Autor Thema: Sundtek SkyTV Ultimate setup on Tvheadend with Diseqc 1.1  (Gelesen 28076 mal)
anilw
« am: August 26, 2018, 04:53:03 Nachmittag »
Hi can anyone pls help me setup Sundtek SkyTV Ultimate on my TVH server.. i have 1.1 diseqc switc and my LNB set up as follows
LNB1- 91.5E
LNB2-45.0E
LNB3-88.0E
LNB4-91.5/95.0E
LNB5-8 so far not connected..
pls tell how to setup as TVH does not send LNB voltage it seems.. when i do  force scan..
2018-08-26 20:02:12.265 linuxdvb: adapter added /dev/dvb/adapter0
2018-08-26 20:03:46.293 bouquet: new bouquet 'D2H'
2018-08-26 20:04:04.960 bouquet: new bouquet 'Dialog'
2018-08-26 20:04:23.914 bouquet: new bouquet 'DishTV'
2018-08-26 20:04:47.057 bouquet: new bouquet 'SunHD'
2018-08-26 20:05:05.263 bouquet: new bouquet 'BigHD'
2018-08-26 20:08:23.073 mpegts: 11155V in Dialog - tuning on Sundtek DVB-S/S2 (V) #0 : DVB-S #0
2018-08-26 20:08:24.276 epggrab: 11155V in Dialog - registering mux for OTA EPG
2018-08-26 20:08:24.280 subscription: 0001: "scan" subscribing to mux "11155V", weight: 5, adapter: "Sundtek DVB-S/S2 (V) #0 : DVB-S #0", network: "Dialog", service: "Raw PID Subscription"
2018-08-26 20:08:34.191 mpegts: 11155V in Dialog - scan no data, failed
2018-08-26 20:08:34.191 subscription: 0001: "scan" unsubscribing
2018-08-26 20:09:25.288 mpegts: 11483H in D2H - tuning on Sundtek DVB-S/S2 (V) #0 : DVB-S #0
2018-08-26 20:09:26.809 epggrab: 11483H in D2H - registering mux for OTA EPG
2018-08-26 20:09:26.811 subscription: 0002: "scan" subscribing to mux "11483H", weight: 5, adapter: "Sundtek DVB-S/S2 (V) #0 : DVB-S #0", network: "D2H", service: "Raw PID Subscription"
2018-08-26 20:09:36.791 mpegts: 11483H in D2H - scan no data, failed
2018-08-26 20:09:36.791 subscription: 0002: "scan" unsubscribing
2018-08-26 20:10:35.287 mpegts: 11630H in SunHD - tuning on Sundtek DVB-S/S2 (V) #0 : DVB-S #0
2018-08-26 20:10:36.802 epggrab: 11630H in SunHD - registering mux for OTA EPG
2018-08-26 20:10:36.805 subscription: 0003: "scan" subscribing to mux "11630H", weight: 5, adapter: "Sundtek DVB-S/S2 (V) #0 : DVB-S #0", network: "SunHD", service: "Raw PID Subscription"
2018-08-26 20:10:46.705 mpegts: 11630H in SunHD - scan no data, failed
2018-08-26 20:10:46.705 subscription: 0003: "scan" unsubscribing
2018-08-26 20:11:23.566 mpegts: 11037H in DishTV - tuning on Sundtek DVB-S/S2 (V) #0 : DVB-S #0
2018-08-26 20:11:25.063 epggrab: 11037H in DishTV - registering mux for OTA EPG
2018-08-26 20:11:25.065 subscription: 0004: "scan" subscribing to mux "11037H", weight: 5, adapter: "Sundtek DVB-S/S2 (V) #0 : DVB-S #0", network: "DishTV", service: "Raw PID Subscription"
2018-08-26 20:11:34.983 mpegts: 11037H in DishTV - scan no data, failed
2018-08-26 20:11:34.983 subscription: 0004: "scan" unsubscribing
2018-08-26 20:12:15.948 mpegts: 12523H in BigHD - tuning on Sundtek DVB-S/S2 (V) #0 : DVB-S #0
2018-08-26 20:12:17.449 epggrab: 12523H in BigHD - registering mux for OTA EPG
2018-08-26 20:12:17.451 subscription: 0005: "scan" subscribing to mux "12523H", weight: 5, adapter: "Sundtek DVB-S/S2 (V) #0 : DVB-S #0", network: "BigHD", service: "Raw PID Subscription"
2018-08-26 20:12:27.366 mpegts: 12523H in BigHD - scan no data, failed
2018-08-26 20:12:27.366 subscription: 0005: "scan" unsubscribing
root@odroid:~# /opt/bin/mediaclient -e
device 0: [SkyTV Ultimate V 2016]  DVB-S/S2, ANALOG-TV, REMOTE-CONTROL, OSS-AUDIO
     FESTATUS: STANDBY
     LNBVOLTAGE: DISABLED
     LNBSUPPLY: ACADAPTER
     VIDEO0: /dev/video34
pls help me with this.. appreciate if you tell me putty command to set up my LNB setup so that TVH will recognize..
