Autor Thema: Cannot watch HD channels...  (Gelesen 6078 mal)
druggo
« am: Juni 21, 2011, 08:40:21 Vormittag »
Hi there, i just got a Ver 3 i beleive (how can i see the version of the stick?)
i am using tvheadend as backend server, and xbmc as frontend.
SD channels tune fine and amazing fast compared to the tevii-crap i used earlier (stay away from tevii everyone!)
however, when i tune to HD channels, i get following in my logs.
2011-06-21 08:31:41 [852] skipped everything ...
2011-06-21 08:31:41 [852] THERE MUST BE A BUG WITH YOUR HARDWARE, PLEASE CHECK ISO/BULK TRANSFER MODE
2011-06-21 08:31:41 [852] Packetsize < 188 bytes is invalid, throwing it away and increasing corruption
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (0)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (590)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (439)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (745)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (669)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (438)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (902)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (771)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (425)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (564)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (756)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (752)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (376)
2011-06-21 08:31:41 [852] TS Sync byte not aligned, realigning stream (188)
my signalstrength:
-bash-4.2# /opt/bin/mediaclient --readsignal=0 -d /dev/dvb/adapter0/frontend0
SIGNAL: [........................         ] ( 72%)  BER:   2386 FREQ: 1415000    Hz LOCKED:  NO SYM: 30000000 FEC: FEC_3_4 VOLTAGE: 18V TONE: ON
SIGNAL: [........................         ] ( 72%)  BER:   2386 FREQ: 1415000    Hz LOCKED: YES SYM: 30000000 FEC: FEC_3_4 VOLTAGE: 18V TONE: ON
any ideas on what i should check???
