Autor Thema: Sundtek install docker  (Gelesen 35583 mal)
jteeuw
« am: Januar 25, 2019, 01:39:50 Nachmittag »
I am trying to install the driver in a docker (  linuxserver/tvheadend alpine 3.8 ) but get a error :
unpacking...
checking system... Your system is currently unsupported
also check that this installer is not corrupted due a bad download
/tmp must not be mounted with noexec flag, otherwise the installer
won't work
In case you do not have enough free space on your system you might
use the network installer
http://sundtek.de/media/sundtek_netinst.sh
in case your system is really unsupported please contact
our support via mail <kontakt@sundtek.de>
removing driver.....
driver removed...
Platform is Qnap 253A ( intel cpu )
Re: Sundtek install docker
« Antwort #1 am: Januar 27, 2019, 10:26:18 Nachmittag »
you can contact us about that topic on Friday (1. February 2019). Basically we support docker systems - but still need to update some installer scripts.
jteeuw
« Antwort #2 am: Februar 04, 2019, 01:38:51 Nachmittag »
What is the best way to contact you ?
« Antwort #3 am: April 13, 2019, 01:22:14 Nachmittag »
Regarding Docker:
first of all docker and tvheadend inside need to be installed
On the native host you need to run our installer with following parameter:
./sundtek_netinst_testing.sh -createnodes
In the Docker Image:
./sundtek_netinst_testing.sh -docker -use-custom-path=/config
where config is a persistent path inside the Docker image (you can just change it).
The Docker must be configured with -device=/dev/bus/usb
Docker does not support Hotplugging USB devices,
mitcho
« Antwort #4 am: Januar 18, 2021, 04:49:08 Nachmittag »
whats the procedure on Synology 918+ for already prepared docker image marcoh00-tvheadend-sundtek1?
I've installed native Sundtek driver 0.38 in Package center.
Thanx, Mitcho
« Antwort #5 am: Januar 19, 2021, 01:52:49 Nachmittag »
mitcho
« Antwort #6 am: Januar 20, 2021, 03:53:07 Nachmittag »
That Did the job done!
Thank you!