tks in advance
« Letzte Änderung: August 26, 2018, 04:54:49 Nachmittag von anilw »
anilw
Re: Sundtek SkyTV Ultimate setup on Tvheadend with Diseqc 1.1
« Antwort #1 am: August 31, 2018, 01:27:23 Nachmittag »
STRANGE!!!
NO reply for the last many days...
:P :P :P
« Antwort #2 am: August 31, 2018, 03:56:01 Nachmittag »
I have told you previously in the chat room that 4 channel DISEQC is still in progress with our streaming server, maybe you did not see the reply?
We are finalising our multituners at the moment that's why the software is a bit stuck at the moment.
« Letzte Änderung: August 31, 2018, 04:03:17 Nachmittag von Sundtek »
anilw
« Antwort #3 am: September 03, 2018, 06:52:29 Vormittag »
Hi Noted..
I think the problem is LNB voltage OFF ( even though i have connected power supply to USB tuner)
     FESTATUS: STANDBY
I have connected USB tuner on my Vu+ and then it works properly.. then i connected antenna wire (coming out from Diseqc) to a signal spliter and then one output to my Vu+ tuner one and 2nd one to TVH through USB tuner..
then i get signal for TVH for the selected sat in Vu+
(ex if i select 95E from my Vu+ then i can scan and find chs on TVH for 95E.. similarly for 45E, 91.5E and 93.5E)
this confirms that LNB voltage made this problem..
Untill you sort out software issues from your end.. can you pls tell me how enable LNB Voltage manually
your earliest responce is highly appreciated
« Letzte Änderung: September 03, 2018, 06:55:22 Vormittag von anilw »
« Antwort #4 am: September 03, 2018, 03:28:54 Nachmittag »
The voltage is enabled automatically, and disabled if the tuner is not used.
Your problem is that we haven't implemented 4 channel Diseqc support yet in the Streamingserver.
We will implement that - we also need that and more Diseqc based features because of our upcoming Multituners.
anilw
« Antwort #5 am: September 04, 2018, 02:12:33 Nachmittag »
OK good to hear you are working on this.. my request would be pls dont take ages on this...hope at least by this weekend it will be ready.. pls get this done for DiseqC 1.1, As DiseqC 1.0 is for nothing..)
But if i'm not mistaken already your streamserver is showing LNB settings for DeseqC 1.0 ( we can select AA, AB, BA or BB for LNB settings.. but it doesn't work that's the problem..)
anilw
« Antwort #6 am: September 11, 2018, 04:52:48 Vormittag »
hello any update...
« Antwort #7 am: September 11, 2018, 09:42:20 Vormittag »
Sorry we're at the final stage of our new devices, it might take up to 1 1/2 - 2 weeks until we can fully focus on the streamingserver again.
It will be implemented properly then.
anilw
« Antwort #8 am: September 28, 2018, 10:11:13 Vormittag »
Hi any update?
