Autor Thema: [Solved] High memory usage mediaserv  (Gelesen 34161 mal)
carelw
« am: November 27, 2009, 02:17:09 Nachmittag »
Hello,
After a couple of days running <mediasrv> I found a memory usage of 42%
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
 7117 carel     20   0  495m  87m 6500 S    4  4.4  22:24.33 vdr
 1498 root      18  -2 1126m 848m  15m S    0 42.0 504:10.07 mediasrv
I use vdr-1.7.10, 1 x dvb-c and 1 x dvb-s PCI cards and use latest driver version.
This usage increases very slowly...
"/var/log/mediasrv.log" doesn't show anything special.
Do I have a memory-leak here ?
Kind regards
Carel
« Letzte Änderung: Januar 19, 2010, 04:07:35 Nachmittag von carelw »
Nvidia ION - Intel Atom 230
Ubuntu Server 10.04 x86_64 - kernel 2.6.34  - vdr-1.7.15 + Ext patch NG
Plugins: s.c, xineliboutput, epgsearch, iptv, live, osdteletext, exrecmenu.
2 x Sundtek DVB-C
carelw
Re:High memory usage mediaserv
« Antwort #1 am: November 30, 2009, 10:49:31 Nachmittag »
No one seeing the same behaviour ?  ::)
I rebooted a couple of times, but without luck
I also completely reinstalled driver 091109.
Thanks
Carel
2 x Sundtek DVB-C
« Antwort #2 am: November 30, 2009, 10:53:08 Nachmittag »
What system/kernel do you use? Please retry with the latest available driver, if it still comes up like that we will check it.
« Letzte Änderung: November 30, 2009, 11:10:12 Nachmittag von Sundtek »
carelw
« Antwort #3 am: Dezember 01, 2009, 02:55:55 Nachmittag »
Hello,
I use Debian Squeeze and "Linux 2.6.31.6 #15 SMP PREEMPT Tue Nov 3 13:39:16 CET 2009 i686 GNU/Linux"
I tried the new driver for a while, but unfortunately the old error "VDR: Too many open files" re-appeared...".  :(
But I will try it again, after deleting the previous driver completely.
Kind regards
Carel
« Letzte Änderung: Dezember 03, 2009, 05:30:33 Nachmittag von carelw »
2 x Sundtek DVB-C
« Antwort #4 am: Dezember 07, 2009, 02:05:09 Nachmittag »
The next update will also take care about the memory usage. The driver did not clean up the session memory when the client disconnected.
Due the network update the clienthandling part got updated, the too many files issue will also be solved with the next update.
« Letzte Änderung: Dezember 07, 2009, 02:54:34 Nachmittag von Sundtek »
carelw
« Antwort #5 am: Dezember 07, 2009, 09:23:12 Nachmittag »
2 x Sundtek DVB-C
carelw
« Antwort #6 am: Dezember 18, 2009, 11:16:50 Vormittag »
This: http://www.sundtek.com/support/empia_installer_091214.sh
version may not be the latest official version  ::) but it does solve the aforementioned problems!
CU
Carel
2 x Sundtek DVB-C
