Autor Thema: TS Sync byte not aligned  (Gelesen 22131 mal)
druggo
Re: TS Sync byte not aligned
« Antwort #15 am: Juli 04, 2011, 01:09:23 Nachmittag »
I have 76% signal quality, should that be enough?
I ordered my stick 03.05.2011 19:53:59, order no 1946, however, it was not shipped untill mid-june..
« Antwort #16 am: Juli 04, 2011, 02:19:39 Nachmittag »
Signal quality should be enough but we better replace the unit with a new one this month.
druggo
« Antwort #17 am: Juli 05, 2011, 04:27:13 Nachmittag »
Ok i will email you!
« Antwort #18 am: Juli 05, 2011, 04:27:40 Nachmittag »
Can you please send an email with your ordernumber to kontakt at sundtek de
druggo
« Antwort #19 am: Juli 05, 2011, 04:30:39 Nachmittag »
done deal!
druggo
« Antwort #20 am: Juli 19, 2011, 10:41:35 Vormittag »
Hi i have received the new stick - and swapped it, too bad the same results (see attached logfile) i also tried to upgrade to the latest driver, same error (see logfile)
Anything else you want me to try?
with latest driver:
Logfile @ http://dl.dropbox.com/u/8760671/mediasrv.log
Br
Tobias
therock
« Antwort #21 am: August 03, 2011, 05:06:37 Nachmittag »
hi i just tryed the new 3.5 i got with the mail aswell and i have the same problems
2011-08-03 16:59:51 [902] found lock
2011-08-03 16:59:52 [902] voltage is low/0
2011-08-03 16:59:52 [902] Starting diseqc timing
2011-08-03 16:59:52 [902] diseqc len: 4/0
2011-08-03 16:59:53 [902] Diseqc execution time: 267 ms
2011-08-03 16:59:53 [902] diseqc send burst Modulated (SEC_MINI_B)
2011-08-03 16:59:53 [902] Starting tuning timing
2011-08-03 16:59:53 [902] Tuning DVB-S2 (QPSK) Transponder
2011-08-03 16:59:53 [902] USING FEC_3_4
2011-08-03 16:59:53 [902] roll off 035
2011-08-03 16:59:53 [902] LNB tone off
2011-08-03 16:59:53 [902] voltage is low
2011-08-03 16:59:53 [902] setting frequency: 1028000
2011-08-03 16:59:53 [902] setting symbolrate: 25000
2011-08-03 16:59:53 [902] using auto mode for this transponder
2011-08-03 16:59:54 [902] Tuning delay: 694 ms
2011-08-03 16:59:54 [902] TS Sync byte not aligned, realigning stream (0)
2011-08-03 16:59:54 [902] TS Sync byte not aligned, realigning stream (192)
2011-08-03 16:59:54 [902] TS Sync byte not aligned, realigning stream (463)
2011-08-03 16:59:54 [902] TS Sync byte not aligned, realigning stream (555)
2011-08-03 16:59:55 [902] TS Sync byte not aligned, realigning stream (0)
2011-08-03 16:59:55 [902] TS Sync byte not aligned, realigning stream (192)
2011-08-03 16:59:55 [902] TS Sync byte not aligned, realigning stream (523)
2011-08-03 16:59:55 [902] TS Sync byte not aligned, realigning stream (441)
2011-08-03 16:59:55 [902] TS Sync byte not aligned, realigning stream (639)
2011-08-03 16:59:55 [902] skipped everything ...
2011-08-03 16:59:55 [902] found lock
2011-08-03 16:59:55 [902] TS Sync byte not aligned, realigning stream (429)
2011-08-03 16:59:55 [902] TS Sync byte not aligned, realigning stream (677)
2011-08-03 16:59:55 [902] TS Sync byte not aligned, realigning stream (489)
2011-08-03 16:59:55 [902] TS Sync byte not aligned, realigning stream (399)
2011-08-03 16:59:55 [902] TS Sync byte not aligned, realigning stream (691)
2011-08-03 16:59:55 [902] TS Sync byte not aligned, realigning stream (385)
2011-08-03 16:59:55 [902] TS Sync byte not aligned, realigning stream (633)
« Antwort #22 am: August 03, 2011, 05:17:40 Nachmittag »
We already figured out this issue and are testing some different components for it this week.
We mainly use Astra 19.2 / Hotbird for testing, those satellites have different requirements compared with eg. Thor5. Anyway more about this issue will be posted within the next 1-2 days. That issue mainly affects northern Europe (scandinavian Area as far as we could figure this out) so our current plan is to provide different S2 sticks for that region.
« Letzte Änderung: August 03, 2011, 05:19:27 Nachmittag von Sundtek »
therock
« Antwort #23 am: August 08, 2011, 09:01:10 Vormittag »
okay looking forward to getting this problem fixed
druggo
« Antwort #24 am: September 06, 2011, 07:29:55 Nachmittag »
hi any news???
« Antwort #25 am: September 06, 2011, 07:40:44 Nachmittag »
Working on adding the features of the central European stick to the stick which is compatible with Thor5/Scandinavia.
We'll send you the current engineering sample which already works with it as soon as we have the next cut (1-2 weeks) so you have something to play around with.
« Antwort #26 am: September 15, 2011, 08:01:10 Nachmittag »
Small Update:
3 handmade samples are ready for the Scandinavian market which solve those issues, the devices will be shipped out at around mid next week.
