Autor Thema: TS Sync byte not aligned  (Gelesen 22129 mal)
therock
« am: April 23, 2011, 07:58:21 Nachmittag »
Hey
i just installed my new Sundtek SkyTV Ultimate onto my xbmc linux box
with kernel Linux XBMCLive 2.6.32-26-generic #48-Ubuntu SMP Wed Nov 24 09:00:03 UTC 2010 i686 GNU/Linux
and the tone and all that is fine on normal SD channels
but when i want to watch a HD channel it gives a pixel picture and this is what i got from the log file
2011-04-23 19:52:38 [851] Packetsize < 188 bytes is invalid, throwing it away and increasing corruption
2011-04-23 19:52:38 [851] THERE MUST BE A BUG WITH YOUR HARDWARE, PLEASE CHECK ISO/BULK TRANSFER MODE
2011-04-23 19:52:38 [851] TS Sync byte not aligned, realigning stream (752)
2011-04-23 19:52:38 [851] skipped everything ...
2011-04-23 19:52:38 [851] TS Sync byte not aligned, realigning stream (376)
2011-04-23 19:52:38 [851] TS Sync byte not aligned, realigning stream (568)
2011-04-23 19:52:38 [851] TS Sync byte not aligned, realigning stream (564)
2011-04-23 19:52:38 [851] TS Sync byte not aligned, realigning stream (756)
2011-04-23 19:52:38 [851] TS Sync byte not aligned, realigning stream (188)
is there anything i can do?
Re: TS Sync byte not aligned
« Antwort #1 am: April 23, 2011, 08:26:03 Nachmittag »
What System do you use?
Are you using any graphic acceleration for HDTV?
Please provide some information about the CPU load (eg. screenshot of top on the console).
please note that decoding HDTV with the CPU can take a massive amount of CPU and steal it from the driver finally corrupting the datatransfer.
So far we advice to use NVidia Graphiccards for HDTV since they have mature support so far.
therock
« Antwort #2 am: April 23, 2011, 09:15:51 Nachmittag »
im on a zotac zbox id11 with a Intel Atom 1.6Ghz with nvidia ION2 with VDPAU
top - 21:14:22 up  2:49,  1 user,  load average: 0.79, 0.86, 0.72
Tasks: 132 total,   1 running, 131 sleeping,   0 stopped,   0 zombie
Cpu(s):  8.9%us,  2.7%sy,  0.0%ni, 87.5%id,  0.1%wa,  0.2%hi,  0.6%si,  0.0%st
Mem:   1024868k total,   620136k used,   404732k free,    76828k buffers
Swap:  3108260k total,        0k used,  3108260k free,   327616k cached
 2639 xbmc      20   0  138m  12m 5436 S   23  1.3   6:34.59 tvheadend
 2943 xbmc      20   0  409m 128m  41m S   20 12.8   8:05.00 xbmc.bin
  851 root      18  -2  106m 9.9m 6460 S    6  1.0  11:09.19 mediasrv
  931 root      20   0     0    0    0 S    2  0.0   2:40.16 hd-audio1
 2895 root      20   0 43172  32m 9752 S    1  3.2   0:25.65 Xorg
but yeah it looks like it can't manage the load but if i play a mkv HD movie it plays nicely
so its not that bad on cpu
« Antwort #3 am: April 24, 2011, 01:11:24 Vormittag »
We're still missing the BER (Bit error rate) reporting in the driver it should be available early next week, that should help to go further with that problem.
HDTV in general is no issue normally.
therock
« Antwort #4 am: April 24, 2011, 01:20:22 Vormittag »
okay looking forward to that...
anyway if i mount it in a very powerfull pc with the same kernel it should work with HD channels right?
« Antwort #5 am: April 24, 2011, 01:42:41 Vormittag »
Let's check the statistics first.
therock
« Antwort #6 am: April 24, 2011, 04:12:20 Nachmittag »
okay but if i put the same cable in my sat i get a fine signal so i dont think it has anything todo with BER...?
therock
« Antwort #7 am: Mai 10, 2011, 03:13:27 Nachmittag »
is the BER reporting enabled or when will it be enabled in a new driver?
« Antwort #8 am: Mai 10, 2011, 04:37:20 Nachmittag »
We are currently working on getting the Signal Strength into the driver, the problem is that specific part is missing from the information which we received from our chip dealer.
BER is basically no problem, we'll check it quickly tomorrow morning. Our main interest is the signal quality indicator.
« Antwort #9 am: Mai 11, 2011, 04:19:00 Vormittag »
We received all the necessary information this morning so it will be available very soon, also we've been told that the driver for the S2 chip component is outdated. We're going to update it completely asap.
« Letzte Änderung: Mai 11, 2011, 04:34:08 Vormittag von Sundtek »
« Antwort #10 am: Mai 11, 2011, 05:29:25 Nachmittag »
Just to update this, we updated the BER but are still testing how usable those values are and finding some reference values by comparing it with different devices on the market.
Good for us the BER value is always low but question is how correct this is so more testing is needed, we only tested those values for one day so far so more work is needed.
One thing we noticed is that the F-Connector of the LNB cable is a major point of failure we have several different cables for testing - the cable itself does not matter but the connector. Cables with a high quality F-Connector never caused any change of the signal quality when moving or touching this part. Whereas cheap connectors which did not connect both items rock solid could cause a drop of signal quality of up to 30%.
« Letzte Änderung: Mai 11, 2011, 05:35:12 Nachmittag von Sundtek »
druggo
« Antwort #11 am: Juni 21, 2011, 01:49:25 Nachmittag »
hi therock, did you manage to get HD working? I seem to have the exact same issue:
http://support.sundtek.com/index.php/topic,651.0.html
« Antwort #12 am: Juni 21, 2011, 07:28:18 Nachmittag »
we're looking at it (but please expect the answer in 1-2 days), we can't answer before we finish some testing with new devices.
The device overall should be fine but sensitivity might need to be improved of your stickversion, testresults will be available soon.
druggo
« Antwort #13 am: Juni 27, 2011, 10:07:04 Vormittag »
Ok, it has now been more than 1-2 days, whats the status?
« Antwort #14 am: Juni 27, 2011, 07:12:18 Nachmittag »
We did some tests, basically if your LNB delivers a strong enough signal it should work without any problem.
However, we were working together with the tuner company within the last week and found a way to improve the sensitivity of our USB Stick. The sensitivity of the latest DVB-S/S2 stick is at least as good as with regular settopboxes (if not better). We also compared some other PCTV DVB-S/S2 devices (eg. TT S2-3650) and figured out that the latest revision (v3.5) has a much more sensitive tuner implementation now.
If you have purchased your tuner after 20. May we will replace the USB Stick for free with a new version, if not we will charge a small handling fee (basically shipping + 2 EUR handling) for upgrading the USB Stick, plus we need the old stick in return (only the USB Stick).
This upgrading option will only be available as long as devices are available at the beginning. Once the mass production has been finished in August it will be available until the end of 2011.
Rev 3.5:
* improved sensitivity
Rev 3.0:
* short circuit protection
* works without AC adapter with many active multiswitches
* faster inductor discharging (eg. when disconnecting AC adapter while stick is connected to an active multiswitch).
* stick shows up red light if something's wrong
« Letzte Änderung: Juni 27, 2011, 07:42:46 Nachmittag von Sundtek »
