Erweiterte Suche
9305 Beiträge in 1192 Themen- von 1728 Mitglieder - Neuestes Mitglied: Plobb
Mai 25, 2013, 09:24:26 pm
Sundtek Support ForumEnglishVU+ - VU Duo SettopboxCable recording issues
Seiten: [1]
Drucken
Autor Thema: Cable recording issues  (Gelesen 831 mal)
rassi
Newbie
Profil anzeigen
« am: Dezember 15, 2011, 11:20:00 am »
I got issues with cable recordings, in normal situation I use Sundtek as C tuner only for one cable channel and many many times, recordings hasn't work properly.
1. it has recorded maybe 10minutes from start
2. recording is just blackscreen and it stops immediately after trying to play it.
3. Record is pixelated, lot´s of glitches.
All Cable channels which I use are FTA channels, so it is not any CAM issue.
I have also used C-tuner channels as alternativate services for satellite channels and looks like when VU+ DUO has recorded from C-tuner issues are there.
i haven´t tested not so much the issues, but looks like live TV wathing with Sundtek stick is Ok. All DVB-S2 works perfectly even if there is many recordings at the same time.
Read/Write troughput from VU+ to NAS (so it is not network transfer issue):
Code:
Results for write throughput:
76.695 Mbit/s with udp,async,wsize=16384
76.695 Mbit/s with tcp,async,wsize=4096
67.108 Mbit/s with udp,async,wsize=8192
67.108 Mbit/s with udp,async,wsize=4096
67.108 Mbit/s with udp,async,wsize=32768
67.108 Mbit/s with tcp,async,wsize=8192
67.108 Mbit/s with tcp,async,wsize=32768
67.108 Mbit/s with tcp,async,wsize=16384
Results for read throughput:
89.478 Mbit/s with udp,async,rsize=8192
89.478 Mbit/s with udp,async,rsize=32768
89.478 Mbit/s with udp,async,rsize=16384
89.478 Mbit/s with tcp,async,rsize=8192
89.478 Mbit/s with tcp,async,rsize=4096
89.478 Mbit/s with tcp,async,rsize=32768
89.478 Mbit/s with tcp,async,rsize=16384
76.695 Mbit/s with udp,async,rsize=4096
Dev. drivers updated couple of days a go and it is tested with both Sundtek Pro sticks which i do have and image is now BH 1.6.6
Will powered USB hub give some advantages?
PS. Same message (only shorter) is in BH forum, so you can ignore it from there.
Gespeichert
Seiten: [1]
Drucken
Gehe zu:
