Autor Thema: Dual s2 device missing some transponders at blindscan  (Gelesen 20938 mal)
olci
« am: Februar 16, 2021, 07:03:03 Nachmittag »
Hello,
I tried blind scan feature on skytv dual device there are some missing transponders that device can't found
my old M88CS8001-S based STB was finding that missing transponders on blindscan
11053.00   H   DVB-S   QPSK   8000 3/4
12729.00   V   DVB-S2   8PSK   30000 2/3
device can lock both of transponders but can't find in blindscan
pi@raspberrypi:~ $ /opt/bin/mediaclient --readsignal=0 -d /dev/dvb/adapter0/frontend0 --band UNIVERSAL
SIGNAL: [.............................    ] ( 87%) SATQUALITY:  53%  SNR:  10  BER:      0 FREQ: 11053000   Hz LOCKED: YES SYS: DVB-S SYM: 8000000 FEC: FEC_3_4 MOD: QPSK VOLTAGE: H(18V) TONE: OFF
SIGNAL: [.............................    ] ( 87%) SATQUALITY:  55%  SNR:  10  BER:      0 FREQ: 11053000   Hz LOCKED: YES SYS: DVB-S SYM: 8000000 FEC: FEC_3_4 MOD: QPSK VOLTAGE: H(18V) TONE: OFF
SIGNAL: [.............................    ] ( 87%) SATQUALITY:  54%  SNR:  10  BER:      0 FREQ: 11053000   Hz LOCKED: YES SYS: DVB-S SYM: 8000000 FEC: FEC_3_4 MOD: QPSK VOLTAGE: H(18V) TONE: OFF
SIGNAL: [............................     ] ( 86%) SATQUALITY:  55%  SNR:  10  BER:      0 FREQ: 11053000   Hz LOCKED: YES SYS: DVB-S SYM: 8000000 FEC: FEC_3_4 MOD: QPSK VOLTAGE: H(18V) TONE: OFF
SIGNAL: [............................     ] ( 86%) SATQUALITY:  54%  SNR:  10  BER:      0 FREQ: 11053000   Hz LOCKED: YES SYS: DVB-S SYM: 8000000 FEC: FEC_3_4 MOD: QPSK VOLTAGE: H(18V) TONE: OFF
^C
SIGNAL: [........................         ] ( 72%) SATQUALITY:  83%  SNR:  14  BER:      0 FREQ: 12729000   Hz LOCKED: YES SYS: DVB-S2 SYM: 30000000 FEC: FEC_2_3 MOD: PSK_8 VOLTAGE: V(13V) TONE: ON
/opt/bin/mediaclient -e
     STATUS: ACTIVE
     FESTATUS: ACTIVE
     LNBVOLTAGE: ENABLED
     LNBSUPPLY: USBPOWER
     FESTATUS: STANDBY
/opt/bin/mediaclient --blindscan=/dev/dvb/adapter0/frontend0
DVB-S2 blindscan request
Scanning 13V Lowband
MODE: DVB-S2 FREQUENCY(MHz): 10957 SYMBOL_RATE: 6249000 MODULATION: PSK8 VOLTAGE: 13V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 10978 SYMBOL_RATE: 12500000 MODULATION: PSK8 VOLTAGE: 13V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 11052 SYMBOL_RATE: 30001000 MODULATION: PSK8 VOLTAGE: 13V TONE: OFF
MODE: DVB-S  FREQUENCY(MHz): 11094 SYMBOL_RATE: 30000000 MODULATION: QPSK VOLTAGE: 13V TONE: OFF
MODE: DVB-S  FREQUENCY(MHz): 11132 SYMBOL_RATE: 1798000 MODULATION: QPSK VOLTAGE: 13V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 11456 SYMBOL_RATE: 3199000 MODULATION: PSK8 VOLTAGE: 13V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 11477 SYMBOL_RATE: 6799000 MODULATION: PSK8 VOLTAGE: 13V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 11525 SYMBOL_RATE: 2220000 MODULATION: PSK8 VOLTAGE: 13V TONE: OFF
MODE: DVB-S  FREQUENCY(MHz): 11674 SYMBOL_RATE: 24444000 MODULATION: QPSK VOLTAGE: 13V TONE: OFF
Scanning 18V Lowband
MODE: DVB-S  FREQUENCY(MHz): 11044 SYMBOL_RATE: 4798000 MODULATION: QPSK VOLTAGE: 18V TONE: OFF
MODE: DVB-S  FREQUENCY(MHz): 11060 SYMBOL_RATE: 4819000 MODULATION: QPSK VOLTAGE: 18V TONE: OFF
MODE: DVB-S  FREQUENCY(MHz): 11095 SYMBOL_RATE: 30000000 MODULATION: QPSK VOLTAGE: 18V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 11178 SYMBOL_RATE: 30000000 MODULATION: QPSK VOLTAGE: 18V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 11787 SYMBOL_RATE: 20000000 MODULATION: PSK8 VOLTAGE: 18V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 11852 SYMBOL_RATE: 24999000 MODULATION: PSK8 VOLTAGE: 18V TONE: OFF
Scanning 13V Highband
