Autor Thema: Update 30. November 2009  (Gelesen 7933 mal)
« am: November 30, 2009, 08:58:35 Vormittag »
Version: http://www.sundtek.com/support/empia_installer_091130.sh
* Network support in order to use the USB TV Stick remotely on different PCs in a LAN
http://support.sundtek.com/index.php/topic,179.0.html
* WSS Support, the driver supports WSS decoding and is able to return a callback
* Ubuntu 9.10 Update regarding the remote control, the driver now also tries to open /dev/uinput instead of /dev/input/uinput (as in previous Ubuntu versions)
* Ubuntu 9.10 udev, startscripts are also copied into /lib/udev/rules.d
* Modified the installer to check for files after extracting the driver files, it's a nicer way to do that but practically has no relevance.
* mediaclient returns a proper returnvalue when tuning and locking to an FM station.
* reworked pulseaudio support, the driver doesn't need to update the pulseaudio system configuration anymore in order to work with pulseaudio.
* closing the devicenodes happens in a synchronized way now, closing it will only return when the devicenode got internally released
* Analog TV is now registered in the hardware abstraction layer (HAL)
Our engineers are still looking into further reports in this forum.
« Letzte Änderung: November 30, 2009, 10:20:14 Nachmittag von Sundtek »
