Autor Thema: Linux driver 18. May 2017 (recommended)  (Gelesen 72505 mal)
« am: September 08, 2011, 09:04:27 Vormittag »
Installer (all systems): http://www.sundtek.de/media/sundtek_installer_development.sh (15 MByte)
NetInstall (all systeme): http://www.sundtek.de/media/sundtek_netinst.sh (70 KByte)
(netinst is usually useful for embedded systems which do not have enough temporary space for the full installer)
Settopboxes: http://sundtek.de/media/sundtek-netinst-driver_1.0_all.ipk (940 Byte)
Debian/Ubuntu: http://sundtek.de/media/sundtek-netinst-driver.deb (850 Byte)
Synology NAS Package Source: http://sundtek.de/synology (neu!)
QNAP NAS Package: http://sundtek.de/media/sundtek_driver_qnap.zip (QPKG, installable via Webinterface)
Thecus NAS: http://sundtek.de/media/Sundtek_1.0.0.0.mod (Installation via Application Server / App Installation - Webfrontend)
OpenELEC Plugin: http://www.sundtek.de/media/driver.dvb.sundtek-mediatv-3.0.3.zip
The english changelog section is usually not up to date, but the drivers are. If any questions arise feel free to post them here in english.
German Changelog (which is up to date):
http://support.sundtek.com/index.php/topic,1573.0.html
http://support.sundtek.com/index.php/topic,1121.0.html
* Closed Caption Support for American television (3. August 2012)
* Erster Closed Caption Test (3. August 2012)
- Closed Caption Standard Characters
- Closed Caption Extended Characters
- Closed Caption Special Characters
« Letzte Änderung: Juni 30, 2017, 04:02:43 Nachmittag von Sundtek »
gergomez
Re:Linux Driver 5th March 2012 (recommended)
« Antwort #1 am: März 23, 2012, 04:19:27 Nachmittag »
Hello, I'm having problems with mplayer since sundtek_installer_110207.2248.sh, mplayer stutters and blocks and inform me about my computer is not fast enough for playing that content, also the driver makes a kworker process high on CPU (about 5%). I've tried latest version (as of 2012/03/23) and I have the same problem.
Any idea?
gergomez
« Antwort #2 am: März 23, 2012, 04:34:08 Nachmittag »
fixed it adding a buffering cache (-cache 10240) and setting the transfermode to iso.
Regards,
« Antwort #3 am: März 24, 2012, 08:18:33 Vormittag »
great, we always recommend some buffer for mplayer since it affects the stream detection it seems.
We also think there's some space for improvement in mplayer for that part
Re:Linux Driver 7th July 2012 (recommended)
« Antwort #4 am: Juli 08, 2012, 06:03:22 Nachmittag »
Driver is updated and includes support for some new upcoming devices.
frankt
Re:Linux Driver 3rd August 2012 (recommended)
« Antwort #5 am: August 20, 2012, 03:06:18 Nachmittag »
I've installed the Ubuntu/Debian driver - and the software centre says it's "installed".
And yet, when I try to create a channel config for Kaffeine I get the following:
output format kaffeine channels.dvb
   /dev/dvb/adapter0/frontend0 -> DVB-C "Sundtek DVB-C": specified was DVB-T -> SEARCH NEXT ONE.
main:2960: FATAL: ***** NO USEABLE DVB CARD FOUND. *****
Any ideas?
« Antwort #6 am: August 20, 2012, 04:53:42 Nachmittag »
it says what it says...
It found a DVB-C device while the channel file was made for DVB-T.
In order to switch the device to DVB-T run:
/opt/bin/mediaclient -DDVBT -d /dev/dvb/adapter0/frontend0
fpbx
Re:Linux Driver 11th November 2012 (recommended)
« Antwort #7 am: Dezember 17, 2012, 11:06:55 Vormittag »
Habe folgendes Problem mit Kaffeine (DVB-T)und dem Parameter:
mediaclient --updaterc=0 / 1
Ist dieser gesetzt, erscheint bei DVB-T zwar noch die Senderinformation, danach kommt aber ein "Lesefehler vom Device". In der Log erscheint:kaffeine(14209) DvbDevice::frontendEvent: tuning failed
Setze ich diesen Parameter nicht, funktioniert es einwandfrei. Die Kaffeineversion: 1.2.2
Kann jemand helfen?
Taiger
« Antwort #8 am: Dezember 17, 2012, 07:32:30 Nachmittag »
Is it only me or?
I can't seam to download latest drivers from 11th November 2012:
I only get a small part of the file (about 82kB)
I tried a couple of weeks back with same result. Could someone fix the link/file?
Or re-share it for me?
Br
Taiger
« Antwort #9 am: Dezember 17, 2012, 07:42:54 Nachmittag »
That driver now links to the netinst driver, and the netinst driver will always download the latest version.
Please note that the german change log section really contains the latest changes for the drivers (the english section is a bit outdated - but will always get you the latest drivers at least)
« Antwort #10 am: Dezember 17, 2012, 07:45:31 Nachmittag »
Kann jemand helfen?
Wird aktuell bearbeitet/überprüft, Antwort kommt dann noch.
Taiger
« Antwort #11 am: Dezember 17, 2012, 08:53:38 Nachmittag »
Okay thank you for the fast answer..
Br
Taiger
« Antwort #12 am: Dezember 18, 2012, 12:57:55 Nachmittag »
Kann jemand helfen?
Das scheint hier soweit kein Problem zu bereiten, es scheint jedoch ein Problem zu geben wenn Kaffeine den ersten eingeschaltenen Sender nicht empfangen konnte. Der Treiber wurde mittlerweile aktualisiert (das Problem wurde wohl durch den "rewrite" im August verursacht). Löst das eventuell bereits dein Problem?
Hast du initial_dvb_mode=DVBT in /etc/sundtek.conf gesetzt, bzw. wie sieht deine sundtek.conf aus?
« Letzte Änderung: Dezember 18, 2012, 01:19:07 Nachmittag von Sundtek »
fpbx
Re:Linux Driver 14th December 2012 (recommended)
« Antwort #13 am: Dezember 18, 2012, 01:25:37 Nachmittag »
Hallo Hero,
hatte bislang keine /etc/sundtek.conf. Habe eine angelegt und den von Dir empfohlenen Eintrag gemacht. Danach konnte ich bei Kaffeine (unabhängig ob nun updaterc genutzt wurde oder nicht), nichteinmal mehr "Digitales Fernsehen" aufrufen. Der Monitor wurde dunkel - die Systemlast ging auf 100%. Zu dem Punkt, dass das nur passiert, wenn der 1. DVB-T Sender nicht gefunden wird: Warum findet er denn ohne "updaterc" den 1. Sender?
Ich starte Kaffeine wie folgt:
#!/bin/bash
PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/opt/bin
# mediaclient --updaterc=1 -d /dev/mediainput0
mediaclient -D DVBT
SOLID_HAL_LEGACY=1
sudo kaffeine
« Antwort #14 am: Dezember 18, 2012, 01:35:20 Nachmittag »
Ist der aktuelle Treiber installiert (welcher vor ein paar Minuten aktualisiert wurde)? Eventuell können wir das via Chat durchgehen
http://chat.sundtek.de damit es schneller geht.
Was für ein System ist das überhaupt, wir haben es soweit auf Ubuntu 12.10 getestet ebenfalls mit Kaffeine 1.2.2
« Letzte Änderung: Dezember 18, 2012, 01:37:24 Nachmittag von Sundtek »
