Autor Thema: Channel Mess...  (Gelesen 18487 mal)
dreadcontrol
Channel Mess...
« am: März 16, 2013, 04:02:11 Nachmittag »
Hi Sundtek,
Got a new Media TV, trying to make it work under Mint 14 (kern 3.7.0-7) in DVB-C.
Channels are found with W_Scan but with MeTV channels are not working properly.
Most of the channels don't work at all, the working ones are not showing the indicated channels.
If you record, it sometimes records ok (what you're viewing at the same time) but sometimes another channel is recorded. I suspect a mess with the standards and/or PID / service ID & else.
Any idea ?
Thks for your help guys.
Cheers,
Re:Channel Mess...
« Antwort #1 am: März 16, 2013, 04:07:07 Nachmittag »
Try to doublecheck the parameters with following command
W-Scan usually reports the correct channel parameters so it might be some issue with me-tv
dreadcontrol
Re:Channel Mess...
« Antwort #2 am: März 16, 2013, 04:28:28 Nachmittag »
That's what I got, scolling...
Does it tell you something ?
SIGNAL: [.................................] (100%)  BER:      3 FREQ: 394000000  Hz LOCKED: YES MER: 325 SYM: 6900000 MOD: QAM256
SIGNAL: [.................................] (100%)  BER:      2 FREQ: 394000000  Hz LOCKED: YES MER: 327 SYM: 6900000 MOD: QAM256
SIGNAL: [.................................] (100%)  BER:      2 FREQ: 394000000  Hz LOCKED: YES MER: 328 SYM: 6900000 MOD: QAM256
SIGNAL: [.................................] (100%)  BER:      3 FREQ: 394000000  Hz LOCKED: YES MER: 326 SYM: 6900000 MOD: QAM256
SIGNAL: [.................................] (100%)  BER:      3 FREQ: 394000000  Hz LOCKED: YES MER: 328 SYM: 6900000 MOD: QAM256
SIGNAL: [.................................] (100%)  BER:      3 FREQ: 394000000  Hz LOCKED: YES MER: 329 SYM: 6900000 MOD: QAM256
SIGNAL: [.................................] (100%)  BER:      3 FREQ: 394000000  Hz LOCKED: YES MER: 327 SYM: 6900000 MOD: QAM256
SIGNAL: [.................................] (100%)  BER:      2 FREQ: 394000000  Hz LOCKED: YES MER: 329 SYM: 6900000 MOD: QAM256
SIGNAL: [.................................] (100%)  BER:      2 FREQ: 394000000  Hz LOCKED: YES MER: 326 SYM: 6900000 MOD: QAM256
Re:Channel Mess...
« Antwort #3 am: März 16, 2013, 07:06:07 Nachmittag »
That means that the frequency itself seems to be okay, so it should be some issue with me-tv and dvb-c.
Maybe you might try kaffeine.
AMD64:
up to Ubuntu 11.10
http://www.sundtek.de/support/kaffeine_oneiric_1.2.2-1ubuntu3_amd64.deb
newer Ubuntu versions::
X86-32bit:
up to Ubuntu 11.10
http://www.sundtek.de/support/kaffeine_oneiric_1.2.2-1ubuntu3_i386.deb
http://www.sundtek.de/support/kaffeine_1.2.2-1ubuntu3_i386.deb
Required kaffeine patch:
http://www.sundtek.de/support/sundtek_0.3.diff
dreadcontrol
Re:Channel Mess...
« Antwort #4 am: März 16, 2013, 07:35:17 Nachmittag »
Thks, installed the http://www.sundtek.de/support/kaffeine_oneiric_1.2.2-1ubuntu3_amd64.deb ; would you have a procedure to install the patch (am a bit lost) ?
I really appreciate your help.
Cheers,
Re:Channel Mess...
« Antwort #5 am: März 16, 2013, 08:32:35 Nachmittag »
If you installed that package no patch needed. You can just start it and scan within the UI
