Autor Thema: SkyTV Ultimate 8 ausgefallen  (Gelesen 20659 mal)
date
« am: April 29, 2019, 09:09:26 Nachmittag »
mein seit etwa 4 Monaten im Einsatz befindlicher SkyTV Ultimate 8 macht seit vorgestern keinen Muckser mehr.
Auszug aus syslog von VDR auf Linux-Kiste:
Apr 29 20:54:23 server2 vdr: [3840] VNSI: Channel: no data 16
Apr 29 20:54:23 server2 vdr: [3840] VNSI: exit streamer thread
Apr 29 20:54:23 server2 vdr: [3840] cLiveStreamer stream processor thread ended (pid=2449, tid=3840)
Apr 29 20:54:23 server2 vdr: [3596] VNSI: LiveStreamer::Close - close
Apr 29 20:54:23 server2 vdr: [3596] VNSI: close video input ...
Apr 29 20:54:23 server2 vdr: [3596] VNSI: Successfully found following device: 0x20045e0 (1) for receiving
Apr 29 20:54:23 server2 vdr: [3841] device 1 TS buffer thread ended (pid=2449, tid=3841)
Apr 29 20:54:23 server2 vdr: [3838] buffer stats: 0 (0%) used
Apr 29 20:54:23 server2 vdr: [3838] device 1 receiver thread ended (pid=2449, tid=3838)
Apr 29 20:54:23 server2 vdr: [4002] device 1 receiver thread started (pid=2449, tid=4002, prio=high)
Apr 29 20:54:23 server2 vdr: [3596] VNSI: Successfully switched to channel 1 - Das Erste HD
Apr 29 20:54:23 server2 vdr: [3596] VNSI: Started streaming of channel Das Erste HD (timeout 10 seconds)
Apr 29 20:54:23 server2 vdr: [4004] cLiveStreamer stream processor thread started (pid=2449, tid=4004, prio=high)
Apr 29 20:54:23 server2 vdr: [4003] VNSI: VideoInput: no pat/pmt within timeout, falling back to channel pids
Apr 29 20:54:23 server2 vdr: [4003] VNSI: Video Input - new pmt, attaching receiver
Apr 29 20:54:23 server2 vdr: [4005] device 1 TS buffer thread started (pid=2449, tid=4005, prio=high)
Apr 29 20:54:32 server2 vdr: [2454] frontend 0/0 timed out while tuning to channel 1 (Das Erste HD), tp 111493
Apr 29 20:54:33 server2 vdr: [4004] VNSI: Channel: no data 16
mediaclient -e
     FESTATUS: ACTIVE
     LNBVOLTAGE: ENABLED
     LNBSUPPLY: USBPOWER
Setup/ Verkabelung wurde schon länger nicht mehr angefasst. Testhalber habe ich auch die letzte Treiberversion vom 8. April installiert (wie zu erwarten hat sich am Zustand nichts geändert).
Ein zu Testzwecken angeschlossener SkyUltimat 4 funktioniert seit einem Tag problemlos (selbes Netzteil, selbes SAT- und USB-Kabel, selber USB-Port).
Hier noch mediaclient -e für den funktionierenden 4er:
device 0: [   SkyTV Ultimate IV]  DVB-S/S2, ANALOG-TV, REMOTE-CONTROL, OSS-AUDIO
     STATUS: ACTIVE
     FESTATUS: ACTIVE
     LNBVOLTAGE: ENABLED
     LNBSUPPLY: ACADAPTER
Ich kann vermutlich von einem Hardwaredefekt ausgehen?! Gibt es noch etwas was ich testen könnte?
Re: SkyTV Ultimate 8 ausgefallen
« Antwort #1 am: April 30, 2019, 05:55:48 Nachmittag »
was geben denn folgende Befehle aus?
/opt/bin/mediaclient -e
adapter0 durch den Adapter des jeweiligen Tuners austauschen.
Bei den Tunern wird's keine irreparablen Probleme geben, sollte ein Service benötigt werden kann das problemlos durchgeführt werden.
date
« Antwort #2 am: April 30, 2019, 11:35:49 Nachmittag »
die mediaclient -e Ausgabe hatte ich schon drin. Hier noch /opt/bin/mediaclient --testastra -d /dev/dvb/adapter0/frontend0 für den SkyTV Ultimate 8:
DVBS
LO Band / 18V:
LO Band / 13V:
HI Band / 18V:
HI Band / 13V:
DVB-S2 ZDF HD / 18V
zum Vergleich die Ausgabe des funktionierenden 4ers:
DVBS
LO Band / 18V:
LO Band / 13V:
HI Band / 18V:
HI Band / 13V:
DVB-S2 ZDF HD / 18V
.. [LOCKED]
« Antwort #3 am: April 30, 2019, 11:49:07 Nachmittag »
Schon mal versucht das Netzteil zu wechseln?
Der Empfang ist laut der Ausgabe gegeben, aber irgendetwas stimmt mit der LNB Stromversorgung nicht.
date
« Antwort #4 am: Mai 01, 2019, 12:04:24 Vormittag »
Weil es mich auch interessieren würde wie die Log-Ausgaben zu deuten sind: Woraus schließen Sie dass es Probleme mit der Stromversorgung geben könnte? Mit fällt nur auf dass bei dem 8er die "[LOCKED]" Meldungen fast komplett fehlen.
Ich habe leider nur noch dieses eine - was die technischen Daten betrifft - passende Netzteil (welches eben auch mit dem 8er Stick geliefert wurde)  :(.
« Antwort #5 am: Mai 01, 2019, 12:20:06 Vormittag »
Versuche mal sundtek.conf lnblimit=1000mA (danach wird ein Treiber- oder Systemneustart benötigt)
LO Band / 13V:
Ich denke der Tuner nimmt den Strom wohl vom USB Port und nicht vom Netzteil.
13V Loband hat die geringste Anforderung.
date
« Antwort #6 am: Mai 01, 2019, 09:00:11 Nachmittag »
Mein VDR läuft unter Ubuntu - die Datei "sundtek.conf" gab es bei mir bislang wohl noch nicht. Habe diese jetzt wie folgt angelegt (Pfad korrekt?):
/etc/sundtek.conf
Inhalt:
lnblimit=1000mA
Vorsichtshalber habe ich den Rechner danach neu gestartet.
mediaclient -e
     FESTATUS: ACTIVE
     LNBVOLTAGE: ENABLED
     LNBSUPPLY: USBPOWER
DVBS
LO Band / 18V:
LO Band / 13V:
HI Band / 18V:
HI Band / 13V:
DVB-S2 ZDF HD / 18V
TV tut leider noch immer nicht...
