Autor Thema: libmediaclient.so lässt wipe crashen  (Gelesen 55016 mal)
mifritscher
« am: November 14, 2018, 11:49:16 Nachmittag »
Wollte unter Ubuntu 18.04 64 bit ne 1 GB Datei löschen -  time wipe -i -q -Q 1 /media/michi/4D66-6D70/blah
Am Ende gabs ne Speicherschutzverletzung:
[342418.056014] wipe[23887]: segfault at ffffffff89600770 ip 00007f4084c4d819 sp 00007ffd3b374040 error 5 in libmediaclient.so[7f4084c4a000+10000] (mediaclient vom 10.02.2018)
Update half nichts:
[342981.602897] wipe[28561]: segfault at 2a368770 ip 00007fae828a9789 sp 00007ffd1511f7f0 error 4 in libmediaclient.so[7fae828a6000+10000] (mediaclient vom 13.11.2018)
gdb sagt folgendes:
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff7bc7789 in ?? () from /opt/lib/libmediaclient.so
(gdb) bt
#0  0x00007ffff7bc7789 in ?? () from /opt/lib/libmediaclient.so
#1  0x00007ffff7bc866f in open () from /opt/lib/libmediaclient.so
#2  0x00007ffff7bc8743 in open64 () from /opt/lib/libmediaclient.so
#3  0x000055555555741c in ?? ()
#4  0x0000555555558693 in ?? ()
#5  0x0000555555556b55 in ?? ()
#6  0x00007ffff77f4b97 in __libc_start_main (main=0x5555555562b0, argc=6, argv=0x7fffffffd648, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>, stack_end=0x7fffffffd638) at ../csu/libc-start.c:310
#7  0x000055555555701a in ?? ()
(gdb) info registers
rax            0x0   0
rbx            0x10900   67840
rcx            0x8   8
rdx            0x0   0
rsi            0x7ffff7bd1972   140737349753202
rdi            0x5579f770   1434056560
rbp            0xffffffff   0xffffffff
rsp            0x7fffffffc7b0   0x7fffffffc7b0
r8             0xfff   4095
r9             0x0   0
r10            0x55555575f010   93824994373648
r11            0x0   0
r12            0x5579f770   1434056560
r13            0x10900   67840
r14            0x7fffffffdad1   140737488345809
r15            0x55555579f8d0   93824994638032
rip            0x7ffff7bc7789   0x7ffff7bc7789
eflags         0x10202   [ IF RF ]
cs             0x33   51
ss             0x2b   43
ds             0x0   0
es             0x0   0
fs             0x0   0
gs             0x0   0
Es hängt _kein_ TV-Receiver am Notebook.
Re: libmediaclient.so lässt wipe crashen
« Antwort #1 am: November 15, 2018, 11:30:57 Vormittag »
Danke für die Information, wir überprüfen das.
So ein Tool würde ich aber nicht empfehlen da es auf Dateisystemebene zurückgreifen müsste, bei einem Fehler kann man sich damit die gesamte Festplatte ruinieren; Dort sollte man den Anmerkungen im Manual wirklich Beachtung schenken.
Laut dem Crash fehlt der Dateiname bzw. wurde dort ein ungültiger Pointer an eine Standardfunktion übergeben die einfach weitergereicht wird (wir verändert dort nichts, überprüfen nur ob auf /dev/dvb zugegriffen wird).
Sofern man den Pointer direkt an den Kernel weitergibt wird der Kernel hier abriegeln und es wird ein fehlerhafter Returncode zurückgeliefert, dadurch das wir auf /dev/dvb überprüfen bleibt hier alles auf Applikationslevel (in dem Fall Ring3) und es kann bei einem Programmierfehler zu einem Crash kommen).
« Letzte Änderung: November 15, 2018, 11:32:37 Vormittag von Sundtek »
