Autor Thema: Driver incompatible with latest second stage (ss84) Dreambox 800se  (Gelesen 28045 mal)
knallert
« am: September 30, 2011, 04:54:54 Nachmittag »
Sky ultimate stick will not work when upgrading Dreambox 800se to latest second stage (ss84). Tried different images all with the same result. The USB-stick isn't recognized by the box.
Re:Driver incompatible with latest second stage (ss84) Dreambox 800se
« Antwort #1 am: September 30, 2011, 05:39:42 Nachmittag »
Did you install our driver?
http://support.sundtek.com/index.php/topic,348.0.html
The device fully works with SSL84 and the latest driver.
knallert
« Antwort #2 am: September 30, 2011, 07:30:02 Nachmittag »
Yes, I used your driver and it worked with ss82 but stopped working under ss84. I reinstalled the driver several times with no luck.  Now, this was 10 days ago so I'll give it a try again.
« Antwort #3 am: September 30, 2011, 08:24:03 Nachmittag »
Too early, you are right 10 days ago the driver did not work with the new image.
There have been some updates with those images and we had to update the driver too.
Everything works at this time.
knallert
« Antwort #4 am: Oktober 01, 2011, 02:01:17 Nachmittag »
You're right, works with latest driver. Thanks!
