donald
« am: Januar 25, 2012, 06:41:13 pm » |
how to install. driver of the sundtek media tv digital home dvb/ct into the Qnap ts 119 nas? thanks : don.
« Antworten #1 am: Januar 26, 2012, 04:20:26 am » |
Just log in into your QNAP and install the driver according to the installation, it's everywhere the same.
donald
« Antworten #2 am: Januar 26, 2012, 08:16:38 am » |
yes i do that,so far so good, but when i set the last line ./sundtek_installer_development.sh i getting errors and dont install.
« Antworten #3 am: Januar 26, 2012, 08:46:49 am » |
Which errors do you get? You might also contact our support via Skype chat (sundtek).
donald
« Antworten #4 am: Januar 27, 2012, 08:05:09 am » |
i install. the sundtek in the qnap so far so good now install also the driver into de vu duo (pli) and see now the app. sundtek controle centre i open it and fill in the ip of the qnap after that i push 'ok' and then i get the question:you have not corrctly install the driver i install. again. it is ok. but after that again the same question that the driver not corr. is install. what to do now?
thanks don
donald
« Antworten #6 am: Januar 27, 2012, 06:53:03 pm » |
yes, i have do that and its correct installed, the same question still after reboot and "oke" that the driver not corr. is install.
« Antworten #7 am: Januar 27, 2012, 06:59:48 pm » |
Maybe you should contact our skype support chat (sundtek) or give us a call.
This discussion is mixing up Dreambox with QNAP now.
For QNAP: It depends which version you have, some QNAP Systems have a virtual Filesystem in that case our installer only installs the driver into memory. After a reboot the driver will be removed automatically (so you have to reinstall by yourself in that case).
For Dreambox: it should just work as in the Link.
donald
« Antworten #8 am: Januar 29, 2012, 05:04:37 pm » |
its only works when i put the sundtek into the vu+ then i can choose of the c tuner but when i put it in the qnap i dont see a c tuner in the vu+ also not when i use sundtek control center and fill in the network config .
« Antworten #9 am: Februar 08, 2012, 04:12:18 pm » |
You can also retry the network functionality. We had some issues in the network discovery mechanism.
