Autor Thema: Apple TV + Openelec - no scan  (Gelesen 8970 mal)
techouse
« am: Mai 05, 2012, 01:54:17 Nachmittag »
I set up an apple TV with openelec + a sundtek DVBC USB tuner.
DVBC works fine but I can't do a W_scan.
I stopped thheadend and tried to initiate a scan and got :
FATAL: ***** NO USEABLE CABLE CARD FOUND. *****
while mediaclient -e says :
device 0: [Sundtek MediaTV Digital Home (USB 2.0)] DVB-C, DVB-T, REMOTE-CONTROL
Can you tell me what is wrong ?
Thank you
Re:Apple TV + Openelec - no scan
« Antwort #1 am: Mai 05, 2012, 01:58:23 Nachmittag »
The virtual driver is probably not registered with libc.
Try:
afterwards your w_scan.
To make this persistent:
echo /opt/lib/libmediaclient.so > /etc/ld.so.preload
OpenElec by default does not register it globally.
What did your installation show up?
Did you install it on the AppleTV directly or did you use the openelec Package?
« Letzte Änderung: Mai 05, 2012, 02:06:31 Nachmittag von Sundtek »
techouse
« Antwort #2 am: Mai 05, 2012, 03:49:02 Nachmittag »
You solved it :
Here is what I used :
export LD_PRELOAD=/storage/.xbmc/addons/driver.dvb.sundtek-mediatv/lib/libmediaclient.so
both openelec's addon and downloaded "w_scan" didn't work before that.
This should be fixed in openelec.
Thanks
ultraman
« Antwort #3 am: Mai 05, 2012, 05:42:16 Nachmittag »
Openelec works as it works. And addon works just fine as is with tvheadend and vdr. To run w_scan you just need to use this export. No big deal. It's only few times.
