Autor Thema: Not detecting channels on Qnap  (Gelesen 15542 mal)
jteeuw
« am: Oktober 31, 2012, 09:33:31 Nachmittag »
Hello,
I just installed my suntek on a Qnap TS-119II and the problem that i have is the tuner is not detecting any channels ( see log )
2012-10-31 20:18:55 [6036] Sundtek MediaTV Driver loaded. This driver is licensed for non-commercial use
2012-10-31 20:18:55 [6036] with Sundtek MediaTV only
2012-10-31 20:18:55 [6036] Driver loaded within 7107 milliseconds
2012-10-31 20:18:55 [6036] Serial(0): U111215143813
2012-10-31 20:18:55 [6036] Initial devicescan done, switching detection mode
2012-10-31 20:18:55 [6036] received device attach message
2012-10-31 20:18:55 [6037] notify request: media device connected
2012-10-31 20:18:58 [6036] Submitting 4 failed (112800)
2012-10-31 20:18:58 [6036] RV: -1
2012-10-31 20:18:58 [6036] ERROR: Cannot allocate memory
2012-10-31 20:18:58 [6036] Error enabling USB transfer
2012-10-31 20:18:58 [6036] Setting Frequency: 164000000
2012-10-31 20:18:58 [6036] Setting Symbolrate: 6900000
2012-10-31 20:18:58 [6036] Setting Modulation: 3
2012-10-31 20:18:59 [6036] Submitting 5 failed (112800)
2012-10-31 20:18:59 [6036] RV: -1
2012-10-31 20:18:59 [6036] ERROR: Cannot allocate memory
2012-10-31 20:18:59 [6036] Error enabling USB transfer
2012-10-31 20:18:59 [6036] Submitting 4 failed (112800)
2012-10-31 20:19:00 [6036] Submitting 4 failed (112800)
2012-10-31 20:19:00 [6036] RV: -1
2012-10-31 20:19:00 [6036] ERROR: Cannot allocate memory
2012-10-31 20:19:00 [6036] Error enabling USB transfer
2012-10-31 20:19:00 [6036] Current mode: Media Digital TV
2012-10-31 20:19:00 [6036] Requested mode: Media Analog TV
2012-10-31 20:19:00 [6036] PID: 6174
2012-10-31 20:19:00 [6036] Application: ld-linux.so.3
2012-10-31 20:19:00 [6036] current mode != requested mode .. but there are still users there! 2
2012-10-31 20:19:01 [6036] Channel found (164000000)
Re:Not detecting channels on Qnap
« Antwort #1 am: Oktober 31, 2012, 10:01:06 Nachmittag »
Hmm, try to patch the firmware, run following command on the terminal:
/opt/bin/mediaclient --dtvtransfermode=bulk
Afterwards reconnect the device, seems like there's some bug on the NAS system (although as mentioned you can try to work around with some features of the stick)
jteeuw
« Antwort #2 am: Oktober 31, 2012, 10:13:51 Nachmittag »
Thank you for the awnser, but how do i flash the stick ?
« Antwort #3 am: Oktober 31, 2012, 10:34:24 Nachmittag »
Just run that command
the driver will do everything for you
