Autor Thema: Access to raw frame, including VBI?  (Gelesen 7067 mal)
RawVBI
« am: August 24, 2009, 08:30:05 Nachmittag »
Using your hardware under windows, is it possible to get individual frames in memory buffers?
If so, in what format - BMP/RGB?
And most importantly, is the VBI also available in memory buffer per frame? I need all the lines (1-21) of the VBI. not just the 480 lines of video (NTSC, 30fps).
Thank you.
Re:Access to raw frame, including VBI?
« Antwort #1 am: August 24, 2009, 08:44:28 Nachmittag »
The video output can be RGB16 or raw YUV frames.
Thank you.
VBI is supported, do you need the raw samples or the final decoded information?
