Autor Thema: Raspberry PI2 + Openelec 6.0 + MediaPro III + VDR + Remote command  (Gelesen 19523 mal)
Want2Play
« am: Dezember 30, 2015, 07:16:17 Nachmittag »
Hello,
Edit : I use a Raspberry Pi2
I'm using Openelec 6.0.0 and the VDR backend and frontend.  I've the last version of the remote command, the version "3" from a german thread.
The cursors can change the channels, but the number can't select a channel. After I want map some key to the Kodi interface.
I've found this, but it could be too old for the 6.0.0 version of OpenElec http://openelec.tv/forum/103-infared-remotes/61729-sundtek-remote-not-working?start=15
How to activate the remote command in OpenElec / VDR ?
Thanks.
Best regards.
« Letzte Änderung: Dezember 30, 2015, 10:34:34 Nachmittag von Want2Play »
Re:Openelec 6.0 + MediaPro III + VDR + Remote command
« Antwort #1 am: Dezember 30, 2015, 07:32:51 Nachmittag »
Good question, I don't know how Openelec currently implements the remote control.
There are 2 ways.
1. the remote control is registered as a keyboard interface (by default)
2. Lirc attaches to the registered remote control interface
I don't know if Openelec currently uses LIRC or just the default keyboard interface
It seems like Openelec uses LIRC
http://wiki.openelec.tv/index.php/Guide_to_add_your_own_remote
the numeric patterns are currently set to KEY_0 - KEY_9 instead of KEY_NUMERIC_0 - KEY_NUMERIC_9
Do you have any experience with Lirc?
Want2Play
« Antwort #2 am: Dezember 30, 2015, 07:48:12 Nachmittag »
I've no experience with Lirc.
Must I do something to activate the specific mapping of the MediaPro III ? The the moment, you've right, it's only a keyboard.
« Antwort #3 am: Dezember 30, 2015, 07:54:08 Nachmittag »
I can only give you some hint at the moment since I do not have any openelec system here right now.
If you open a terminal you can dump the current keymap
mediaclient --dumprc > /tmp/keymap.txt
afterwards you can edit this keymap and change KEY_0 to KEY_NUMERIC_0
and load the new keymap using
mediaclient --setrcmap=/tmp/keymap.txt
You would have to wait a few more days until I can have an openelec system in order to help you with more details.
« Letzte Änderung: Dezember 30, 2015, 08:00:15 Nachmittag von Sundtek »
Want2Play
« Antwort #4 am: Dezember 30, 2015, 10:29:40 Nachmittag »
Thanks for your help. I'll go try this and come back to give you the status.
Edit : I've changed the title of this thread because I use a Raspberry Pi2.
« Letzte Änderung: Dezember 30, 2015, 10:35:39 Nachmittag von Want2Play »
Want2Play
Re:Raspberry PI2 + Openelec 6.0 + MediaPro III + VDR + Remote command
« Antwort #5 am: Januar 01, 2016, 12:48:38 Vormittag »
The KEY_[0-9] changed to KEY_NUMERIC_[0-9] and mediaclient --setrcmap=... done, but no result. Even the keys CH+ and CH- are inactiv.
Edit : I've add the program "Keymap Editor". For the PVR, when I try to map the CH+ to a command, there is no detection of the key pressed, but it's working for CH- and Record / the red button.
« Letzte Änderung: Januar 01, 2016, 01:23:11 Vormittag von Want2Play »
Want2Play
« Antwort #6 am: Januar 13, 2016, 03:54:20 Nachmittag »
Have you some suggestions ?
For the moment, I use Osmc (November 2015). I would want to controm Kodi with the remote control.
Thanks for any help.
