Autor Thema: Blindscan on VU+ Solo2 with OpenPLI image  (Gelesen 227359 mal)
Dima73
Re:Blindscan on VU+ Solo2 with OpenPLI image
« Antwort #30 am: April 14, 2016, 05:31:48 Nachmittag »
The problem is related to the channel scan.
blindscan_13E_14-04-2016_18-17-04.xml
Please see:
<?xml version="1.0" encoding="iso-8859-1"?>
File created on Четверг, 14 of апреля 2016, 18:17:04
using et8500 receiver running Enigma2 image, version 2016-03-17,
image Openpli 4, with the Blind scan plugin
Search parameters:
Тюнер F: Sundtek DVB-S/S2 (IV) (0/0) (USB) (DVB-S2)
Satellite: 13.0E Eutelsat Hot Bird 13B/13C/13D
Start frequency: 10700MHz
Stop frequency: 12750MHz
Polarization: vertical and horizontal
Lower symbol rate: 2000
Upper symbol rate: 45000
Only save unknown tranponders: yes
Filter out adjacent satellites: up to 3 degrees
<satellites>
<sat name="13.0E Eutelsat Hot Bird 13B/13C/13D" flags="0" position="130">
<transponder frequency="10774000" symbol_rate="27500000" polarization="0" fec_inner="0" system="0" modulation="1"/>
</sat>
</satellites>
After scan tuner (sundtek sky tv ultimate 5) --> 0 channels found
After scan any internal tuner  --> 2 channels found
Use manual scan, if set System_DVB_S2 --> scan tuner (sundtek sky tv ultimate 5) --> 2 channels found
It should not be.
This is a bug in the drivers.
It can be fixed?
« Antwort #31 am: April 14, 2016, 06:15:45 Nachmittag »
Which satellite do you use with Blindscan?
Blindscan is currently set up for Astra 19.2 (and similar ones).
The blindscan will need some symbol rates pre-set (currently we have only hard-coded the ones which are common on Astra 19.2 / Thor5 / Hotbird )
« Letzte Änderung: April 14, 2016, 06:27:42 Nachmittag von Sundtek »
Dima73
« Antwort #32 am: April 14, 2016, 06:51:52 Nachmittag »
this feed transponder
« Letzte Änderung: April 14, 2016, 08:07:12 Nachmittag von Dima73 »
Dima73
« Antwort #34 am: April 18, 2016, 09:41:10 Vormittag »
The S2 Blindscan output for the nim sockets will be modified with the next update (however it's a bit unclear when the next one will be available since we have several updates and a new RTSP streamingserver upcoming)
Dima73
« Antwort #35 am: April 21, 2016, 10:10:29 Vormittag »
Support Sundtek S2 Blindscan added in plugin Blindscan(feed avaibale):
1)openPli image
2)images based of oe-alliance (openATV,openVIX and etc)
Dima73
« Antwort #36 am: Mai 29, 2016, 12:23:59 Nachmittag »
Tested.
Scan for new drivers(25.05.2016) works fine.
Fixed new output blind scan:
1)openPli image
https://github.com/OpenPLi/enigma2-plugins/commit/75aa34b103c6e78678f78f54952fb9c9fce2bd7e
https://github.com/oe-alliance/oe-alliance-plugins/commit/96975356a3a9e67d1a948ba64f7f13a233e94819
Dima73
« Antwort #37 am: November 19, 2016, 11:33:48 Nachmittag »
Hi.
Blind scan not work.
NIM Socket 5:
        Type: DVB-S2
        Name: Vuplus DVB-S NIM(7376 FBC)
        Frontend_Device: 5
NIM Socket 6:
        Type: DVB-S2
        Frontend_Device: 6
NIM Socket 7:
        Type: DVB-S2
        Frontend_Device: 7
NIM Socket 8:
        Type: DVB-S2
        Name: Vuplus DVB-S NIM(AVL6222)
        Frontend_Device: 8
        I2C_Device: 4
NIM Socket 9:
        Type: DVB-S2
        Frontend_Device: 9
        I2C_Device: 4
NIM Socket 10:
        Type: DVB-T
        Name: Sundtek DVB-T (III) (1/0) (USB)
        Frontend_Device: 10
NIM Socket 11:
        Type: DVB-S2
        Name: Sundtek DVB-S/S2 (IV) (0/0) (USBDVB-S2
        Frontend_Device: 11root@vusolo4k:~#
root@vusolo4k:~# /opt/bin/mediaclient --build
Build date: 2016-10-20 11:51:28
root@vusolo4k:~# /opt/bin/mediaclient --blindscan 10
root@vusolo4k:~# /opt/bin/mediaclient --blindscan 11
root@vusolo4k:~#
answer zero
« Antwort #38 am: November 20, 2016, 02:02:51 Nachmittag »
What does ls /dev/dvb/frontend* show up?
