Autor Thema: FEC 8/9  (Gelesen 19313 mal)
andrew_j_w
FEC 8/9
« am: Juni 05, 2024, 05:19:39 Nachmittag »
Do the Sundtek drivers support an FEC of 8/9? It is needed for this multiplex. I'm struggling to tune it, and when using -F 8/9 with mediaclient it says error the FEC value.
This is my device in case it helps:
     STATUS: ACTIVE
     FESTATUS: ACTIVE
     LNBVOLTAGE: ENABLED
     LNBSUPPLY: USBPOWER
     FESTATUS: ACTIVE
Many thanks,
Andrew
Re: FEC 8/9
« Antwort #1 am: Juni 05, 2024, 07:32:26 Nachmittag »
The driver for this device doesn't use the FEC information submitted by the user, you can just write anything there.
The issue lies within mediaclient itself, FEC 8/9 is just not parsed there and that gives you the error; I think since 2014 we do not have any tuner which uses the FEC user information from the user. The tuner will auto-detect the FEC parameters for the given transponder.
For testing with mediaclient you can just pass any FEC value...
« Letzte Änderung: Juni 05, 2024, 08:25:33 Nachmittag von Sundtek »
andrew_j_w
Re: FEC 8/9
« Antwort #2 am: Juni 06, 2024, 11:45:02 Vormittag »
Thanks for the information. You're right, I can tune ok to this channel. I think my problem is an issue with MythTV or Minisatip, not the Sundtek device. I got confused by the error message when trying to tune myself.
Thanks,
Andrew
Re: FEC 8/9
« Antwort #3 am: Juni 06, 2024, 12:31:21 Nachmittag »
I will update this, thanks for reporting it. It's more a "optical" issue rather than a "functional" one.
