Autor Thema: Sundtek Media TV Pro Stick erkennt DVB-C nicht (Linux)  (Gelesen 66334 mal)
chrisjan
Re:Sundtek Media TV Pro Stick erkennt DVB-C nicht (Linux)
« Antwort #30 am: Oktober 25, 2011, 05:18:09 Nachmittag »
Was mir jetzt am meisten in der Datei mediasrv.log aufgefallen ist, ist:
2011-10-25 06:58:50 [946] Enabling standby
2011-10-25 06:58:51 [946] SETTING DVB-C
2011-10-25 06:59:52 [946] Setting Frequency: 442000000
2011-10-25 06:59:52 [946] Setting Symbolrate: 6875000
2011-10-25 06:59:52 [946] Setting Modulation: 3
2011-10-25 06:59:53 [946] Channel found (442000000)
2011-10-25 06:59:53 [946] =============
2011-10-25 06:59:53 [946] Symbol rate: 6874893
2011-10-25 06:59:53 [946] Constellation: QAM64
2011-10-25 06:59:53 [946] Mirroring: Normal
2011-10-25 06:59:53 [946] Symbol rate: 6874898
2011-10-25 06:59:54 [946] THERE MUST BE A BUG WITH YOUR HARDWARE, PLEASE CHECK ISO/BULK TRANSFER MODE
2011-10-25 06:59:54 [946] Packetsize < 188 bytes is invalid, throwing it away and increasing corruption 140
2011-10-25 07:04:57 [946] Channel found (442000000)
2011-10-25 07:04:57 [946] =============
2011-10-25 07:04:57 [946] Symbol rate: 6874908
2011-10-25 07:04:57 [946] Constellation: QAM64
2011-10-25 07:04:57 [946] Mirroring: Normal
chrisjan
« Antwort #31 am: Oktober 25, 2011, 05:19:09 Nachmittag »
Oder nein: Das ist noch von dem manuellen Senderhinzufügen von heute in der früh, daran kann es wahrscheinlich nicht liegen
chrisjan
« Antwort #32 am: Oktober 25, 2011, 05:21:16 Nachmittag »
Hier der Dateiteil von vorhin:
2011-10-25 15:47:23 [1516] Starting up Multimedia Framework (Oct 21 2011 00:28:57)
2011-10-25 15:47:23 [1516] Detected DVB version.h
2011-10-25 15:47:23 [1516] API Version: 5.3
2011-10-25 15:47:23 [1516] Running on Linux (3.0.0-12-generic)
2011-10-25 15:47:23 [1520] Starting service processor (PID 1520)
2011-10-25 15:47:23 [1516] Detected: GenuineIntel
2011-10-25 15:47:23 [1516] This CPU supports: MMX and SSE
2011-10-25 15:47:23 [1516] scanning devices
2011-10-25 15:47:23 [1516] Scanning for drivers
2011-10-25 15:47:23 [1516] found lib: libdrv_em28xx.so
2011-10-25 15:47:23 [1516] found lib: libdrv_vivi.so
2011-10-25 15:47:23 [1516] found lib: libdrv_net.so
2011-10-25 15:47:23 [1516] Scanning for plugins
2011-10-25 15:47:23 [1516] *WARNING* could not open plugin path
2011-10-25 15:47:23 [1516] Starting up device manager
2011-10-25 15:47:23 [1516] unable to open /dev/misc
2011-10-25 15:47:23 [1516] scanning devices done
2011-10-25 15:47:23 [1516] attached devices:
2011-10-25 15:47:23 [1516] registering ID: 0
2011-10-25 15:47:23 [1516] disconnecting kernel driver
2011-10-25 15:47:23 [1520] Autostarting scripts in /etc/sundtek/
2011-10-25 15:47:23 [1520] executed all available items
2011-10-25 15:47:24 [1516] attaching Videodecoder
2011-10-25 15:47:26 [1516] attaching DVB-T, DVB-C
2011-10-25 15:47:26 [1516] Using second generation demodulator
2011-10-25 15:47:28 [1516] SETTING DVB-C
2011-10-25 15:47:28 [1516] demodulator successfully attached (DVBC)!
2011-10-25 15:47:28 [1516] requesting to attach tuner(s) now
2011-10-25 15:47:28 [1516] This device uses the second generation Tuner
2011-10-25 15:47:28 [1516] registering: adapter0/0
2011-10-25 15:47:28 [1516] registered virtual: /dev/dvb/adapter0/frontend0
2011-10-25 15:47:28 [1516] registered virtual: /dev/dvb/adapter0/demux0
2011-10-25 15:47:28 [1516] registered virtual: /dev/dvb/adapter0/dvr0
2011-10-25 15:47:28 [1516] registered virtual: /dev/video0
2011-10-25 15:47:28 [1516] registered virtual: /dev/radio0
2011-10-25 15:47:28 [1516] registered virtual: /dev/rds0
2011-10-25 15:47:28 [1516] registered virtual: /dev/vbi0
2011-10-25 15:47:28 [1516] Setting RC Protocol to NEC
2011-10-25 15:47:28 [1516] registered virtual: /dev/mediainput0
2011-10-25 15:47:28 [1516] IR Setup
2011-10-25 15:47:28 [1516] Infrared support enabled on startup
2011-10-25 15:47:28 [1516] Registering OSS emulation
2011-10-25 15:47:28 [1516] registered virtual: /dev/dsp0
2011-10-25 15:47:28 [1516] Sundtek MediaTV Driver loaded. This driver is licensed for non-commercial use
2011-10-25 15:47:28 [1516] with Sundtek MediaTV only
2011-10-25 15:47:28 [1516] Driver loaded within 5124 milliseconds
2011-10-25 15:47:28 [1516] Serial(0): HDVBTB
2011-10-25 15:47:28 [1976] RC: IR Event /dev/input/event11
2011-10-25 15:47:28 [1986] RC: IR Event /dev/input/event11
2011-10-25 15:47:30 [1516] Initial devicescan done, switching detection mode
2011-10-25 15:47:43 [1516] Enabling standby
chrisjan
« Antwort #33 am: Oktober 25, 2011, 08:25:21 Nachmittag »
Ich habe es nach langen rumprobieren geschafft!
Jetzt funktioniert es!
« Antwort #34 am: Oktober 26, 2011, 10:54:59 Vormittag »
Wir arbeiten aktuell an unserem eigenen Player welcher die Geräte dann optimal unterstützt, zudem ist der Player eine Hybridapplikation welche auch unter MacOSX funktioniert und auch den Netzwerkmodus einbindet.
Das wird dann in nächster Zeit alles einfacher machen.