« Antwort #39 am: November 20, 2016, 02:49:44 Nachmittag »
try attached mediaclient file
put it to /opt/bin
cd /opt/bin
chmod 777 mediaclient
I see it was only possible to support up to 9 tuners on a system for the blindscan, the 10th was truncated to 1 with the mediaclient blindscan command.
Dima73
« Antwort #40 am: November 20, 2016, 03:56:11 Nachmittag »
mediaclient old
yes, /dev/dvb/adapter0/frontend11 work
root@vusolo4k:~# /opt/bin/mediaclient --blindscan /dev/dvb/adapter0/frontend11
Scanning 13V Lowband
MODE: DVB-S  FREQUENCY(MHz): 10718 SYMBOL_RATE: 27500 MODULATION: QPSK VOLTAGE: 13V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 10757 SYMBOL_RATE: 27499 MODULATION: PSK8 VOLTAGE:
I had just made:
https://github.com/OpenPLi/enigma2-plugins/blob/master/blindscan/src/plugin.py#L788
test
root@vusolo4k:~# //opt/bin/mediaclient
//opt/bin/mediaclient: line 1: syntax error: unexpected "("
root@vusolo4k:~# uname -a
Linux vusolo4k 3.14.28-1.8 #1 SMP Fri Sep 9 01:28:49 EEST 2016 armv7l GNU/Linux
Dima73
« Antwort #41 am: November 20, 2016, 04:15:41 Nachmittag »
Another question...
Dear Sundtek,
Recently we added DVB API v5 statistics into Enigma2 (see: https://github.com/O...7cb9b043797834)
I've got a request from a user that since above commit dB/snr caclulation is broken for Sundtek DVB-T (III).
I guess that you are using DVB API v5 statistics!
Could you please fill DVB API v5 statistics properly?
Currently we need at least the following: DTV_STAT_SIGNAL_STRENGTH scaled as FE_SCALE_RELATIVE, DTV_STAT_CNR scaled as FE_SCALE_DECIBEL and FE_SCALE_RELATIVE
Example values:
DTV_STAT_SIGNAL_STRENGTH S: 59172 U: 59172 L: 1 Scale: FE_SCALE_RELATIVE
DTV_STAT_CNR S: 12453 U: 12453 L: 2 Scale: FE_SCALE_DECIBEL
DTV_STAT_CNR S: 51007 U: 51007 L: 2 Scale: FE_SCALE_RELATIVE
Please let me know of your thoughts.
Best Regards,
Athoik on behalf of OpenPLi team
for  DVB API v5
Sundtek DVB-T (III) snr always 99%
Sundtek DVB-S/S2 (IV) snr always 88-89%
My workaround has been removed recently:
https://github.com/OpenPLi/enigma2/commit/abaabfdad4f278cbcfcf7e4915d2a8e20486bfac
When either signalquality or signalqualitydb are nonzero, the driver
implements the DTV_STAT_CNR property.
And we have to trust the driver to report the correct values, no need to
make any exceptions.
Perhaps this commit was meant to force snr percentage to dB calculation
for Sundtek, but in that case a different, more generic fix should be
made to calculate dB values based on the FE_SCALE_RELATIVE value
reported by the DTV_STAT_CNR property.
« Antwort #42 am: November 20, 2016, 04:54:01 Nachmittag »
use this one for ARM
Dima73
« Antwort #43 am: November 20, 2016, 05:56:53 Nachmittag »
Thanks,work fine...
root@vusolo4k:~# mediaclient --blindscan 11
waiting for 1 seconds
OK DVB-S 968361 27500 QPSK V OFF
OK DVB-S2 1006490 27499 8PSK V OFF
OK DVB-S2 1045633 27500 8PSK V OFF
OK DVB-S2 1083311 27501 8PSK V OFF
OK DVB-S 1122257 27500 QPSK V OFF
OK DVB-S2 1160689 27501 8PSK V OFF
Dima73
« Antwort #44 am: Januar 24, 2017, 11:13:30 Vormittag »
About this question...
http://support.sundtek.com/index.php/topic,1833.msg17003.html#msg17003
You can make changes to the drivers.
Return the DTV_STAT_SIGNAL_STRENGTH / DTV_STAT_CNR value as zero.
Or at least add a key to start the driver DTV_STAT_SIGNAL_STRENGTH/ DTV_STAT_CNR S with zero.
Please help :(.
