Autor Thema: Can't Switch from DVB-C to DVB-T  (Gelesen 19298 mal)
fullcorn
« am: Oktober 16, 2012, 11:43:08 Nachmittag »
Hey there again, after having had some trouble free time with the MediaTV Stick and DVB-C I now moved to a new place, where I have to use DVB-T.
The Computer runs Ubuntu 12.04 and TVheadend.
I tried to switch the device to DVB-T with:
/opt/bin/mediaclient --setdtvmode=DVBT
and
/opt/bin/mediaclient -D DVBT
both with the same result:
Done.
However, in the drop down menu of TVheadend (Configuration/TV Adapters) the stick still shows up as DVB-C, also I can't search for DVB-T channels.
Rebooting doesn't help either.
Has anyone an idea, what it is that I'm doing wrong?
Any help and hint is greatly appreciated!
-peter
Re:Can't Switch from DVB-C to DVB-T
« Antwort #1 am: Oktober 16, 2012, 11:45:01 Nachmittag »
You need to delete the old adapter in tvheadend.
If you want the dongle to start up in DVB-T mode you need to add this to the configuration file in /etc/sundtek.conf
1. /opt/bin/mediaclient -e shows up the serialnumber of the device
2. add some configuration to /etc/sundtek.conf
[serial]
initial_dvb_mode=DVBT
eg.
/etc/sundtek.conf:
[U1234567890]
« Letzte Änderung: Oktober 16, 2012, 11:56:15 Nachmittag von Sundtek »
fullcorn
« Antwort #2 am: Oktober 17, 2012, 11:01:44 Vormittag »
Thank you very much, that did the trick!
Live TV works now just fine in XBMC and if I open a stream directly with vlc (http://192.168.0.102:9981/stream/ts-channelid/1) but I still don't get video using the web interface. All that shows up is the icon of vlc and the console of tvheadend puts out the following:
Oct 17 10:59:36 HTTP: 192.168.0.10: /stream/channelid/1 -- 401
I tried it on a remote computer and the host itself, always the same output in the console but no stream.
Man, so close! Any ideas??
-Peter
« Antwort #3 am: Oktober 17, 2012, 11:26:13 Vormittag »
401 stands for authorization, right. If it's a problem, you can still disable it by removing the password on the TVHeadend Access control tab.
But remember then that everyone can connect to your server port, particularly if you forward the port on your router.
