Autor Thema: Problem sundtek dvb-s2 x tvheadend multistream 5w  (Gelesen 111223 mal)
orahmed
« am: Juli 03, 2024, 12:38:13 Nachmittag »
Hi I have the Sundtek SkyTV Dual 2x card (DVB-S/S2/S2X) I receive dvb-s and dvbs2 channels very well with tvheadend But I find problems with dvbs2x channels multistream channels from Eutelsat 5 west b. (French channels) I receive the signal very well Once I update the mux parameters example (dvbs2 12648. 29500 v. 8/9. 8qbsk. Pls code: 121212 and pls mode: gold. Siid: 1,2, and 3) I only receive the same duplicate channels I use an Android tv box with coreelec 21 and raspberry 3b+ with libreelec 12 Same result Can you help me thanks in advance
Re: Problem sundtek dvb-s2 x tvheadend multistream 5w
« Antwort #1 am: Juli 03, 2024, 01:04:01 Nachmittag »
thank you for that information I will forward it to our technician for checking, it's a bit busy here this week (so the answer could take until friday / saturday).
orahmed
« Antwort #2 am: Juli 03, 2024, 11:03:02 Nachmittag »
Hi I just installed the same card (sundtek dvbs2x) on vu+solo2 with the installation of the drivers I scanned the same frequency 12648 and 12733 it gives me the same result only the same channels For example if I scan 12732 stream 1 it gives me (TF1. Nrj12. Rmc. Tfx..) if I scan 12732 stream 4 it gives me (TF1. Nrj12. Rmc. Tfx) the same channels so the problem comes from the card herself
orahmed
« Antwort #3 am: Juli 06, 2024, 01:17:39 Nachmittag »
Hi Yesterday I tried the French channels in multistream (frequency 12648 and 12732) with an octagon sf8008 device (eigma2 openpli 8.3) and it works very well We can have a solution for the sundtek dvbs2x SkyTV Dual vIII card I like using it with tvheadend thanks again
orahmed
« Antwort #4 am: Juli 08, 2024, 04:10:58 Nachmittag »
Hi I'm still waiting answer for French multistreams from Eutelsat 5w I bought this card just for that It's been a week since I asked the question but no answer.
orahmed
« Antwort #5 am: Juli 23, 2024, 01:20:41 Nachmittag »
Hello everyone It's been two weeks since I performed several combinations of rules on tvheadend and Eingma2 to resolve the problem but without result Finally I gave up It's been 15 days without answer only the number of views is increasing It’s really a shame and thank you as well
« Antwort #6 am: August 18, 2024, 10:31:52 Vormittag »
sorry our engineer just returned from vacation last week, the driver will be updated within the next few days we are using an Eutelsat 5 West B at 5.0°W satellite for testing. The stream_id is not forwarded in the current driver according to the engineer.
Simple to fix but we will just do some more testing, the driver should be released before 23rd August 24.
« Letzte Änderung: August 18, 2024, 10:51:44 Vormittag von Sundtek »
« Antwort #7 am: August 21, 2024, 11:00:04 Nachmittag »
I updated the documentation (for testing on the console/Terminal):
https://sundtek.com/wiki/index.php?title=Mediaclient#DVB-S.2FS2.2FS2X_Tuning
and added the corresponding Multistream options.
For the DVB Protocol, only DTV_STREAM_ID is used (it will forward the correct parameter to the driver now). So just about any existing application which supports Multistream will work with it.
To confirm that the correct transponder is tuned you can just run
it will scan the transport stream and display the services.
The drivers are updated, just run the netinstaller and it will update the drivers.
« Letzte Änderung: August 21, 2024, 11:07:02 Nachmittag von Sundtek »
orahmed
« Antwort #8 am: August 28, 2024, 11:38:57 Vormittag »
Hi I just saw your answer I was on vacation Thank you for your response I will test and see the result
orahmed
« Antwort #9 am: August 28, 2024, 03:41:58 Nachmittag »
Hi I did a driver update Now it works very well with tvheadend Thank you for your help
orahmed
« Antwort #10 am: August 05, 2025, 05:05:57 Nachmittag »
Hi I'm back with the same problem as before. It's been a long time since I used my Sundtek DVB-S2X SkyTV Dual 2X card. I noticed that Kodi is updating the driver to 2025. With TV Headend Qunad, I scan the providers for French multistream channel 12548 with different streams. I have duplicate channels. The same problem as before. Thanks.
« Antwort #11 am: August 05, 2025, 07:59:47 Nachmittag »
Sorry, we still haven't updated the multistream code in the latest driver - I will try to do that tomorrow morning. We had quite some updates in other areas recently.
orahmed
« Antwort #12 am: August 05, 2025, 09:03:03 Nachmittag »
Thanks for Because I'm stuck The tuner is installed on a server I have another question Can it be installed in Docker Casaos on Raspberry Pi? I installed it natively and it works, the only problem is the multistream issue But with TVHeadEnd on Docker, it doesn't see my tuners
« Antwort #13 am: August 06, 2025, 01:58:25 Nachmittag »
it can be installed inside a docker but you need to follow some guidelines.
The easiest way would be to set up a remote desktop session with rustdesk and we could go through it together. I have never seen that system before (it looks interesting). I could modify the driver installer to set up everything properly on that system.
orahmed
« Antwort #14 am: August 06, 2025, 04:34:17 Nachmittag »
Hi Is the multistream driver up to date?
