106:0
Comédie+;Voo:306000:M64:C:6875:162=2:88=fre@4,89=eng:0;42:186C,100,181D,1850:403:1:106:0
Disney XD;Voo:306000:M64:C:6875:163=2:93=eng@4,92=fre:0;43,143:186C,100,181D,1850:404:1:106:0
Planète+ A&E;Voo:306000:M64:C:6875:164=2:96=fre@4:0:186C,100,181D,1850:405:1:106:0
MCS Tennis;Voo:306000:M64:C:6875:165=2:100=fre@4:0:186C,100,181D,1850:406:1:106:0
Mezzo;Voo:306000:M64:C:6875:166=2:104=fre@4:0:186C,100,181D,1850:407:1:106:0
Game One;Voo:306000:M64:C:6875:167=2:108=fre@4:0:186C,100,181D,1850:408:1:106:0
Ma Chaîne Sport;Voo:306000:M64:C:6875:168=2:112=fre@4:0:186C,100,181D,1850,500:409:1:106:0
Disney Cinema;Voo:306000:M64:C:6875:169=2:116=fre@4,117=eng:0;49,149:186C,100,181D,1850:410:1:106:0
TRT;Voo:134500:M64:C:6875:160=2:80=tur@4:0:186C,100,181D,1850,500:10201:1:110:0
Rai 1;Voo:134500:M64:C:6875:162=2:88=ita@4:42:186C,100,181D,1850,500:10203:1:110:0
ZDF;Voo:134500:M64:C:6875:163=2:92=ger@4:43:186C,100,181D,1850,500:10204:1:110:0
CNBC;Voo:134500:M64:C:6875:164=2:96=eng@4:0:186C,100,181D,1850:10205:1:110:0
TVE;Voo:134500:M64:C:6875:165=2:100=spa@4:0:186C,100,181D,1850,500:10206:1:110:0
NPO2;Voo:134500:M64:C:6875:166+1306=2:104=fre@4:46:186C,100,181D,1850,500:10207:1:110:0
Canal 24 Horas;Voo:134500:M64:C:6875:167=2:108=spa@4:0:186C,100,181D,1850:10208:1:110:0
Al Aoula;Voo:134500:M64:C:6875:168=2:112=ara@4:0:186C,100,181D,1850,500:10209:1:110:0
Disney Junior;Voo:134500:M64:C:6875:161=2:84=fre@4:0:186C,100,181D,1850,500:10202:1:110:0
VOO;Voo:142500:M64:C:6875:160=2:80=fre@4:0:0:10501:1:111:0
Disney Channel;Voo:142500:M64:C:6875:161=2:84=fre@4:41:186C,100,181D,1850,500:10502:1:111:0
Gulli;Voo:142500:M64:C:6875:162=2:88=fre@4:0:186C,100,181D,1850:10503:1:111:0
Equidia Live;Voo:142500:M64:C:6875:163=2:92=fre@4:0:186C,100,181D,1850:10504:1:111:0
Radio Contact Vision;Voo:142500:M64:C:6875:164=2:104=fre@4:0:186C,100,181D,1850,500:10505:1:111:0
Nickelodeon;Voo:142500:M64:C:6875:166=2:116=fre@4:46:186C,100,181D,1850,500:10507:1:111:0
La Première;Voo:142500:M64:C:6875:0:120=fre@4:0:186C,100,181D,1850,500:10508:1:111:0
Classic21;Voo:142500:M64:C:6875:0:124=fre@4:0:186C,100,181D,1850,500:10509:1:111:0
Musiq3;Voo:142500:M64:C:6875:0:128=fre@4:0:186C,100,181D,1850,500:10510:1:111:0
VivaCité;Voo:142500:M64:C:6875:0:132=fre@4:0:186C,100,181D,1850,500:10511:1:111:0
BRF;Voo:142500:M64:C:6875:0:136=ger@4:0:186C,100,181D,1850,500:10512:1:111:0
Pure FM;Voo:142500:M64:C:6875:0:140=fre@4:0:186C,100,181D,1850,500:10513:1:111:0
Sundance Channel;Voo:142500:M64:C:6875:173=2:144=fre@4:0:186C,100,181D,1850:10514:1:111:0
D17;Voo:142500:M64:C:6875:174=2:148=fre@4:0:186C,100,181D,1850:10515:1:111:0
DH Radio;Voo:142500:M64:C:6875:0:152=fre@4:0:186C,100,181D,1850:10516:1:111:0
Ketnet;Voo:150500:M64:C:6875:160=2:80=fre@4:40:186C,100,181D,1850,500:11001:1:106:0
Arte Belgique;Voo:150500:M64:C:6875:161=2:86=eng@4,84=fre,85=ger:41:186C,100,181D,1850,500:11002:1:106:0
ARD;Voo:150500:M64:C:6875:162=2:88=ger@4:42:186C,100,181D,1850,500:11003:1:106:0
BRF-TV;Voo:150500:M64:C:6875:164=2:96=ger@4:0:186C,100,181D,1850,500:11005:1:106:0
InfoSport+;Voo:150500:M64:C:6875:165=2:100=fre@4:0:186C,100,181D,1850:11006:1:106:0
Canal Z;Voo:150500:M64:C:6875:166=2:104=fre@4:0:186C,100,181D,1850,500:11007:1:106:0
PureVision;Voo:150500:M64:C:6875:167=2:108=fre@4:0:186C,100,181D,1850,500:11008:1:106:0
Eleven;Voo:150500:M64:C:6875:163=2:92=fre@4,93=dut:0:186C,100,181D,1850:11004:1:106:0