MODE: DVB-S2 FREQUENCY(MHz): 11526 SYMBOL_RATE: 2220000 MODULATION: PSK8 VOLTAGE: 13V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 11557 SYMBOL_RATE: 30000000 MODULATION: QPSK VOLTAGE: 13V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 11674 SYMBOL_RATE: 24444000 MODULATION: QPSK VOLTAGE: 13V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 11854 SYMBOL_RATE: 30000000 MODULATION: QPSK VOLTAGE: 13V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 11915 SYMBOL_RATE: 30001000 MODULATION: QPSK VOLTAGE: 13V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 11957 SYMBOL_RATE: 27500000 MODULATION: QPSK VOLTAGE: 13V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 11998 SYMBOL_RATE: 11666000 MODULATION: PSK8 VOLTAGE: 13V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 12033 SYMBOL_RATE: 27500000 MODULATION: QPSK VOLTAGE: 13V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12072 SYMBOL_RATE: 27500000 MODULATION: PSK8 VOLTAGE: 13V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12187 SYMBOL_RATE: 27500000 MODULATION: PSK8 VOLTAGE: 13V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12212 SYMBOL_RATE: 5832000 MODULATION: PSK8 VOLTAGE: 13V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12263 SYMBOL_RATE: 27500000 MODULATION: PSK8 VOLTAGE: 13V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12309 SYMBOL_RATE: 14999000 MODULATION: PSK8 VOLTAGE: 13V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 12379 SYMBOL_RATE: 27500000 MODULATION: QPSK VOLTAGE: 13V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 12422 SYMBOL_RATE: 27500000 MODULATION: QPSK VOLTAGE: 13V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 12457 SYMBOL_RATE: 30001000 MODULATION: QPSK VOLTAGE: 13V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 12558 SYMBOL_RATE: 27500000 MODULATION: QPSK VOLTAGE: 13V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12685 SYMBOL_RATE: 30000000 MODULATION: PSK8 VOLTAGE: 13V TONE: ON
Scanning 18V Highband
MODE: DVB-S2 FREQUENCY(MHz): 11788 SYMBOL_RATE: 19999000 MODULATION: PSK8 VOLTAGE: 18V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 11852 SYMBOL_RATE: 24999000 MODULATION: PSK8 VOLTAGE: 18V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 11880 SYMBOL_RATE: 19999000 MODULATION: PSK8 VOLTAGE: 18V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 11977 SYMBOL_RATE: 27499000 MODULATION: QPSK VOLTAGE: 18V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 12014 SYMBOL_RATE: 27500000 MODULATION: QPSK VOLTAGE: 18V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 12053 SYMBOL_RATE: 27500000 MODULATION: QPSK VOLTAGE: 18V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12103 SYMBOL_RATE: 8333000 MODULATION: PSK8 VOLTAGE: 18V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12209 SYMBOL_RATE: 10000000 MODULATION: PSK8 VOLTAGE: 18V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12244 SYMBOL_RATE: 27500000 MODULATION: PSK8 VOLTAGE: 18V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12328 SYMBOL_RATE: 6664000 MODULATION: PSK8 VOLTAGE: 18V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 12335 SYMBOL_RATE: 5519000 MODULATION: QPSK VOLTAGE: 18V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 12378 SYMBOL_RATE: 30001000 MODULATION: QPSK VOLTAGE: 18V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 12422 SYMBOL_RATE: 30000000 MODULATION: QPSK VOLTAGE: 18V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12456 SYMBOL_RATE: 15000000 MODULATION: PSK8 VOLTAGE: 18V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12574 SYMBOL_RATE: 2499000 MODULATION: PSK8 VOLTAGE: 18V TONE: ON
MODE: DVB-S  FREQUENCY(MHz): 12610 SYMBOL_RATE: 20830000 MODULATION: QPSK VOLTAGE: 18V TONE: ON
MODE: DVB-S2 FREQUENCY(MHz): 12684 SYMBOL_RATE: 27500000 MODULATION: PSK8 VOLTAGE: 18V TONE: ON
Re: Dual s2 device missing some transponders at blindscan
« Antwort #1 am: Februar 16, 2021, 07:51:08 Nachmittag »
The Blindscan is running some algorithm for searching the 950-2150 band, a real scan should still try to use the NIT scan. Applications are usually using tables as well. That's nothing to worry about.
You might try to tune to one (or some of those transponders and run a nitscan)
/opt/bin/mediaclient --nitscan /dev/dvb/adapter0/dvr0
olci
« Antwort #2 am: Februar 16, 2021, 08:00:53 Nachmittag »
nitscan usually take much more time than blindscan but still i prefer nitscan over blindscan too
thanks
