Autor Thema: SkyTV VIII dual - enigma2  (Gelesen 80666 mal)
Re: SkyTV VIII dual - enigma2
« Antwort #15 am: März 04, 2021, 12:00:06 Nachmittag »
There are also other factors, you wrote the picture froze, on both tuners or what? Don't even take VU+ as a reference, things very much depend on the chipsets. Everything has its advantages and disadvantages.
SNR is only one factor, things are chipset and device dependent
« Letzte Änderung: März 04, 2021, 12:03:13 Nachmittag von Sundtek »
Dima73
« Antwort #16 am: März 04, 2021, 01:46:15 Nachmittag »
yes
Tryon
« Antwort #17 am: April 02, 2021, 09:39:36 Nachmittag »
Is it possible to make dynamic values, at least a little closer to reality?
I checked that dynamic values work very badly.
 I used was the VU+DVB-S dual tuner, so the calculation of the values is very accurate.
1)
VU+DVB-S dual tuner -->SNR 94%
Sundtek-->SNR 91%
2)
VU+DVB-S dual tuner -->SNR 64%
Sundtek-->SNR 90%
The value was very low and the picture on the HD channel began to freeze.
Any tuner should not report such high values in poor signal conditions(which can be simulated by misaligned dish or during the heavy rain)...
It also seems that yellow warning is present only when replying to topic:
Loading mixed (insecure) display content “http://support.sundtek.com/Smileys/default/smiley.gif” on a secure page ???
EDIT: or on any topic when such gifs are used!
« Letzte Änderung: April 02, 2021, 09:42:50 Nachmittag von Tryon »
Dima73
« Antwort #18 am: April 25, 2021, 09:58:17 Vormittag »
Loop through
Is internal loopback("Loop through") possible between the two tuners A<->B?
Dima73
« Antwort #19 am: April 27, 2021, 07:45:59 Nachmittag »
dvbloopback:
     --createadapter               create dvb loopback device
     --remove=[n]                  delete dvb loopback device
Dima73
« Antwort #20 am: Mai 04, 2021, 03:39:33 Nachmittag »
Solo 4K
Last drivers.
Connected together  tuner SkyTV VIII dual / tuner Sundtek SkyTV Ultimate IV.
No signal on both tuners.
Remove Sundtek SkyTV Ultimate IV, reboot solo4K, SkyTV VIII dual no signal.
Unplug the power adapter SkyTV VIII dual  temporarily,load  solo4K,  SkyTV VIII dual work fine.
Sundtek I just add the answer here, it must have been fixed for a long time already.
« Letzte Änderung: November 21, 2021, 11:02:27 Vormittag von Sundtek »
