Autor Thema: qnap  (Gelesen 15963 mal)
donald
qnap
« am: Januar 25, 2012, 07:41:13 Nachmittag »
how to install. driver of the sundtek media tv digital home dvb/ct into the Qnap ts 119 nas?
don.
Re:qnap
« Antwort #1 am: Januar 26, 2012, 05:20:26 Vormittag »
Just log in into your QNAP and install the driver according to the installation, it's everywhere the same.
donald
Re:qnap
« Antwort #2 am: Januar 26, 2012, 09:16:38 Vormittag »
yes i do that,so far so good, but when i set the last line
./sundtek_installer_development.sh
i getting errors and dont install.
Re:qnap
« Antwort #3 am: Januar 26, 2012, 09:46:49 Vormittag »
Which errors do you get? You might also contact our support via Skype chat (sundtek).
donald
Re:qnap
« Antwort #4 am: Januar 27, 2012, 09:05:09 Vormittag »
i install. the sundtek in the qnap
so far so good now
install also the driver into de vu duo (pli)
and see now the app. sundtek controle centre
i open it and fill in the ip of the qnap
after that i push 'ok' and then i get the question:you have not corrctly install the driver
i install. again. it is ok.
but after that again the same question that the driver not corr. is install.
what to do now?
thanks
don
Re:qnap
« Antwort #5 am: Januar 27, 2012, 09:08:55 Vormittag »
http://support.sundtek.com/index.php/topic,348.0.html
please follow our instruction how to install it on a settopbox.
donald
Re:qnap
« Antwort #6 am: Januar 27, 2012, 07:53:03 Nachmittag »
yes, i have do that and its correct installed,
the same question still after reboot and "oke" that the driver not corr. is install.
Re:qnap
« Antwort #7 am: Januar 27, 2012, 07:59:48 Nachmittag »
Maybe you should contact our skype support chat (sundtek) or give us a call.
This discussion is mixing up Dreambox with QNAP now.
For QNAP:
It depends which version you have, some QNAP Systems have a virtual Filesystem in that case our installer only installs the driver into memory. After a reboot the driver will be removed automatically (so you have to reinstall by yourself in that case).
For Dreambox:
it should just work as in the Link.
donald
Re:qnap
« Antwort #8 am: Januar 29, 2012, 06:04:37 Nachmittag »
its only works when i put the sundtek into the vu+
then i can choose of the c tuner
but when i put it in the qnap i dont see a c tuner in the vu+
also not when i use sundtek control center
and fill in the network config .
Re:qnap
« Antwort #9 am: Februar 08, 2012, 05:12:18 Nachmittag »
You can also retry the network functionality. We had some issues in the network discovery mechanism.
