Autor Thema: Sundtek and Nova-T at the same time  (Gelesen 20551 mal)
OldSkul
« am: Juni 06, 2012, 02:20:32 Nachmittag »
My primary stick is Nova-T (tuner C) and today i installed sundtek stick. It only shows as tuner D when i put this line in sundtek.conf: vtuner_skip0=vtuner0
Usb stick is then detected as tuner D but when i zap to random dvb-c channel, it wants to use tuner C which is DVB-T. Basically its a mess. Anyone has a clue what to do here?
OldSkul
Re:Sundtek and Nova-T at the same time
« Antwort #1 am: Juni 07, 2012, 11:25:49 Vormittag »
I am also attaching two dmesg files. Dmesg1 was made when only nova-t was installed. Dmesg2 was made when both sticks were installed.
http://www.sendspace.com/file/rov4n8
OldSkul
« Antwort #2 am: Juni 11, 2012, 02:11:01 Nachmittag »
I also tested same situation on ET-5000. Same image, same sticks (nova-t and sundtek) and everything works as expected. I assume there must be something wrong with vuduo driver+sundtek drivers.
In the past i already tested two usb dvb-t sticks (nova-t and volar-hd) and they worked together without any problems. But it was old kernel back then. Now its newer one.
I also put clean latest pli image on VU+DUO and same problem as described in first post.
« Letzte Änderung: Juni 11, 2012, 02:25:56 Nachmittag von OldSkul »
« Antwort #3 am: Juni 12, 2012, 04:56:23 Nachmittag »
A simple way might be to re-create the virtual tuner interface nodes. That would be a workaround for a bug of the vu+ broadcom modules.
If possible contact us again via Skype.
You might be able to do that by running:
mv /dev/misc/vtuner1 /dev/misc/vtuner3
mv /dev/misc/vtuner0 /dev/misc/vtuner1
mv /dev/misc/vtuner3 /dev/misc/vtuner0
In order to make that work you might add it to the second line of sun_dvb.sh in /usr/sundtek
The problem is probably the slot allocation in the VU+ broadcom module.
« Letzte Änderung: Juni 12, 2012, 07:40:20 Nachmittag von Sundtek »
OldSkul
« Antwort #4 am: Juni 26, 2012, 03:07:30 Nachmittag »
I tried your suggestion but it doesnt work. Tuner C (Sundtek) works OK, but when i use tuner D (Nova-T), picture is black. Receiver doesnt use tuner D. When i check which tuners are present under Enigma2 Information, i can see both tuners.
What to do now?
« Letzte Änderung: Juni 26, 2012, 03:16:57 Nachmittag von OldSkul »
« Antwort #5 am: Juni 26, 2012, 03:23:14 Nachmittag »
Try to put those commands into /usr/sundtek/sun_dvb.sh (paste it after the first line of this script)
OldSkul
« Antwort #6 am: Juni 26, 2012, 03:27:08 Nachmittag »
This is first thing i did! *.sh file looks like this:
#!/bin/sh
if [ -f /usr/sundtek/mediasrv ]; then
  DRIVERPATH=/usr/sundtek
« Antwort #7 am: Juni 26, 2012, 03:52:07 Nachmittag »
and you still have this one in sundtek.conf vtuner_skip0=vtuner0?
OldSkul
« Antwort #8 am: Juni 26, 2012, 03:52:44 Nachmittag »
Yes!
I can give you remote access to my box if that will help you.
« Letzte Änderung: Juni 26, 2012, 04:00:19 Nachmittag von OldSkul »
OldSkul
« Antwort #9 am: Juni 27, 2012, 02:11:17 Nachmittag »
Any clue what to do here?
« Antwort #10 am: Juni 27, 2012, 06:54:57 Nachmittag »
Pieterg is looking into it to skip vtuner0 if it's already in use as this is the main issue actually. Unfortunately we're a little bit busy here for this week so further support for this has to be postponed until the beginning of next week.
« Antwort #11 am: Juni 30, 2012, 11:53:25 Nachmittag »
By the way try moving the files back at the end of sun_dvb.sh
OldSkul
« Antwort #12 am: Juli 02, 2012, 10:32:55 Vormittag »
Tuner doesnt work at all with these lines at the end. I tried to put them before and after "exit 0" line!
« Letzte Änderung: Juli 02, 2012, 11:31:38 Vormittag von OldSkul »
« Antwort #13 am: Juli 02, 2012, 02:20:07 Nachmittag »
The explanation is:
The VU+ System has an internal slot mechanism
1
2
actually at the beginning when our driver starts up no change is needed it should take 1 and no vtuner_skip should be used from your side.
After the registration (at the end of the script), the node /dev/misc/vtuner0 should be swapped with /dev/misc/vtuner1
OpenPLi will by default allocate vtuner0 for the first tuner, the internal VU+ slot mechanism will still think that the first allocated tuner will be Number 1. While OpenPLI will think the other way around.
OldSkul
« Antwort #14 am: Juli 06, 2012, 10:19:12 Vormittag »
New drivers are out and they apperantly improved vtuner performance. Maybe they fixed this issue?