Eleven Sports;Voo:150500:M64:C:6875:168=2:112=fre@4,113=dut:0:186C,100,181D,1850:11009:1:106:0
« Antwort #6 am: August 23, 2016, 02:38:39 Nachmittag »
Thanks, we'll include it in the next update (possibly at the end of this week).
DidierB
« Antwort #7 am: August 30, 2016, 02:39:46 Nachmittag »
I'v again some questions
how can I see which version (build) is installed on my linux box and which is the latest version available and how to upgrade. Is it automatic?
how can I install the streaming server on a synology nas? I already installed the sundtek drivers on it.
« Antwort #8 am: August 30, 2016, 03:35:20 Nachmittag »
we will add a tab with the version info to the server with the next update.
Current things we're working on:
- DAB/DAB+ Radio Streaming support (streaming support is almost done, DAB/DAB+ service information will be added lateron)
- Recording Support for DVB (adding tv recording schedules)
For the Synology NAS we'll post the answer within the next days.
Tryon
« Antwort #9 am: April 09, 2017, 09:00:50 Nachmittag »
Hi!
Will there be eng setup? Auto scan is too long because it will scan many pay TV.
Please give us manual option to select few interesting mux. :-\
« Antwort #10 am: April 16, 2017, 06:10:12 Vormittag »
Yes we're working on that.
we're switching the server to utf8 at the moment as well to support different character sets.
Tryon
« Antwort #11 am: April 23, 2017, 06:30:16 Nachmittag »
It also seems that server use wrong address(localhost) when using UPnP feature of VLC from another computer.
It would be useful if server can announce availability of channels from current mux when first VLC is streaming(second VLC will only be able to tune to channels of current mux) 8)
virtualdj
« Antwort #12 am: September 06, 2017, 09:07:13 Nachmittag »
Sorry if I write here, but I don't understand Deutsche ;)
I'm preparing the QNAP QPKG for the Streaming Server, and it's almost done, but I have a question. The database where the playlist and/or channels are saved where is located?
I tried strace-ing rtspd but still I was unable to figure out where it is.
EDIT: It was under my eyes... /opt/bin/sundtek.db!
Can I change this PATH to something else, maybe in the QPKG folder? How? I don't like having it hardcoded, especially in /opt which may not exist on the QNAP.
« Letzte Änderung: September 06, 2017, 09:39:30 Nachmittag von virtualdj »
« Antwort #13 am: September 07, 2017, 05:14:19 Nachmittag »
the next update will introduce:
--daemon .. to run the streamingserver as a server
--dbpath .. to add a custom database path
The requested issues from the other users are updated already.
Additionally the driverpackage will support another parameter (sundtek.conf):
streamingserver=/path/to/rtspd
dbpath=/path/to/alternative.db
« Letzte Änderung: September 07, 2017, 05:39:56 Nachmittag von Sundtek »
nfgb
Re: Sundtek Streaming Server (Englisch / English)
« Antwort #14 am: Oktober 05, 2018, 08:02:07 Nachmittag »
I've successfully started the streaming server on a linux however it doesn't start on my router (asus ac68u).  Is  there any special procedure for routers?
Additionally, the web interface is in German and I can't change it to English. I already tried to change it by going to SETUP->STREAMINGSERVER->Sprachen  and the choose english on the dropbox  but it does nothing. Is there any other way to change it to English or  ideally start the streaming server on English?
